Old Mon, Feb-16-2015, 11:47:32 PM   #11
ThunderMoose
Default Re: Removing intake manifold for SMG, DIY?
http://www.m3forum.net/m3forum/showthread.php?t=262263
#67 2017 NASA TX TT3 Champion
Old Tue, Feb-17-2015, 12:05:40 AM   #12
hemi8
M Power
Reputation: 0 hemi8 is on a distinguished road
High likelihood the fitting on the SMG reservoir will break when removing the hose, I found it easier to disconnect it at the pump, just be very very careful, push down gently on the red plastic part and slowly pull the hose out. If you need to replace a leaky hose its better to disconnect it from the SMG reservoir when the intake is off, you can flip it over to see what the hell you are supposed to squeeze to release and install.
Mike
2004 SMG M3, carbon black metallic w/cinnamon interior, OEM Euro Headers, Frank Smith engine & CSL SMG tuned, 300rwhp. Original SMG pump died @ 198k. Original clutch died @ 190k. Original rear diff. died @ 200k
Jump to top hemi8 is offline   Reply With Quote
Old Tue, Feb-17-2015, 05:46:41 AM   #13
icecream
Registered Apples
icecream's Avatar
Originally Posted by MPOWERD View Post
Not true! Needle nosed pliers are just as good, if not better than, these pliers.
I purchased a set and they bent on me when trying to install the clamps the first time I reinstalled the intake...
The next time I did it the needle nosed pliers were actually VERY easy to use and more stable when applying force to the clamps to both remove and install...
Much faster as well. It only took me 15 mintues to reattach all six clams the last time using them.
Have to agree with this. Old post but worth restating. Any other tool will likely be too large to fit between the fuel rail and intake anyway. I resorted to the needle nose pliers after fidgeting with a different tool for a wile.
Old Tue, Feb-17-2015, 05:53:44 AM   #14
Feuerbach86
Reputation: 0 Feuerbach86 is on a distinguished road
I used and angled set of needle nose pliers, to help get at 5-6
2002 Silver SMG Cloth No Sunroof... Track Project
2005 Mystic Blue 6MT on Grey... RIP
Jump to top Feuerbach86 is offline   Reply With Quote
Old Wed, Jul-27-2016, 12:00:05 AM   #15
Ken reich
Reputation: 0 Ken reich is on a distinguished road
The 2006 m3 s have clamps , a no-brainer,
Jump to top Ken reich is offline   Reply With Quote
diy, intake, manifold, removing, smg
Help, removing intake manifold.. Jeffxxx E46 M3 (2001-2006) 6 Sun, Jul-04-2010 01:15:54 AM
FS: OEM Intake Manifold off SMG Equipped M3 nismo skyline Parts for Sale/Wanted 1 Fri, Oct-03-2008 12:26:52 AM
Help, removing intake manifold.. Jeffxxx Forced Induction (F/I) 1 Mon, May-26-2008 02:24:29 AM
starter problems, removing intake manifold Techno ///M3 E36 M3 (1992-1999) 2 Fri, Nov-23-2007 02:22:02 PM
Removing The VFE Intake Manifold on an E46 M3 jmciver Forced Induction (F/I) 6 Sat, Oct-13-2007 12:17:21 PM
Discussing Removing intake manifold for SMG, DIY? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
