Old Mon, Oct-01-2012, 10:53:31 PM   #1
DrGSXR750
Reputation: 0 DrGSXR750 is on a distinguished road
Default SMG slave cylinder replacement
What's up guys? Has anyone done a slave cylinder replacement on an SMG? I'm a fairly competent mechanic(I swapped a few engines/trannys) with a full compliment of tools. Is this something I can tackle? Also, I assume you need to bleed the clutch system so do I need to borrow a Autoenginuity or GT3 or something? Thanks for the help!!!
Brian
Jump to top DrGSXR750 is offline   Reply With Quote
replacement, slave cylinder, smg clutch
Discussing SMG slave cylinder replacement in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
