Old Tue, May-22-2018, 06:16:55 PM   #1
NolliM3
NolliM3's Avatar
Default Socket Size Transmission Output Flange
What's the size socket for the transmission output flange nut? It's not 30mm...I don't want to make several runs to the store...I need to return the 30mm one to get the correct size which seems to be from my estimate more like 34mm.
Old Tue, May-22-2018, 07:54:59 PM   #2
NolliM3
NolliM3's Avatar
Default Re: Socket Size Transmission Output Flange
It's supposing to be a thin-walled 30mm socket...now to find that!
Old Tue, May-22-2018, 08:53:43 PM   #3
avusblu_e36
Reputation: 0 avusblu_e36 is on a distinguished road
You could shave down the side of your socket with an angle grinder if that's easier
Jump to top avusblu_e36 is offline   Reply With Quote
Old Wed, May-23-2018, 01:29:56 AM   #4
pbonsalb
Beware the torque required to put it back on if you take it off. A non impact socket will more likely fit but an impact can be ground down.
https://www.bimmerforums.com/forum/s...put-shaft-seal
Old Wed, May-23-2018, 01:54:34 AM   #5
JitteryJoe
Amazon is your friend here. I found all my special need sockets there.
Jump to top JitteryJoe is online now   Reply With Quote
Old Wed, May-23-2018, 03:09:48 PM   #6
NolliM3
NolliM3's Avatar
Thank you Phil for sharing...the socket I have is the non-impact one; however, it has six points. I am thinking of skipping the output seal as one can get to it without removing the transmission.
Old Wed, May-23-2018, 03:16:09 PM   #7
NolliM3
NolliM3's Avatar
That's too much work!
I meant where locally.
Old Wed, May-23-2018, 03:40:26 PM   #8
pbonsalb
Now is the time. Why drop midpipe and disconnect DS again? Check local auto parts stores and sears for 30mm 12 point in single socket section.
Old Wed, May-23-2018, 05:37:38 PM   #9
englishtom1596q
englishtom1596q's Avatar
Is yours actually leaking? If not don’t freaking touch it! Most of the time they don’t leak, the selector seal above it does.
If it ain’t broke, don’t fix it
Old Wed, May-23-2018, 05:55:33 PM   #10
pbonsalb
That is one theory. I do a lot of preventative maintenance. But it is true the selector shaft seal is the much more common source of leaking.
Discussing Socket Size Transmission Output Flange in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
