Old Fri, Feb-26-2010, 01:34:09 AM   #1
1997 cosmos m3
Reputation: 0 1997 cosmos m3 is on a distinguished road
Default m5 clutch conversion ?'s
I can get the e34 m5 clutch kit from sachs for a decent deal through my dad. do you use the whole kit including pressure plate, disc, throwout bearing? do you have to do anything special like install the disc a certain way. I am going with a jb racing aluminum flywheel, as I heard they were made to be used with the m5 setup. thanks guys. tj.
Jump to top 1997 cosmos m3 is offline   Reply With Quote
Old Fri, Feb-26-2010, 01:38:22 AM   #2
FSUhorizon
In the US of A, we have freedom of speech
FSUhorizon's Avatar
Reputation: 0 FSUhorizon is on a distinguished road
The clutch has to be installed backwards with the JB racing flywheel. That's the exact setup I have. I like it. There's a small bit of chatter at idle and at low rpms when engaging. Very happy with it so far.
The only M5 bits that you use are the pressure plate and clutch. The throw out bearing needs to be E36 M3.
Bimmerforums is corrupt: forums.bimmerforums.com/forum/showthread.php?t=971063
Jump to top FSUhorizon is offline   Reply With Quote
Old Fri, Feb-26-2010, 02:07:11 AM   #3
fiveightandten
fiveightandten's Avatar
Weights, FYI...
OEM Setup:
Sachs M3 Clutch = 2 lbs
Sachs Pressure plate = 10 lbs
Luk Flywheel = 23 lbs
TOTAL OEM setup = 35 lbs
M5 + JB setup:
M5 clutch = 4.5 lbs
M5 pressure plate = 13.5 lbs
JB Racing Flywheel = 10 lbs
TOTAL M5 + JB SETUP = 28 lbs
Should be roughly a 7 lb drop in rotational mass.
-Nick
Old Fri, Feb-26-2010, 05:57:04 PM   #4
1997 cosmos m3
so is this kit I am trying to create this exact kit from bimmerworld or not? this kit. http://store.bimmerworld.com/shared/...t=products.asp . or are they cheaping out and using a m3 pressure plate with a m5 clutch disc? besides weight what would be the main difference between the two pressure plates? what slave cylinder should be used when going with a lightweight flywheel? it is the one with the oem sachs clutch for 850 with the jb flywheel.
Old Fri, Jun-09-2017, 04:26:16 AM   #5
macelius
Reputation: 0 macelius is on a distinguished road
Default Re: m5 clutch conversion ?'s
Weights, FYI...
OEM Setup:
Sachs M3 Pressure plate = 10 lbs
M5 + JB setup:
M5 clutch = 4.5 lbs
JB+M5+M3pp setup:
(Sachs?) M5 clutch = 4.5 lbs
Lightweight Alu Flywheel = ~10 lbs
TOTAL JB+M5+M3pp setup: ~24.5 lbs?
2/'99 M3 Coupe - Estoril Blue / Black Vader / Contours / Style 32s - 175k
Factory X-brace | Eibach/RD strut bar | Vogtland Coilovers | RD front sway | Powerflex FCABs | JT RSMs | RSM reinforcement plates | RTAB limiters | Z3 rack | 0-ring shielded lower steering column bearing | RD front bumper | ZKW E-codes | C33 Aux-in mod | BSW mids | Reworked CCC
Jump to top macelius is offline   Reply With Quote
clutch, conversion
Discussing m5 clutch conversion ?'s in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
