Old Fri, Apr-24-2009, 07:18:56 PM   #11
Fastdog911
Fastdog911's Avatar
Reputation: 0 Fastdog911 has disabled reputation
There is one more tube that none of the books talk about. This is a small oil bypass tube that is connected to the bottom of the intake and it is near the back of the box. Once you unbolt the IM you can lift it up just a bit to try to access this tube. Just pull it down the best you can and to install you will just push it back up until it clicks. Small hands on this are a real help. The shot with the intake upside down you can see how far back this tube sits in relationship to the other tubes which you can see from the front of the intake. This one caught me a bit by suprise.
[IMG]2002 SMG, Topaz Blue, BHS pulleys, all options. UUC Exhaust, GC Sway bars, SS lines, BHP Pads F1 paddles, GSP brake pedal, Huber Optik 20%, Iforged rims and a bunch of other things.. Sold
1970 911T Tangerine
1972 911T Albert Blue
1970 911E Ossi Blue
Jump to top Fastdog911 is offline   Reply With Quote
Old Fri, Apr-24-2009, 07:29:10 PM   #12
Fastdog911
Fastdog911's Avatar
Now it is clamp time. For this I will use my clamp photo and on that photo you will see there are four "bumps" on the clamp. Going from left to right.. bump #1 does not come into play. Bump #2 is the part of the clamp that does the latching. There is a smaller bump that sits underneath it to make this connection. Bump #3 and Bump #4 are where you put your tool on. Act like bump #3 is fixed. Bump number #4 moves and you will be pinching bump #3 and #4 to move the clamp together. You will also use these two bumps to remove the clamp as well as install the clamp. The way the clamp is made it allows you to preset the clamp on the intake rubber gasket so they are already in place when you preinstall them on the intake for mounting. I know that might not make much sense and please if anyone can explain better please do so. After you have the clamps removed it is time to start to wiggle the IM off the throttle bodies. just try to wiggle it from side to side before you start pulling it right off ... once you get it going then the intake will come off in one section. For the SMG guys.. you will have fluid drips and leaking from the hose and the connetion point so have something laying around to keep your engine bay clean and your floor. At this point the unit is off and you can now do whatever you want with the IM. I used a lot of Simple Green to soak and clean the inside of the box and a lot of paper towels to clean off the horns etc.. Once you have box ready to install you will just do the opposite of how you took it off to install it. I used a very light mixture of liquid soap and water on the inside of the rubber gaskets so the intake would slide on to the throttle bodies. I also had to remove the one rail that was in the way for me to get the clamp tool on and that took a few extra minutes. Before you bolt the box back on make sure you get the small oil bypass tube to click back into the IM. I would do that before you bolt it back down. All of the other tubes go back on the way they came off. On the SMG tube you will be pushing the main tube back on to the fitting and then bringing the clip downwards until you hear it click and that will make the seal for the SMG fluild which in this case is PENTOSIN CHF 11S which you can find at the dealer, it is around $25.00 per bottle. Fill fluid tank back up to the normal level. Hope this helps.. On the first time doing it from start to finish it took around 1- 1.5 hours.. it is messy, tight working conditions and you have to allow for the time it takes to remove the airbox, cabin air box thing etc...
1970 911T Tangerine
1970 911E Ossi Blue
Old Fri, Apr-24-2009, 08:03:34 PM   #13
Fastdog911
Fastdog911's Avatar
While I was in there I cleaned up the engine bay and also the throttle bodies as they were really dirty. I put some plastic sheeting over the tubes so they would not leak all over the engine bay as I gave it a detail while I was in there..
1970 911T Tangerine
1970 911E Ossi Blue
Old Fri, Apr-24-2009, 08:14:50 PM   #14
USM17N
USM17N's Avatar
Reputation: 0 USM17N is on a distinguished road
United Kingdom
thanks mate for the write up, going to be attempting to replace my starter soon and was looking for a DIY on removing the IM.....
Jump to top USM17N is offline   Reply With Quote
Old Fri, Apr-24-2009, 08:34:53 PM   #15
GRKM3
GRKM3's Avatar
Reputation: 0 GRKM3 is on a distinguished road
Next step, replace with VFE manifold and install SC.
SOLD2003 Steel Gray Metallic M3 - Imola Red Interior - SMGII - Premium - HK Sound - NAV - BT -Sirius
Mods :VFE Stage 2 SC, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe,TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R Brakes, OEM CSL Roof, VCSL D/S Carbon Trunk, diffuser and bumper, Armrest Delete, carbon mirror shells, OEM LED tail lights, BBS CH, Alcantara steering wheel, Armrest delete, Valentine V1, Laser Interceptor...
Current ride: 2015 F32 435i xDrive with PPK
Jump to top GRKM3 is offline   Reply With Quote
Old Fri, Apr-24-2009, 08:39:01 PM   #16
cntrvrsy
44
cntrvrsy's Avatar
United Nations
Nice write up, thanks!
sig engineered by Fcukupayme
Jump to top cntrvrsy is offline   Reply With Quote
Old Fri, Apr-24-2009, 10:44:21 PM   #17
.333 snubnose
.333 snubnose's Avatar
Reputation: 0 .333 snubnose is on a distinguished road
Keep in mind that the SMG resevoir is a vented system...so try to keep the IM (with resevoir attached) in an upright position, or else you will have hydraulic fluid leaking out of the cap.
Thanks for the write-up
Jump to top .333 snubnose is offline   Reply With Quote
Old Fri, Apr-24-2009, 11:48:23 PM   #18
Mash3
Look out below!
Reputation: 0 Mash3 is a jewel in the rough
Would you say 5 hours is an appropriate time for this, start to finish?
http://www.m3forum.net/gallery/data/522/medium/Willow_.jpg
Forum Member Since 2003.
. . 2004 M3, SG/ IR. 95k miles. Original owner.
Jump to top Mash3 is offline   Reply With Quote
Old Sat, Apr-25-2009, 12:23:09 AM   #19
Fastdog911
Fastdog911's Avatar
I would say 3 hours Mash. I am sure you can do it faster but it is the type of job that you need to take some time on and if you have big hands it would be really hard to do this type of work quickly..your wrist and hands are at funky angles under the IM. It took me 2+ hours to clean up the throttle bodies with carb cleaner and a hour to clean the box out. Dealer didn't have clamps so that was 3-4 days and it took 1 day to find and get the tool to remove the clamps. Dealer did have the Pentosin CHF in stock
1970 911T Tangerine
1970 911E Ossi Blue
Old Sat, Apr-25-2009, 05:17:21 AM   #20
jaffy5150
Reputation: 0 jaffy5150 is on a distinguished road
Nice write-up Fastdog!
I'll just let everyone know that if you need to remove the hose from the SMG reservoir to the accumulator for any reason, be very careful of the red plastic snap ring that's used to hold the hose in the accumulator. You can see the red snap ring in post #8 in the second picture where the hose attaches to the accumulator.
The reservoir hose broke during my supercharger install and when I went to pull the old hose out the snap ring disintegrated. No problem I thought since I needed to buy a new hose. Well, I was wrong. BMW doesn't include a snap ring with the new hose and it's not an item that is sold separately. It only comes with a new accumulator or a new SMG hydraulic assembly.
Also, you can use CV boot clamps for the six hoses that attach from IM to the throttle bodies if you don't live close to a dealer. You can usually pick them up from any auto parts store.
Jump to top jaffy5150 is offline   Reply With Quote
dyi, intake, manifold, removing, smg
Removing intake manifold for SMG, DIY? Fastdog911 E46 M3 (2001-2006) 14 Wed, Jul-27-2016 12:00:05 AM
Help, removing intake manifold.. Jeffxxx E46 M3 (2001-2006) 6 Sun, Jul-04-2010 01:15:54 AM
Help, removing intake manifold.. Jeffxxx Forced Induction (F/I) 1 Mon, May-26-2008 02:24:29 AM
starter problems, removing intake manifold Techno ///M3 E36 M3 (1992-1999) 2 Fri, Nov-23-2007 02:22:02 PM
Removing The VFE Intake Manifold on an E46 M3 jmciver Forced Induction (F/I) 6 Sat, Oct-13-2007 12:17:21 PM
Discussing DYI on removing Intake Manifold on SMG in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
