Old Wed, Jan-06-2010, 05:28:49 AM   #21
iggy
iggy's Avatar
Reputation: 0 iggy is on a distinguished road
Know what, I might just go ahead and order them anyways. I'd rather order it all to be sure I'll have everything I need for the job instead of cheaping out and trying to save a few bucks and risk not having a replacement for a damaged component.
I've heard that not all parts of the Pelican kit can be accessed with transmission still bolted to the car. Is that true?
If so, which pieces should I leave out?
Alex
Jump to top iggy is offline   Reply With Quote
Old Wed, Jan-06-2010, 06:47:58 AM   #22
rowar64
eh
Reputation: 0 rowar64 is on a distinguished road
I would tend to trust Chris and Understeer. If you're unsure give him a call or email, you'll get a very quick response from my experience.
You may not need the second set of spacers due to going with the UUC carrier bushing. I went with TMS Delrin bushing and did use the spacers, iirc.
You absolutely do not need to drop the driveshaft/exhaust to do this. I've done it twice now without doing so. Many others have as well. But as has been well stated, it does make things that much more difficult.
As for not needing those spacers....Not installing the spacers is going to leave your gearbox extremely loose and sloppy. They are definitely required. You can get the general idea from this picture:
Robert
1998 m3 Cosmos/Grey
Jump to top rowar64 is offline   Reply With Quote
Old Wed, Jan-06-2010, 01:16:14 PM   #23
iggy
iggy's Avatar
It's not that I don't trust Understeer, I just want to replace as many wear items as I can while I'm in there. The vagueness of my stock shifter is driving me nuts and I want to enjoy the same crisp shifter that I'm sure the OP is enjoying now.
I'll try to contact Chris today and see what he thinks, unless other forum members can shed more light.
Alex
Old Wed, Jan-06-2010, 02:17:17 PM   #24
runindawg
95M3 04ZHP
Reputation: 0 runindawg is on a distinguished road
Default Yellow Washers on Selector Rod
BMW changed their design at some point to no longer use the yellow washers.
Check realOEM for various build dates and you will see. If you have a selector rod designed for washers then get new washers. If you get a new selector rod that isn't designed for the yellow washers(the two "pins" are shorter) then obviously, you don't need the yellow washers(there isn't room for them).
BMW also changed the style of the gear selector "joint" or "knuckle" at some point. This is only important to know if you decide to switch to the new style joint as it is slightly longer(and therefore requires a corresponding selector rod that is slightly shorter).
If more info desired, see unofficialBMW(ron stygar's site)
Jump to top runindawg is offline   Reply With Quote
Old Wed, Jan-06-2010, 05:55:24 PM   #25
Oogie_M
o_O
Oogie_M's Avatar
Reputation: 0 Oogie_M is on a distinguished road
Taiwan
my build date is 10/98 and it shows no #9 yellow spacers in realoem.com
However I ordered them just in case since it wasn't much money.
Jump to top Oogie_M is offline   Reply With Quote
Old Thu, Jan-07-2010, 05:18:43 PM   #26
reidnez
reidnez's Avatar
Reputation: 0 reidnez is on a distinguished road
One more project to add to the list, but like all the others it has to wait until I have my own garage again. My shifter is not terrible, but it's not too crisp either.
Jump to top reidnez is offline   Reply With Quote
Old Tue, Jan-12-2010, 11:18:24 PM   #27
SketchyD
Relentlessly Awesome
Reputation: 0 SketchyD is on a distinguished road
just finished installing a Z3 lever, DSSR, and new bushings, though i didn't do those pieces actually on the trans (that sponge thing and the part the selector rod attaches to). i'm a little disappointed with the results, i still have some play in the shifter, AND THAT FIFTH GEAR LEAN!!
but the throws are definitely shorter and crisper
Jump to top SketchyD is offline   Reply With Quote
Old Tue, Jan-12-2010, 11:25:23 PM   #28
Roland H
LOLiticks troll
Roland H's Avatar
Reputation: 0 Roland H is on a distinguished road
The sponge thing is one of the more important bushings. Make sure your trans is topped off with fluid, and the fifth gear lean and detent bushing kits will really make a difference.
Jump to top Roland H is offline   Reply With Quote
Old Wed, Jan-13-2010, 12:22:40 AM   #29
PurduinaM3
Reputation: 0 PurduinaM3 is on a distinguished road
Well yeah, not replacing those key parts will cause that extra slop... it's cheap to just do them all while you're in there... As far as the 5th gear lean, you have to pull the tranny and do the detent pin fix, no shifter will fix that...
Jump to top PurduinaM3 is offline   Reply With Quote
Old Wed, Jan-13-2010, 01:47:13 AM   #30
Brandon318
Reputation: 0 Brandon318 is on a distinguished road
No, all parts can be accessed even with the tranny on, just fine, actually. There's one clip, known as the b!tch clip, that's difficult to remove. Just destroy it with a screwdriver. Search b!tch clip to find tips.
/// Brandon
Jump to top Brandon318 is offline   Reply With Quote
bushing, great, linkage, replacement, shift
Discussing Shift linkage bushing replacement = great in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
