Old Tue, Jul-12-2016, 10:12:45 AM   #11
rovert604
rovert604's Avatar
Default '05 SMG M3 Wouldn't Shift Into 6th at low speed?
SMG allows you to upshift once you've hit 1500 when slowly accelerating on level ground or on a decline.
I always cruise at high gear when I don't need to do any moderate to hard acceleration. Fifth or sixth are happy increasing speed at 2000RPM when you're not asking too much.
I did that for the life of my ZHP's M54B30 engine until it was totalled at 175,000 miles. That engine was a freak even at that high mileage. It would launch from a stop aggressively and never did it miss any spark fire.
If the S54 feels/sounds like it's struggling then I'll downshift. Otherwise I'll cruise anywhere under 10% throttle position. My normal 40% city/40% suburbs/20% highway mileage is 22MPG. Sometimes I'll hit over 30MPG in the city if it's 2am and I get all greens. The most I've got is 34MPG on a straight 50-60MPH highway for two straight hours.
--Trevor in 604--
Vancouver, BC, Canada
Old Wed, Jul-13-2016, 03:33:26 PM   #12
nascar_acj
nascar_acj's Avatar
Reputation: 0 nascar_acj is on a distinguished road
Default Re: '05 SMG M3 Wouldn't Shift Into 6th at low speed?
Originally Posted by idriveastick View Post
Sorry, I meant no offense by "he." I simply meant it as "person," "they," "the owner," etc.
No offense taken! Just thought I'd point it out that it may be user error on my part, which it was.
Jump to top nascar_acj is offline   Reply With Quote
Old Wed, Jul-13-2016, 03:36:09 PM   #13
nascar_acj
nascar_acj's Avatar
Same here. I just feel it out. If it feels bogged down, i downshift.
I get excellent gas mileage in 6th when I'm just cruising on a trip down back roads. Average around 28-34 mpg when I've watched the gauge and confirmed it by doing the math. Pretty sweet that these cars are capable of that.
Old Wed, Jul-13-2016, 04:08:45 PM   #14
idriveastick
Reputation: 0 idriveastick has disabled reputation
What gauge are you talking about?
Jump to top idriveastick is offline   Reply With Quote
Old Wed, Jul-13-2016, 09:19:01 PM   #15
Jazzkat
Reputation: 0 Jazzkat is on a distinguished road
My assumption would be gas gauge. Not sure if eyeball mileage is more or less accurate than butt dyno hp rating...
Jump to top Jazzkat is offline   Reply With Quote
Old Wed, Jul-13-2016, 09:58:54 PM   #16
BTB
BTB's Avatar
lol
I always assume my gas mileage, even if I calculate it from trip odo and gallons put in at fill up, is slightly optimistic. With the high-reading speedometers on these cars, how can we get a true gas mileage rating?
My Journal
Old Fri, Jul-15-2016, 07:32:00 PM   #17
rve
In ///M we trust.
rve's Avatar
Reputation: 0 rve is on a distinguished road
Bulgaria
It's not only the engine rpm that matters for upshifting. The SMG also uses a g-sensor for many of it's functions. You should be able to upshift at1500rpm on a flat road but on a steep uphill it won't let you upshift bellow 3000rpm.
The throttle remains in "Sport" mode, the DSC is Off and the smile just gets wider... and wider...
Jump to top rve is offline   Reply With Quote
Old Fri, Jul-15-2016, 07:40:20 PM   #18
idriveastick
Very interesting. Is this documented anywhere?
Old Sat, Jul-16-2016, 06:27:15 AM   #19
rovert604
rovert604's Avatar
I've never read anything this far. I just know that stuff from experience. It's a smart system knowing and allowing when to upshift.
--Trevor in 604--
Old Sat, Jul-16-2016, 04:15:48 PM   #20
icecream
Registered Apples
icecream's Avatar
Op, maybe you were on an incline, at that speed and gear it would deny shift. If no cog light came on I would not worry about it.
The smg will only deny a shift if it will stall or cause excessive load on the drivetrain. In other words, if you command a shift like you would driving a manual, you will have no problems ☺
smg, transmission
Discussing '05 SMG M3 Wouldn't Shift Into 6th at low speed? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
