Old Wed, Sep-22-2010, 02:37:59 PM   #1
zahbaker
Reputation: 0 zahbaker is on a distinguished road
South Africa
Default SMG Gearbox Problem-Please help
I drive a 2003 E46 M3 SMG. I recently replaced the clutch kit. I then went on vacation, while on vacation driving the car, the gear indicator started to flash 4th gear. The car then stalled, I then got a BMW mechanic to come out. The car refused to select any gears. The car also would not rev up. I then got a new clutch kit and replaced the one that was fitted in the car, the same problem persists. The car will not select any gears. The error is Fault code (048) 30 Gear cannot be engaged (OBDII: P1756)
I am unable to train or bleed the clucth. I can clear the fault but the moment I turn the ignition back on, the error code returns. Please can somebody assist as I am being charged by the day(Storage and maintenance fees).
Thanx in advance, your help is highly appreciated.
Jump to top zahbaker is offline   Reply With Quote
Old Wed, Sep-22-2010, 02:44:43 PM   #2
kevinzz
Reputation: 0 kevinzz is on a distinguished road
My car refused to go in gear one day, I was told that my clutch was done, so my shop replaced the clutch. But that didn't fix the issue. They ended up blaming the SMG actuator, and replaced it. Now my car shifts fine.
If you hear the SMG pump prime, I'd say ask them to check out the actuator..
2003 SMG Individual NightBlue, beige individual leather, AC handbrake lever, AC pedals, AC front lip, CSL trunk lid, CSL carbon fiber rear diffuser, black kidney grills, black side gills, HID fog, CSL rims, megan racing coilovers, front camber plates, AC tower bar, SS header, SuperSprint race x pipe, Borla muffler, Full carbon fiber intake (same as gruppe M), AA software, Powerflex FCAB, RTABs, RE RSM, Stoptech Stage 2 brake kit, TMS Rear Camber Arms
Jump to top kevinzz is offline   Reply With Quote
Old Wed, Sep-22-2010, 02:51:01 PM   #3
cntrvrsy
44
cntrvrsy's Avatar
United Nations
I wish I was an SMG guru and had solid answers for you. You can try reading through this thread http://www.m3forum.net/m3forum/showthread.php?t=231113 and the attached .pdf file. It sounds like it could be the Gearbox Actuator but again, I'm not expert and am just guessing.
edit: lol, I was typing as kevinzz posted the same guess
sig engineered by Fcukupayme
Jump to top cntrvrsy is offline   Reply With Quote
Old Wed, Sep-22-2010, 02:55:40 PM   #4
zahbaker
South Africa
Thanks Guys, I will try replacing the actuator sensor. Will keep you posted. Anybody have a actuator sensor for sale?
Old Wed, Sep-22-2010, 04:14:54 PM   #5
chalaka
Reputation: 0 chalaka is on a distinguished road
Taiwan
after you replace the clutch kit.. did you use the GT1 to reprogram the system?
just wondering ... didn't see you mention that in the post ..
if so, this might be the problem?
Jump to top chalaka is offline   Reply With Quote
Old Wed, Sep-22-2010, 04:24:55 PM   #6
zahbaker
South Africa
Hi, yes the BMW technician did use GT1 to reprogram. The strange thing is that the program will clear the fault, once the ignition is turned on the fault reappears. At this stage, GT1 cannot bleed, or retrain the clutch. No gear will slect. The fault remains with error code (048) 30 Gear cannot be engaged (OBDII: P1756)
Old Wed, Sep-22-2010, 07:30:46 PM   #7
rve
In ///M we trust.
rve's Avatar
Reputation: 0 rve is on a distinguished road
Bulgaria
It could be something much simpler like the salmon colored relay (PN: 12631742690) for example. I would check that first because it's known to fail, it could lead exactly to the problem you have (gear can not be engaged) and it costs just a few bucks. Also, since you get the fault code each time you turn the ignition on sounds like it's a rather software/electrical problem than mechanical.
The throttle remains in "Sport" mode, the DSC is Off and the smile just gets wider... and wider...
Jump to top rve is offline   Reply With Quote
Old Thu, Sep-23-2010, 07:13:25 AM   #8
zahbaker
South Africa
Thanks for that, it was the first thing I swopped out, the problem still persists.
Old Thu, Sep-23-2010, 08:12:04 AM   #9
DirtyM
Reputation: 0 DirtyM is on a distinguished road
Look into the compression spring as well. Mine was only related to 3rd 5th and 6th shifting above 3k or so but, I did get the same code p1756.Being as how yours is affecting all the gears I'd say maybe the gear sensor on the back of the trans as well.
Jump to top DirtyM is offline   Reply With Quote
Old Thu, Sep-23-2010, 08:22:38 AM   #10
zahbaker
South Africa
Thanks, I will ask the engineer to have a look.
gearbox, problemplease, smg
Discussing SMG Gearbox Problem-Please help in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
