Old Fri, Mar-11-2011, 08:53:31 AM   #11
Got_S54?
Got Lip?
Got_S54?'s Avatar
Reputation: 0 Got_S54? is on a distinguished road
Default Re: Clutch slip in 1st gear
I have the slight slip problem too only when starting from 1st when the car has just been started and is still cold. Once the car is warmed up from being driven, no slippage occurs whatsoever. 2002 with 76k miles and no CDV.
If there was a slight leak in the rear main seal, could a bit of oil make it to one side of the clutch disc and cause it to slip a bit until friction burns it off?
05 TT 225 Quattro - APR Stage 1|FK coilovers|Megan Adj.Cont.Arms|APR catback|15F/20R spacers|OEM ALMS 18's - daily
02 M3 AW/IR - sold but not forgotten
Jump to top Got_S54? is offline   Reply With Quote
Old Fri, Mar-11-2011, 02:51:27 PM   #12
AshsBimmer
AshsBimmer's Avatar
Reputation: 0 AshsBimmer is a jewel in the rough
I was thinking the same thing..
Jump to top AshsBimmer is offline   Reply With Quote
Old Mon, Mar-14-2011, 03:10:20 AM   #13
mmm def
Reputation: 0 mmm def is on a distinguished road
Almost feels like the clutch is glazed right? it kind of grips, and then it really grips. If you are on a hill, you'll really notice.
Jump to top mmm def is offline   Reply With Quote
Old Mon, Mar-14-2011, 03:21:31 AM   #14
Got_S54?
Got Lip?
Got_S54?'s Avatar
Yup you described it perfectly. And it only happens once for me-the very first time I clutch out of 1st gear for the day.
Old Fri, Jan-27-2012, 10:12:58 PM   #15
chris5
Reputation: 0 chris5 is on a distinguished road
i think i got this too w/ the clutch engagement coming out of first. i also have what appears to be a rear main seal leak according to the mechanic that did the PPI on my car.
Jump to top chris5 is offline   Reply With Quote
Old Mon, Mar-12-2012, 11:28:48 PM   #16
MMMNick
Reputation: 0 MMMNick is on a distinguished road
Has anyone figured what is causing this? It has just started happening to me, usually only when cold, and only once, but not in reverse. Only 35k miles and just out of warranty!
Jump to top MMMNick is offline   Reply With Quote
Old Tue, Mar-13-2012, 12:27:20 AM   #17
Got_S54?
Got Lip?
Got_S54?'s Avatar
Since I posted a year ago, I still occasionally have this. Once engaged, the clutch never ever slips. And based on the fact that I do have a very tiny rear main seal leak, Im sticking to my theory that the slight rms leak causes it to slip until friction burns off the oil.
Check for wetness where the tranny bolts onto the engine on your car. If it looks a bit wet, this is probably whats happening with yours too. Let us know.
1st, clutch, gear, slip
SMG Clutch feels like it slips in 1st gear.. RaceMX-M3 E46 M3 (2001-2006) 69 Fri, Nov-10-2006 03:24:18 AM
1st gear shudder (clutch slip?) loosenut E46 M3 (2001-2006) 7 Sat, May-06-2006 07:58:25 PM
Hard to get into Reverse / 1st gear after clutch-stop. NYM3Jack E36 M3 (1992-1999) 5 Mon, Jun-13-2005 09:45:53 PM
SMG clutch slip 1st to 2nd dskippy888 E46 M3 (2001-2006) 21 Fri, Feb-25-2005 11:41:14 AM
Clutch Stop in 1st Gear 97M3CCC E36 M3 (1992-1999) 5 Fri, Jun-20-2003 08:35:10 PM
Discussing Clutch slip in 1st gear in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
