Old Sat, Jun-01-2013, 08:22:33 AM   #81
mscott7426
Reputation: 0 mscott7426 is on a distinguished road
Default Re: Track friendly brake upgrade that doesn't break the bank?
For the people that are swapping to/from track pads, do you make sure to use street pads with similar compound? Or just bed the pads in on each swap?
I think I've been cooking the current pads, and am considering running a dedicated track pads, but am concerned about having the transfer layer on the pad.
I dug through the parts the PO gave me and found some Axxis XBR pads, but from what I've seen they're not necessarily track pads.
Jump to top mscott7426 is offline   Reply With Quote
Old Sun, Jun-02-2013, 03:12:48 PM   #82
kaiv
SoCal S54 specialist :P
kaiv's Avatar
Reputation: 0 kaiv is on a distinguished road
France
I guess I can answer my own thread, 3 years later!
I've had ST40s (E46 M3), ST60 (E90 M3) and now I run stock brakes on my E92 M3.
I'm the happiest with the stock setup and so is my wallet.
Truth of the matter is BBKs look nice but are kinda unnecessary.
So if anyone is wondering, the best track brake upgrade that doesn't break the bank is:
PFC 01 pads
Good fluid
Good lines
That's it.
As for swapping back and forth, I run OE on the street and they get along with the PFCs extremely well.
I swap back and forth all the time (each track weekend) and I literally just pop them in, drive off, apply the brakes a couple times and it's ready to go. It's like a match made in heaven. I don't remember the last time I had to bed my own brakes.
E46 ///M325i Touring journal
Kaiv's SoCal Feedback! IG: limited.slip
Jump to top kaiv is offline   Reply With Quote
Old Sun, Jun-02-2013, 03:49:47 PM   #83
m3 hal
Reputation: 0 m3 hal will become famous soon enough
^have you used the PFC 08's? I'm using them currently and was wondering how they compare to 01's.
Jump to top m3 hal is offline   Reply With Quote
Old Tue, Jun-04-2013, 06:11:31 AM   #84
aongch
Reputation: 0 aongch is on a distinguished road
I'm still experimenting and have not gone to BBKs yet, if necessary. Kevin thanks for those stockers inputs as you've done tons of track days on various tracks. Per the pics below, I've experienced one of the non-optimum set ups for my E46 - stock rotors on Hawk HT-10s with stock backing plates. After 3-4 track days on these front pads I definitely see major overheating and cracks/stress lines. This is mostly from Auto Club Speedway lapping where T3 is notorious for heavy braking (135 to 5 mph!) and most temps are at least in the 80's. I've now removed part of the backing plate except around the ball joints and will do the DTC-60s next, which I've heard are easier on rotors. I'm also on stock size Stoptech/Powerslot slotted rotors now. We'll see.
'02 E46 M3 TiAg 6MT | GC | Koni | Eibach | GruppeM | Apex ARC-8 | NT-01/R-S3 | Sparco | Bell | TMS | Evolve-R
Jump to top aongch is offline   Reply With Quote
Old Wed, Jun-12-2013, 05:51:55 PM   #85
mscott7426
I ended up getting PFC 08s, mostly due to availability, definitely put a hurt to the wallet though.
I was only able to get the fronts in before heading to the track. The braking was much improved, though I was still getting some pedal fade later in sessions. I'll chalk that up to having the OEM-ish rear pads in currently.
Also, these things SCREAM when they're cold.
Which pad grease and backing plates (if any) do you guys use? Does anything quiet them down?
Old Thu, Jun-13-2013, 04:49:02 AM   #86
admranger
Registered troublemaker
Reputation: 0 admranger is on a distinguished road
I run PFC Z-rated for the street. PFC-06 for the track. I'll switch to PFC-08's if I ever wear out the 06's. I have '08s for the E90M3 and they worked great.
'11 E90 M3, Melbourne/Black/Fox Red/Black, 6MT, roof, PP2, heated seats, Eibach Pro Kit, GC Street camber plates, Arc-8's, Technic harness, JL XD 600/6
'16 X5 40e Mineral White/Black Dakota Leather, ZLL, ZCW, ZDA, ZDB, ZPP, side shades, multi contour seats, HK stereo
Jump to top admranger is offline   Reply With Quote
Old Fri, Jun-14-2013, 12:31:15 PM   #87
Feffman
Grand Poobah
Feffman's Avatar
Reputation: 0 Feffman is on a distinguished road
You may want to give Danny Puskar at Carbotech (www.CTBrakes.com) a call. I've found their XP series to not only work great (initial bite, modulation, etc.) but they are VERY easy on rotors.
Feff
MVP Track Time
Jump to top Feffman is online now   Reply With Quote
bank, brake, break, friendly, track, upgrade
Discussing Track friendly brake upgrade that doesn't break the bank? in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
