Old Sun, Jan-06-2019, 01:41:58 AM   #21
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Default Re: Electric fan upgrade
I ran the Mishimoto fan mounted inside the stock fan shroud using a PWM unit and it worked good. We have have summer temps between 100-120 degrees so I kept the Aux Fan as well.
All fans have different depths. The Spal 30101516 and the Mishimoto Fan will fit into the stock fan shroud because of their thickness. The Spal 2049, 2082 etc will not.
I mounted the Mishi Fan offset toward the drivers side as far as possible inside the shroud. You can see how close it is to the water pump shaft. The photo is looking up from under the car.
I recently purchased the Spal 2082 and the N15 Electric Fan Mounts with a Koyorad radiator. The Spal 2049 and 2082 have approx 500 more CFM's than the Mishimoto fan.
Get the Spal 2049 or 2082.
http://www.m3forum.net/m3forum/showthread.php?t=599479
http://www.m3forum.net/m3forum/showthread.php?t=589875
Old Sun, Jan-06-2019, 01:52:10 AM   #22
erickrayos
what controller are you running? can you link everything you needed for that controller to run? thanks!
Old Sun, Jan-06-2019, 05:24:49 AM   #23
STAATS
STAATS's Avatar
Does anyone happen to know the CFM of the Aux fan?
I have often thought about deleting both Mech and Aux and putting a more powerful one in place of the Aux as there is more room.
Currently I run the Aux and a Mishi fan but I would like to delete one of them and just run one fan for simplicity and weight
STAATS
Old Sun, Jan-06-2019, 12:39:14 PM   #24
Kcalhoun27
Reputation: 0 Kcalhoun27 is on a distinguished road
I cant speak to the cfm, but i pulled both fans and replaced them with a spal 2049 wired direct to the original fan computer, or whatever its called. I do not track my car, but even in the summer with the a/c running, my temps never went past 210F. Worked like a charm, two wires to connect and then i made the mounts to bolt onto the radiator with about 1/4 of standoff.
I am quite certain you could run it for a dd all day, for a track car id guess its fine but dont let my lack of experience there blow up your motor
Jump to top Kcalhoun27 is offline   Reply With Quote
Old Sun, Jan-06-2019, 04:31:01 PM   #25
M3AZ
///M3AZ
M3AZ's Avatar
Reputation: 0 M3AZ is on a distinguished road
There seems to be a lot of focus on increasing CFM. Unless the fan is constantly running and still not providing sufficient cooling, the CFM is enough.
As I noted, the Mishimoto barely comes on in normal driving, and the coolant temp does not go much over 200 even when tracking (this is in Phoenix, AZ). For 99.9% of us, the CFM could be quadruple and it would make no difference (the fan would simply cycle more often and for less time). That said, those who plan to run a 24-hour race in the Gobi Desert may benefit from a bit more CFM.
If you are experiencing cooling problems, the issue may be another component in your cooling system. Increasing CFM with a 15-year old radiator probably won't fix anything.
Old Sun, Jan-06-2019, 04:58:30 PM   #26
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
You will need a PWM 50 AMP Controller, temp sensor and radiator hose adapter. I would also install a separate 40amp fuse for added protection. Use 10 gauge wire for the fan control leads (+ and -) and 16 gauge for the rest. He now has a new "No Buzz" controller so you will not need the separate Buzz Box like I have. You can use any inline radiator adapter, I used the Mishimoto one.
There is a wiring diagram on his website for the controller.
NB-50 NO "BUZZ" 50 AMP Controller
http://www.autocoolguy.com/product-p...o-buzz-50-amps
Brass Plug Temp Sensor
http://www.autocoolguy.com/product-p...s-plug-sensors
Inline Radiator Adapter
http://www.autocoolguy.com/product-p...-inline-sensor
Old Sun, Jan-06-2019, 05:04:22 PM   #27
Good points. Refresh your cooling system (thermo, rad, wp, coolant, o-rings, sensors) if it's got 80k+ and/or 15 years imo.
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer/fog delete CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB OE weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Sun, Jan-06-2019, 05:29:28 PM   #28
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Thanks for the info bud
Old Sun, Jan-06-2019, 05:57:12 PM   #29
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Welcome...
Old Sun, Jan-06-2019, 08:03:06 PM   #30
neopolymath
neopolymath's Avatar
Reputation: 0 neopolymath is on a distinguished road
I agree. I would go as far as to say that a street driven car is fine removing the fan and solely using the aux fan. In fact, that is what I did last year in GA in the summer. No change in operating temps. I did this in my M roadster as well which has bad airflow design honestly (as is common practice with those cars).
Jump to top neopolymath is offline   Reply With Quote
Discussing Electric fan upgrade in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
