Old Fri, May-23-2014, 10:51:24 PM   #1
marinm3
Reputation: 0 marinm3 is on a distinguished road
Unhappy DCT failure - Gear light comes on it loses use of 1,3,5,7 and R gears
Hi All,
I have a 2009 M3 DCT. Every once in a while, the gear indicator light comes on and the car only works in 2, 4 and 6th gear...all others are gone, inc. reverse. I restart the car and they are all back. The SA says maybe a clutch, maybe whole tranny, he has never seen it before. Yeah, right.
Anybody else have this issue. I found one guy on these boards that did, but there was no resolution. Nobody seems to come up with a real answer. Also, does anyone have the solution to the "tin can" rattle from rear pass side wheel (very common, but nobody found a real fix) No, it is not a pebble in my dust shield.
Anyway, I dont want to dump 4K into a clutch, just to find out that it now needs a 13K tranny.
Any help appreciated. The thing has 45K on it, so a clutch blowing out seems pretty rare, much less a whole tranny. The outer clutch controls those gears, so i am thinking more electrical, as it only happens randomly and sometimes, not for a week.
Please help if anyone knows. Thanks a ton.
Last edited by marinm3; Fri, May-23-2014 at 10:53:22 PM. Reason: adding "tin can" question too
Jump to top marinm3 is offline   Reply With Quote
Old Tue, May-27-2014, 05:57:58 AM   #2
Bashar368
Bashar368's Avatar
Reputation: 0 Bashar368 is on a distinguished road
Default Re: DCT failure - Gear light comes on it loses use of 1,3,5,7 and R gears
Happened to my brother
Did software updating clutch blah blah blah. End it up replacing the entire tranny. Car only had 2 k miles
God luck bro
2005 IB ZCP - AA 2 HKS - Work Brombachers - 500+ RWHP 91 Octane
Jump to top Bashar368 is offline   Reply With Quote
clutch, dct, gears, transmission
Discussing DCT failure - Gear light comes on it loses use of 1,3,5,7 and R gears in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
