Old Sun, Aug-23-2015, 01:53:22 PM   #371
s54cabrio
Reputation: 0 s54cabrio is on a distinguished road
Default Re: M5 SMG knob does work 100% in an M3!
Originally Posted by avusbluem3 View Post
Did this about a month ago.
Yes, if you just want night illumination, just wire 4 and 5 to the smg selector switch.
Yes, the wires in the knob are only for illumination purposes.
Oke that sounds like i can even do that job... but where do i wire them in exactly? the pics in the above posts /links are not working anymore
Jump to top s54cabrio is offline   Reply With Quote
Old Sun, Aug-23-2015, 04:30:29 PM   #372
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Man that looks nice!
Old Sat, Sep-05-2015, 11:30:14 PM   #373
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Just finished installing mine. What a difference over the chrome OE knob! It looks and feels so much better! I scuffed up the chrome gator ring with a scotch brite pad to give it the brushed aluminum look, turned out nice. I wired up the illumination, Reverse and Neutral. Drive/Shift lights were too bright at night.
Here is the wiring info if anyone needs it.
SMG M5 Shift Knob
1 = Zone Reverse (GND)
2 = Zone Neutral (GND)
3 = Zone Drive A/S (GND)
4 = Night Illumination (GND)
5 = Switched +12v for Night Illumination
6 = Switched/Constant +12v for zone lighting
SMG2 Control Module
1-(Reverse GND) to 3 (White w/Green stripe)
2-(Neutral GND) to 7 (Yellow w/Blue stripe)
3-(Drive A/S GND) to 8 (Green w/White stripe)
4-(Night Illumination GND) to Brown w/Black stripe (SMG Switch)
5-(Switched +12v) to Grey w/Red stripe (SMG Switch)
6-(Switched/Constant +12v) to 1 of the Red/White wires.
Old Sat, Sep-05-2015, 11:44:46 PM   #374
968951M3
AKA ShapeShifter
968951M3's Avatar
Reputation: 0 968951M3 has disabled reputation
Nice touch with the brushed ring.
Current
03 E46 M3 Cab Carbon Black/Black
Recent Past:
'95 540/6 Schwarz/Schwarz
'95 M3 Cosmos/Schwarz
'89 325ix Diamant Schwarz/Natural
'89 635CSi Schwarz/Silber
'95 525 Touring Schwarz/Schwarz
'86 951 Schwarz/Schwarz
'94 968 Polar Silber/Schwarz
'87 944 Rot/Schwarz
'90 325is Schwarz/Houndstooth
'87 635CSi Diamant Schwarz/Lotus
I love to flap my paddle..
Jump to top 968951M3 is offline   Reply With Quote
Old Sun, Sep-06-2015, 04:03:25 PM   #375
certify
Reputation: 0 certify is on a distinguished road
Malaysia
Looks good...
Does it only works on e60 M5 knob or with all other DCT knobs?
Jump to top certify is offline   Reply With Quote
Old Sun, Mar-20-2016, 03:10:45 AM   #376
Mr. 5
Modder Raider
Mr. 5's Avatar
Reputation: 0 Mr. 5 has disabled reputation
I just did mine and I'm very happy with it.
I have the older instrument cluster that displays "0" instead of "N" and thought that the drive lights go out if you down shift with the knob.
I'd like to clarify that the lights only go out for a split second.
I thought that the lights would go off until the knob was put into a different position.
I love it.
Best 1/4 Mile...11.77 @ 119.9
Best 60-130 9.15 Seconds with 1 shift.
WWW.MR5RACING.COM
Jump to top Mr. 5 is offline   Reply With Quote
Old Tue, Mar-22-2016, 02:40:56 PM   #377
Mr. 5
Modder Raider
Mr. 5's Avatar
I do agree that the +/- is too bright at night but it is perfect in the day time.
Using a pot only will kill the daytime feel.
The best way to go in my opinion is to add a relay combined with a pot (resister if you know the resistance that you want)
The affect that I'm talking about is the same as the led on the speaker button in the center console or the LEDs on the heated seats. When you turn the lights on, the LEDs dim.
We can do the same thing by getting the nighttime illumination wire to trigger the relay, which will change the path to the pot so every time the lights are turned on, R, N, and +/- will dim to whatever settings you like.
WWW.MR5RACING.COM
Old Sun, Apr-10-2016, 02:32:02 AM   #378
pstnq
Reputation: 0 pstnq is on a distinguished road
Poland
I spent almost two hours to figure out which wire is what on SMG module connector, until I found this !! Thank you very much !
Jump to top pstnq is offline   Reply With Quote
Old Mon, Jun-13-2016, 02:54:52 AM   #379
tsegreto
Reputation: 0 tsegreto is on a distinguished road
I found this to be the best way to regulate the amount of light given off by the shifter:
Pick up a 50K-Ohm Linear-Taper Potentiometer (https://www.radioshack.com/products/...ant=5717291717) and splice the wire that you tapped into the 12v connection (Pin 6) and connect the two ends to the potentiometer (either by using crimp on connectors or solder). The adjusting stem is pretty long but it fits. Adjust it to your liking, electrical tape it up and forget about it!
This is much like what user Reach wrote (http://www.m3forum.net/m3forum/showt...=83712&page=20) but with a Radio Shack part number that's more specific - furthermore I found that 100Ω did not not give enough adjustability.
Jump to top tsegreto is offline   Reply With Quote
Old Sun, Dec-24-2017, 12:03:24 AM   #380
tshpark
Reputation: 0 tshpark is on a distinguished road
SMG M5 Shift Knob
SMG2 Control Module
Today, I have finished to install with your wiring guide on my 2004 e46m3conv (smg2? I believe)
However, night illumination only works when I shift up the knob position which is (-) direction. any idea?
Jump to top tshpark is offline   Reply With Quote
100%, knob, smg, work
SMG shift knob replacement alternative, no m5 knob 1baadm3 E46 M3 (2001-2006) 57 Mon, Jan-30-2012 09:19:05 PM
FS: OEM e46 M3 Illuminated shift knob $100 obo m3bmwjohn Parts for Sale/Wanted 0 Sat, Jul-05-2008 11:50:28 PM
100 Best Companies to Work For zeuiax Off Topic 37 Sat, Feb-23-2008 09:08:14 PM
2006's 100 best companies to work for... amstel78 Off Topic 20 Tue, Jan-10-2006 04:22:56 AM
Discussing M5 SMG knob does work 100% in an M3! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
