Old Fri, Oct-07-2016, 11:38:26 PM   #1
LuckyM301
LuckyM301's Avatar
Reputation: 0 LuckyM301 is on a distinguished road
Default E36 1995 M3 - stomp code 1281 after head gasket replacement
So after a head gasket job i am getting code 1281 - Control Unit Memory Supply
I have:
swapped ecu out of a good m3 with dinan chip and it started right up and sounded great but the code came back
the code doesnt come on in the other m3
alternator has 14.2 volts while running
the battery has 13.3-13.8. is a bad ground causing this? its a new battery(2/16)
pulled the main ground strap and got .1 - .2 ohm reading which i got from a different 0 gauge wire i had laying around so thats good
really stuck and not sure if anyone has seen or experienced this code
i read its usually caused by low voltage but the code wasnt on before the head gasket job so what am i missing??
Thanks for reading
Jump to top LuckyM301 is offline   Reply With Quote
Old Sat, Oct-08-2016, 04:31:25 PM   #2
NolliM3
NolliM3's Avatar
Default Re: E36 1995 M3 - stomp code 1281 after head gasket replacement
I have:
Thanks for reading
I can tell you this one of the weirdest code I have ever seen after just having the car down for six months because I am still not sure what's the cause. Or, my solution just doesn't make sense. Since your car starts, at least it's not as bad as mine was. Also, most of the cars I have seen affected are 95's.
After changing DME and going through a whole drama of changing crank position sensor, camshaft sensor, battery, starter, and negative cable only to find none of those was the problem. Then, spent another two months getting DIS, computer with a REAL serial port and installing, learning the software only to find out DIS won't diagnose the car because the virtual machine doesn't detect that pin 26 of the DME is indeed connected to the B+ terminal and therefore to the battery. Then, INPA was of no use as there was no DME3.3.1 S50 3.0 U.S...only just DME3.3.1 M50 2.5/DME331K20.prg.
So, after several start attempts, the car engine flooded with gas that washed off the oil on the cylinder wall resulting in no compression and damaging the fuel pressure regulator. I had to take out the spark plugs and pour a tea spoon of oil and change the fuel pressure regulator.
In the end, the solution was changing the hose from the idle control valve to the boot all because it had small splits at the top of the hose towards the boot.
All I can say is happy hunting and here's a list of others who have had the same code...most won't have a solution...in your case, you can focus on the ones where the car started.
This one from here said cleared by driving , then got crankshaft 1243, changed that and still got 1243.
http://www.m3forum.net/m3forum/showthread.php?t=135557
This one at least confirmed it was a bad ECU...still leaves one in the dark at the end of the post.
http://www.m3forum.net/m3forum/showthread.php?t=33612
This one claims changed the battery after getting the code 1281, car runs good but still gets the same code1281
This one has no reply.
http://www.bimmerfest.com/forums/sho...d.php?t=244684
This one changed lots of parts and in the end the vanos solenoid.
http://www.r3vlimited.com/board/showthread.php?t=241969
This one claimed it could be the crankshaft position sensor...didn't follow to confirm.
http://m3pink.blogspot.com/2011/05/n...ump-still.html
This had good info but not the resolution
http://www.mnautox.com/forums/showth...e-E36-M3-Savvy
This one never posted a solution either
http://www.stlbmwcca.org/wwwboard/vi...php?f=4&t=6196
Aeronaut even had the code...didn't stated the solution.
http://www.m3forum.net/m3forum/showt...=438712&page=2
This one got no reply
http://www.m3forum.net/m3forum/showthread.php?t=40605
This one replaced the crankshaft sensor and he stated problem still persist...even getting 1243
This one offered some suggestions that seem more of a witch hunt.
http://www.m3forum.net/m3forum/showthread.php?t=429152
This one gets the code 1281 and car runs good
http://www.m3forum.net/m3forum/showthread.php?t=186242
This one had similar problem to mine ...just never stated what resolved the issue.
http://www.m3forum.net/m3forum/showthread.php?t=366251
Then others on Bimmerfest still with no resolution
http://www.bimmerfest.com/forums/sho...d.php?t=655714
The sad part is changing the DME doesn't resolve the code 1281 issue...in the end a BMW dealer claimed the DME died.
http://www.bimmerfest.com/forums/sho...d.php?t=152995
Old Sat, Jun-03-2017, 12:20:11 AM   #3
gelb3
gelb3's Avatar
Reputation: 0 gelb3 is on a distinguished road
Exactly...Oh hey my problem is resolved. Good luck to the rest of ya. Oh by the way we all own a Subaru now!
I have that code for a week now. Car is a 95 starts and runs fine except for a check engine light and now for the last 2 days starts bucking and jerking during gear changes for a minute and never does it again during the drive. I thought it was the wife's driving so I wen and picked up the car from her work and sure as hell it did it to me. I took a really long way home as to not get stranded on the highway somewhere. Anyone with any real resolution to the problem please say something. I get that its a mystery code but I cant afford to start throwing money at this thing. I started throwing money at the same code 12 yrs ago and found that it was some Italian tuned chip in the dme. It's had a Turner Motorsports chip in ever since and the code went away. Not a single issue in 12 yrs and now all of a sudden this. When I say throw money at it ...I replaced everything electrical. I have a garage full of parts that are probably perfect. except a DME,Alternator,Mass flow sensor.
1995 Dakar M3
///M Mods & Maintenance = all my money
Jump to top gelb3 is offline   Reply With Quote
Old Sun, Jun-04-2017, 11:12:49 PM   #4
NolliM3
NolliM3's Avatar
May be it's time for a new turner chip! Get a spare DME and try that to see whether that resolve your issue.
Old Sun, Jun-04-2017, 11:15:03 PM   #5
NolliM3
NolliM3's Avatar
Wondered whether the OP ever resolves their issue...are you still here on the forum?
Old Thu, Jun-15-2017, 05:30:54 AM   #6
LuckyM301
LuckyM301's Avatar
sorry just saw this
it was a friends car and we got it to go away for a day after we soldered some questionable wiring from the previous owner fixed it for a bit and now comes back on and off
he lives about an hour away so until we dive deep we haven't touched it
Sent from my SAMSUNG-SM-G890A using Tapatalk
Old Thu, Jun-15-2017, 05:32:54 AM   #7
LuckyM301
LuckyM301's Avatar
we swapped DMEs from my car and basically narrowed it down to electrical problems on his specific car though
Discussing E36 1995 M3 - stomp code 1281 after head gasket replacement in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
