Old Tue, Jun-04-2019, 09:48:37 PM   #1
M3kanic
Reputation: 0 M3kanic is on a distinguished road
Default Does this idle tick sound normal?
Hello everyone, long time lurker, first time poster. The strange thing about this tick is that it fades in and out, and I really only hear when next to a wall or enclosed area. It's mainly when the oil is hot. I've had the car for a year and got it with 146,000 miles. Currently at 158,000. I just did a valve adjustment and none were out more than one shim size larger. Recent Blackstone analysis was perfect. I replaced rod bearings at 150,000 with OE. I did the full Besian Vanos treatment as soon as I got the car. Compression test is good. New plugs and coils. It may be normal and I'm just being overly paranoid. All opinions welcome! I will admit that I did not carefully look at each cam lobe and rocker arm while doing the valve adjustment.
Jump to top M3kanic is offline   Reply With Quote
Old Tue, Jun-04-2019, 10:39:06 PM   #2
switlikbob
///Money
switlikbob's Avatar
Reputation: 0 switlikbob is on a distinguished road
Default Re: Does this idle tick sound normal?
Almost sounds like injectors to me.
Sent from my Pixel 2 using Tapatalk
2001 Laguna Seca ///M3
Jump to top switlikbob is offline   Reply With Quote
Old Tue, Jun-04-2019, 10:55:08 PM   #3
kuksul08
Sounds normal to me. These engines are very noisy. You need to worry when it's more of a knocking sound either from the VANOS or deep within the motor.
Old Sat, Nov-02-2019, 04:32:38 PM   #4
M3kanic
Bump. I've noticed that if I put a load on the engine, like turning the steering wheel or putting it in gear and easing out on the clutch with the brake on, the noise stops. Any other suggestions?
Old Sat, Nov-02-2019, 05:44:07 PM   #5
stash1
Your username is 'mechanic'...are you sure this isn't a troll post? This isn't siwon66 is it?
'04 AW/IR...some mods
Old Sat, Nov-02-2019, 07:23:40 PM   #6
HassanEido
HassanEido's Avatar
Lebanon
Hahahaha.
@op I agree sounds normal to me from the video fwiw
PM for performance tune requests
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Sat, Nov-02-2019, 08:31:47 PM   #7
M3kanic
Thanks for the replies. Haha no it's not siwon66. I've been a mechanic for 17 years and a Bentley master tech for 12
Old Sun, Nov-03-2019, 01:35:05 PM   #8
the-git
void
Reputation: 0 the-git is on a distinguished road
Check the condition of the accessory drive belts...if the noise changes quality with steering input.
Jump to top the-git is offline   Reply With Quote
Old Sun, Nov-03-2019, 02:01:37 PM   #9
ThunderMoose
I usually grab my stethoscope and poke around. The injectors sure seem loud on these cars.
Discussing Does this idle tick sound normal? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
