Old Tue, Jun-01-2010, 04:07:52 AM   #61
theBeachBoy
Reputation: 0 theBeachBoy is on a distinguished road
235/35/19, circumference: 80.0"
and
265/30/19, circumference: 79.4"
245/35/19, circumference: 80.9"
and
275/30/19, circumference: 80.1"
wouldn't a 235 front be better suited with a 275 rear? 80.0 vs 80.1
I guess since so many people have 245 and 275 the difference is not problematic for the DSC.
Jump to top theBeachBoy is offline   Reply With Quote
Old Mon, Jun-14-2010, 06:14:29 PM   #62
Pyrex
Pyrex's Avatar
Reputation: 0 Pyrex is on a distinguished road
United Nations
Im Glad I found this thread...
Currently Im running 235/35/19 up front and 255/35/19 rears, all on staggered rims.
I think my rear tire size is affecting my DSC making it light up when (coming on/off ramps or taking freeway curve left/right at high speeds).
02 E46 M3
Past Rides: 97 Titanium E36 M3, 97 Titanium E36 M3 Dinan
Jump to top Pyrex is offline   Reply With Quote
Old Mon, Jun-14-2010, 06:17:35 PM   #63
Pyrex
Pyrex's Avatar
United Nations
I had 235/35/19 front and 275/30/19 rears before with no DSC issues.
02 E46 M3
Old Mon, Jun-14-2010, 06:51:15 PM   #64
MY02M3DINAN
MY02M3DINAN's Avatar
Reputation: 0 MY02M3DINAN is on a distinguished road
Thanks to this thread, I just purchased a pair of Conti Extreme Contact DWS size 235/45/18 to match the same tires I have in the rear sized 265/40/18.
Both tires have the exact revs per mile, and now my DSC does not kick in until I am WAY into the fun zone!
Woo hoo!!!!
2002 TiAg M3 Cabriolet
Dinan S-M3 Kit
{Throttle Bodies/CAI/MAF/Stage 4 software}
Dinan Strut tower brace & Front sway bar
Auto Solutions SSK
UUC Motorwerks "Rasp-X" mid-pipe
Urethane RTAB's/FCAB's/RSM's
Hawk HPS Brake Pads
CDV delete
V1 Hardwired
THIS CAR IS NOW FOR SALE!
Jump to top MY02M3DINAN is offline   Reply With Quote
Old Thu, Sep-16-2010, 11:51:24 PM   #65
Elramos
Reputation: 0 Elramos is on a distinguished road
The question that was asked multiple times in this thread with no real answer being given is whether 245/275 is better or 245/285?
It seems that the circumference difference between 245 and 285 is less, however going 245/285 means you have taken the relative stagger to 40mm instead of 30
Can we can get a more definitive answer here please?
Current Ride: 05 M3 ZCP IB/Cinnamon 6MT
Previous Ride: 08 E90 335
Jump to top Elramos is offline   Reply With Quote
Old Fri, Sep-17-2010, 01:17:33 AM   #66
ILLuSioNz X
Built, not bought
ILLuSioNz X's Avatar
Reputation: 0 ILLuSioNz X is on a distinguished road
great thread, and good info as usual obioban.
-Chauncey
2003 E46 M3 COUPE
Engine/Transmission: "Bolt-on's"
Wheels/Tires: 18 TE37SL & Falken RT615K
Suspension: TRM Coilovers 780F/895R|OEM Front & Turner Rear Reinforcement Plates|RE Rear Spring Perch Reinforcement|GC Race FCABs|GC Monoball RTABs|Godspeed LCAs|Turner Monoball Upper CAB|Turner Sway Bars|Turner Subframe Reinforcement (installed by Coinage)|Turner Solid Subframe, Differential, Motor and Transmission Mounts
Braking: Rotora 4-Piston Calipers|S/S Lines|Ate Dot4|Powerslot Rotors|Ferodo DS2500 Brake Pads
The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS)
Jump to top ILLuSioNz X is offline   Reply With Quote
Old Fri, Sep-17-2010, 01:19:46 AM   #67
I'd go with 245/275.
Increasing the amount of stagger is the opposite of good
FS: Custom Imola leather/alcantara steering wheel, with imola centering stripe
Old Thu, Sep-23-2010, 09:45:36 PM   #68
eshaun
RATEDM
eshaun's Avatar
Reputation: 0 eshaun is on a distinguished road
great thread...what are your thoughts on 265/35/19 in the rear on a csl/zcp wheel?
Been running the usual 245/35/19f, 275/30/19r combo the last few yrs on OEM CSL's and as I'm due for replacing the rears shortly considering what this would do for handling/ride quality given the increasingly poor condition of roads around SF area these days. Just think a bit more meat in the rear sidewall would help from the quality perspective since these wheels are mainly used on the street. For the front id keep the same sizing. Ive run ps2's, T1R's, and currently the RE050A pole positions. Considering the RE-11's next to try something new...
So id go to running a 245/35/19f & 265/35/19r...and of course when the fronts wear out id pick up another pair of RE-11's for that too.
|| www.eshaun.com ||
Jump to top eshaun is offline   Reply With Quote
Old Fri, Sep-24-2010, 02:02:08 AM   #69
ILLuSioNz X
Built, not bought
i have a question:
i'm planning on running a square set up of rear oem 19" rims, because the concavity just looks great. my question is, will 245(currently on my front) fit the oem 19" rims, without being too stretched? the tires are toyo t1r if that helps, and also, are our 19" rear rims 9.5" or 9" ?
-Chauncey
2003 E46 M3 COUPE
Old Fri, Sep-24-2010, 01:17:57 PM   #70
I'd stick with the recommended 265/30/19.
Originally Posted by ILLuSioNz X View Post
i have a question:
It's only 1 cm off 255, I think you'd be okay. I think concavity is a dumb reason to run rear wheels in the front, though...
e46, sizing, thread, tire
Discussing e46 M3 Tire Sizing Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
