Old Fri, Dec-17-2010, 05:04:42 PM   #1
d3x74
apple pie shtn skip
d3x74's Avatar
Reputation: 0 d3x74 is on a distinguished road
Default Replacement front turn signal socket/insert
Any one know the part number for the black socket/insert on the front turn signal?
It is the red circle part. The two wires that feed into it are loose and the notch that holds the cable to the bulb socket is broken too.
Been looking at RealOEM and the closest harness/connector I could find:
http://www.realoem.com/bmw/showparts...83&hg=61&fg=10
And this:
http://www.realoem.com/bmw/showparts...37&hg=61&fg=10
I don't feel like spending $500 for an entire new wiring harness...
General wiring electrical section:
http://www.realoem.com/bmw/partgrp.d...id=47714&hg=61
Jump to top d3x74 is offline   Reply With Quote
Old Mon, Apr-11-2011, 09:36:11 PM   #2
kuul_guy
CK
Reputation: 0 kuul_guy is on a distinguished road
Default Re: Replacement front turn signal socket/insert
Were you able to find any thing for this? Just wanted to check as I am looking for the same thing right now....
2005 Silver Gray ///M3 6speed MT
Jump to top kuul_guy is offline   Reply With Quote
Old Tue, Dec-06-2016, 02:25:33 AM   #3
Kdubski
Kdubski's Avatar
Was this ever discovered? Can anyone help? I am facing the same dilemma
Jump to top Kdubski is online now   Reply With Quote
Old Tue, Dec-06-2016, 03:09:56 PM   #4
Pnick
Pnick's Avatar
Have you tried just going to a junkyard/recycler, cannibalize that part and splice the wires from that to the dead-ended cable you have in the car?
Old Tue, Dec-06-2016, 10:03:19 PM   #5
Kdubski
Kdubski's Avatar
I have not, will any e46 work?
Old Tue, Dec-06-2016, 10:38:51 PM   #6
lmtfi
lmtfi's Avatar
Isn't the part number imprinted into the black plastic?
front, replacement, signal, socket or insert, turn
Discussing Replacement front turn signal socket/insert in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
