Old Sun, Dec-06-2009, 05:12:32 PM   #1
Miami M3
If I only Had Gummybears ...
Miami M3's Avatar
Reputation: 0 Miami M3 has disabled reputation
Switzerland
Default ashtray/cigarette lighter DIY removal and replacement
i replaced all my plastic console pieces including the ashtray a while back and i must have put the cig lighter back together wrong since it doesnt work and when you put a new fuse in, it blows immediately
cant find the DIY for removal again
can someone point me in the direction - i know there was a thread on here that i followed the first time
thanks
Official Boobie Connoisseur Number Fifty-Four
Jump to top Miami M3 is offline   Reply With Quote
Old Sun, Dec-06-2009, 06:21:03 PM   #2
Kaveh
Kaveh's Avatar
Reputation: 0 Kaveh has disabled reputation
Iran
From what I remember, it was very simple!
remove the shift boot, remove the screws inside the shift trim, remove the 2 screws holding the bottom of the cigarette lighter trim, you have to remove the eye-glass holder by squeezing the top/bottom of it so it pops out and then there are 2 remaining screws behind that and the whole thing comes out.
I will try to find the DIY as I remember learning this trick from there. But from what I remember, the trickiest part is to remove the eye-glass holder without scratching or cracking it.
here's one, but its not as descriptive.
http://forum.e46fanatics.com/showthr...e+glass+holder
cheers,
'03 AW/Cinnamon Vert ::: 6MT ::: LEDs ::: CWP ::: NAV (Keeper)
'01 TiAg/Grey M3 Vert ::: 6MT ::: LEDs ::: CWP ::: 19" CSL (Sold)
'01 LSB/Grey M3 Coupe ::: 6MT ::: CWP ::: 19" (Sold)
'01 Imola/Black Vert ::: 6MT ::: CWP ::: 19" (Sold)
'04 TiAg/Black M3 ::: SMG ::: NAV ::: Cold weather Package ::: PDC (Sold)
Jump to top Kaveh is offline   Reply With Quote
Old Sun, Dec-06-2009, 07:46:07 PM   #3
Miami M3
Miami M3's Avatar
Switzerland
cheers,
thanks - yeah i got it out in less than 5 minutes -- thing is i cant figure out what i did wrong when i originally removed and re-installed the actual cig lighter -- maybe i bent the metal prongs (i still have trouble removing the metal cig lighter from the black plastic housing) when i tried to get it out
the current situation is this -- everything appears to have been put back together correctly, the two wires (grounds?) are plugged in -- but the cig lighter doesnt work - it blows the fuse immediately meaning something aint right, right?
anyone have thoughts ? maybe i need to order a new cig lighter (just the metal piece) and reinstall
Old Mon, Dec-07-2009, 05:05:03 AM   #4
johnm_oz
johnm_oz's Avatar
Reputation: 0 johnm_oz is on a distinguished road
The two wires are power and ground, you haven't swapped them over have you? Brown is ground, power is probably red with a black/white trace.
Cheers
JM
Jump to top johnm_oz is offline   Reply With Quote
Old Mon, Dec-07-2009, 05:13:51 AM   #5
grkbimmer
grkbimmer's Avatar
Reputation: 0 grkbimmer is on a distinguished road
just did the same thing actually (but i removed my cig lighter and put in a usb power source and replaced the fuse)... the red wire with yellow tracers goes on the bottom prong and the brown wire goes on the other. unless the actual cig lighter is messed up or if your wiring harness is nicked somewhere and being shorted out (had this happen in my old car) or if you get a penny stuck in it (seen it before) you should be fine.
-George
The Car: '04 E46 M3/6 speed/Silver Gray/Imola Red/Nav/19" wheels
Tires: Hankook Ventus V2 235/35 F & 275/30 R
Audio: Silverline iPod adaptor
Performance: BMW performance shift knob & SSK/Gruppe M muffler/KW V2
Interior Mods: Imola red shift and e-brake boot/long eurotray/full trunk dynamat/Custom USB Power Adapter in Euro Tray
Exterior Mods: Umnitza Angel Eyes/Carbon Fiber Grill and Side Gills/28% Carbon Tint/Full Carbon CSL Replica Rear Diffuser
Mod Wish List: HPF Stage 2/Passport 9500ci custom/CSL trunk
Jump to top grkbimmer is offline   Reply With Quote
Old Mon, Dec-07-2009, 01:36:28 PM   #6
Miami M3
Miami M3's Avatar
Switzerland
Cheers
JM
im pretty sure you can only put them on one way -- the wires are different sizes and have different types of clips
the only thing i can think of is when i originally removed the metal cig lighter, it took a lot of force, maybe i smashed the prongs a bit or something
if not, maybe its a nicked wiring harness
Old Mon, Dec-07-2009, 05:32:47 PM   #7
grkbimmer
grkbimmer's Avatar
doubt you nicked the wiring harness unless you were messing around back there, pulling and pushing the wires(i nicked it during my head unit install in my old car). But a damaged cig lighter would do it, i destroyed mine when removing it and i think you might have done the same. i would say pick up a new one for a few bucks
but another thought...
when you said you place the new fuse in, does it blow right away with nothing drawing power from the cig lighter or with something pluged in?
if it blows with something pluged in try using a different fuse because the item plugged in might be sucking up to much power and blowing the fuse. just an idea..
good luck
-George
Old Mon, Dec-07-2009, 06:34:44 PM   #8
Miami M3
Miami M3's Avatar
Switzerland
good luck
ill give it a shot -- how do you remove the actual cig lighter metal housing from the black plastic it sits in ?
dont know the answer to the question since my mechanic tested the lighter - and told me it blew the fuse - not sure if it blew when he pressed the lighter or when he replaced the fuse
Old Mon, Dec-07-2009, 06:50:18 PM   #9
johnm_oz
johnm_oz's Avatar
Yeh, I thought the spades might be a different size. You should be able to see if you've done any damage that's causing the lighter socket to short. Anyway you can confirm if it's the socket or the wiring causing the problem by unplugging one of the wires- probably the red one'd be better, off the back of the socket.
Cheers
JM
Old Mon, Dec-07-2009, 06:57:03 PM   #10
Miami M3
Miami M3's Avatar
Switzerland
Cheers
JM
how would this confirm anything ?
ashtray or cigarette, diy, lighter, removal, replacement
Discussing ashtray/cigarette lighter DIY removal and replacement in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
