Old Thu, Mar-25-2010, 06:11:10 PM   #11
Function7
Function7's Avatar
Reputation: 0 Function7 is on a distinguished road
Unlike the 6-speed clutch, the SMG clutch uses the SMG fluid (Pentosin CHF-11s) to actuate the clutch. You do not need to flush the clutch if you're flushing the brakes on an SMG equipped car.
Function7 Engineering
Queen Creek, AZ
Jump to top Function7 is offline   Reply With Quote
Old Thu, Mar-25-2010, 06:14:19 PM   #12
PIR3lly
PIR3lly's Avatar
Reputation: 0 PIR3lly is on a distinguished road
Netherlands
Awesome!
That's what I wanted to hear. Thanks a lot
Jump to top PIR3lly is offline   Reply With Quote
Old Thu, Mar-25-2010, 08:29:29 PM   #13
.333 snubnose
.333 snubnose's Avatar
Reputation: 0 .333 snubnose is on a distinguished road
Originally Posted by PIR3lly View Post
Not the smg hydraulics, but the clutch.
As previously stated...same thing.
Clutch on a M3 uses the same fluid as the brakes (at least, that's what I've been told)
And while we are on the topic of 6MT...
although the clutch cylinder uses the same brake fluid, is it really necessary to bleed both together? How is it different than any other manual tranny? (other than convenience )
Not trying to bust your balls...just wondering if the M3 6MT clutch fluidics are unique.
Jump to top .333 snubnose is offline   Reply With Quote
Old Thu, Mar-25-2010, 08:40:52 PM   #14
Function7
Function7's Avatar
It's common in manual cars to have the clutch and brake circuits share the same reservoir. All you need is one hose and the manufacturer saves on one more part for the car.
You really don't need to bleed the clutch when you're bleeding the brakes. It's a completely different master cylinder. If, however air gets into the clutch line, then bleeding it is necessary.
When flushing (changing) the brake fluid, flush both of them since you don't want any of the old fluid in the system.
-A
Queen Creek, AZ
Old Thu, Mar-25-2010, 09:50:56 PM   #15
.333 snubnose
Learn something new everytime I get on this board...
Fifteen years of driving, four manual transmissions, and I never knew that existed
Is this something fairly new?
Old Thu, Mar-25-2010, 10:46:51 PM   #16
Function7
Function7's Avatar
I assume so. My older cars used to have separate reservoirs while my newer ones (non BMW) have just one shared reservoir. Just another casualty of cost cutting in the auto industry.
-A
Queen Creek, AZ
Old Fri, Mar-26-2010, 12:36:26 AM   #17
Fastdog911
Fastdog911's Avatar
Reputation: 0 Fastdog911 has disabled reputation
I was under the impression that the bleeding of the SMG needed to be done by the GT1 machine..has anyone actually performed this service without it??
[IMG]2002 SMG, Topaz Blue, BHS pulleys, all options. UUC Exhaust, GC Sway bars, SS lines, BHP Pads F1 paddles, GSP brake pedal, Huber Optik 20%, Iforged rims and a bunch of other things.. Sold
1970 911T Tangerine
1972 911T Albert Blue
1970 911E Ossi Blue
Jump to top Fastdog911 is offline   Reply With Quote
Old Fri, Mar-26-2010, 12:42:29 AM   #18
Function7
Function7's Avatar
You have to use a GTI system or the AutoEnginuity to bleed the SMG system. This thread was about bleeding a standard 6-speed, not an SMG.
-A
Queen Creek, AZ
Old Thu, May-17-2012, 08:26:52 PM   #19
bio10155
Reputation: 0 bio10155 is on a distinguished road
United Kingdom
Default Re: Do I need to bleed the clutch on an SMG when doing a brake fluid change?
Just to clarify - SMG and manual have different actions to the word 'bleeding'
On the manual the clutch and brake lines share the brake fluid from the master cylinder. When u 'bleed' a manual clutch, you are feeding past fluid from this nipple point to a collection container - this is physical.
On an SMG - the brake system does not share fluid with the SMG clutch. They are both independent. When people refer to the 'SMG bleed' it means to purge the hydrulic lines of air that may exist via valve actuations - this is done by the GT1 or any equiv software. You don't physically take out any fluid from the SMG unit. The trapped air is then vented to the top of the SMG header tank. If you actually want to physically bleed the SMG unit i.e. change the fluid in the unit then one needs to either bleed it from the shift travel cylinder (nipple bit) or unscrew the lines from the hydrulic lines.
Jump to top bio10155 is offline   Reply With Quote
Old Thu, May-17-2012, 11:15:03 PM   #20
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
-A
Umm...........no.........it's about SMG...read the title.
So from what i gathered for 6mt makes sense to bleed the clutch also because you want all the fluid that will be in the same reservoir to be changed......and for SMG just do the brakes because there is a different reservoir and fluid for the SMG clutch making it not neccessary to get all the brake fluid out.....Correct?
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Supersprint V1/Supersprint straight pipe sec 1/ Supersprint X-pipe/OEM Muffler/Eventuri Intake/TCKline Single Adjustable/TCKline Camber Plates/TMS Adjustable Rear Control Arm/Powerflex Black RTABs/Turner Delrin FCABS/ Brembo GT 6 pot F 4 Pot R/OEM CSL Trunk/ SGT 1 piece lip
Jump to top Sandeep1212 is offline   Reply With Quote
bleed, brake, change, clutch, fluid, smg
Discussing Do I need to bleed the clutch on an SMG when doing a brake fluid change? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
