Old Tue, Oct-31-2017, 03:36:45 AM   #61
not///Mpōrtant
Captain Obvious
not///Mpōrtant's Avatar
Reputation: 0 not///Mpōrtant is on a distinguished road
Default Re: Are there any steering shaft extensions (cabin side) to get the wheel towards dri
I’m ordering one and will report back on slipring use.
Awesome!!! Yeah, keep us updated please.
Though, I'm installing the E46 multifunction sport 3 spoke steering wheel with the Z3 single stage airbag. I was going to have it machined and modified with the stand-offs to mount the slip ring as seen here, http://www.frankies-bmw.com/8series/...s_mf_wheel.php
I wonder how, if at all, it would change this.
-Brian
2003 Titanium Silver SMG Vert.
GSP Pedals, H&R Coilovers, OEM 359M, 3000K Fog Lights.
1994 Schwarz Black E36.
TRM Coilovers, Ground Control anti-roll bars, Treehouse Racing FCAB, SPC control arms, X-Brace, Mason Engineering strut tower brace, Z3 steering rack, Mishimoto aluminum radiator, Zionsville aluminum shroud & expansion tank, Fan Delete Mod, Spal electric fan, Stewart WP, Conforti CAI, Dr. Vanos stage II, Powder Coated valve cover, Stromung catback, MA Shaw carbon fiber GTR hood, MA Shaw front bumper, MA Shaw carbon fiber front splitter, APR splitter supports, VIS carbon fiber CSL decklid, CA Automotive carbon fiber rear diffuser, CA Automotive carbon fiber rear splitters, Smoked lighting, OEM Motorsports door handles, Tilt steering column retrofit, Euro three spoke steering wheel, Pioneer AVIC-N2.
Jump to top not///Mpōrtant is offline   Reply With Quote
Old Wed, Nov-08-2017, 07:09:27 PM   #62
tsmith25
Reputation: 0 tsmith25 is on a distinguished road
Did you get it yet?
Jump to top tsmith25 is offline   Reply With Quote
Old Wed, Nov-08-2017, 09:20:40 PM   #63
Originally Posted by tsmith25 View Post
Did you get it yet?
I paid for it last week. No word on shipping. Hope he’s legit!
Old Thu, Nov-09-2017, 12:05:16 PM   #64
tsmith25
Anybody know if the spline is the same on both ends of the steering column? I am coming up with a contingency plan. The internal spline is harder to machine than the external, so if I could scavenge a steering guibo, and modify it I could potentially design a kit that works by modifying the guibo into an extension. I am thinking it would include a spacer/shroud that we could bolt both halves of the guibo to and a length of spline with a tapped hole where the steering wheel would bolt on. Obviously the spacer/shroud would have to have somewhere to route the wiring.
Last edited by tsmith25; Thu, Nov-09-2017 at 12:07:30 PM. Reason: words in correct places...
Old Thu, Nov-09-2017, 01:52:55 PM   #65
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Sounds to me like hand-extenders would be more practical.
When I see that pic of the extension between the column and wheel (which is a nicely machines piece) I see that (obviously) the distance between the wheel and stalks is also extended.
In my case probably too far as my fingers aren't that long. Indicating would become awkward as I would have the take my hand of the wheel and reach forward to get to the stalk.
So it may solve one problem, it creates another one.
Why no longer steering shaft so the whole column including the stalks and everything is moved forward?
Old Thu, Nov-09-2017, 02:36:20 PM   #66
wgknestrick
Reputation: 0 wgknestrick is on a distinguished road
You are exactly right. I have an aftermarket wheel setup that does moves it forward slightly (but still acceptable) and you notice it right away. Another 1" and it would be more frustrating than the problem it solves.
You have to move the entire column towards you.
Jump to top wgknestrick is offline   Reply With Quote
Old Thu, Nov-09-2017, 02:39:51 PM   #67
wgknestrick
http://www.autohausaz.com/search/pro...IaAmSkEALw_wcB
You can get a little extra length from this piece depending on the "depth" you insert the splines. This piece replaces the rubber guibo with a true universal joint that will never wear out.
Old Thu, Nov-09-2017, 03:33:56 PM   #68
tsmith25
I guess I could get the e34 joint and try what I am thinking using my stock guibo. I have been considering getting one anyway. My plan was to make something similar to the extender that was posted previously using the guibo as a starting point, mostly for the internal spline. I'm not sure if I have the time currently, and our machinist has been a little grumpier than usual lately.
Old Thu, Nov-09-2017, 06:26:58 PM   #69
ItalianM3E46
Reputation: 0 ItalianM3E46 is on a distinguished road
Hello, I'm machining them. Both aluminium and steel parts are ready for spline machining.
Far stalks: most users does not care about it. The advantage of the new driving position is so big that the far lever are a little minus. It takes a few days to get used to.
Somebody in the Fiat 500 Abarth forum fits the bracket in the pic. It's for bicycle use, carbon fiber, 10$ on amazon.
When I've made the first spacer for me, on a Renault Clio RS, I didn't think about manufacturing a kind of "longer guibo joint". Seems a solution. But I'm not sure that the column can be untight from where it sits and pushed out with the whole clockspring/levers/shrouds assembly. It depends on how the column is fixed on the firewall, under the instrument cluster.
Also, pushing out all that assembly, you will notice a big gap between the rear of the levers and the dashboard. It must be filled somehow, for aesthetic reasons.
I don't have an E36 on which check this thing, sorry. I'll take a look on my E46. But let me finish the existing parts first. More than one has already paid for them.
Jump to top ItalianM3E46 is offline   Reply With Quote
Old Thu, Nov-09-2017, 06:49:20 PM   #70
Nate047
Nate047's Avatar
I had a deep dished wheel on my last track car, and yea it was slightly annoying that the turn signal stalks were not in the same place as stock relative to the wheel. But the car wasn't stock... Any mods like this will make the car better in one way and worse in another. In this case the part that gets "worse" is extremely nominal.
Discussing Are there any steering shaft extensions (cabin side) to get the wheel towards driver? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
