Old Mon, Sep-14-2009, 08:39:12 PM   #41
GR///M3
GR///M3's Avatar
Reputation: 0 GR///M3 is on a distinguished road
Greece
Originally Posted by Highpower11 View Post
sakman74, let us know how everything turns out. I didn't find any chips per se but there was some slight discoloration of the filter (grayish in color) in my instance. Everything looked really good but then again I was at 8800 miles when I checked and replaced mine. Also I had no problem swapping out the o-rings as they all matched for me. I got all my stuff at Tischer.
parts arrived today instead of friday, anyway, i did the job....wish changing the oil was this easy.....
can't remember the thread but someone else mentioned that one of the o-rings depicted in the diagram (item 5 - 11311318659) http://www.realoem.com/bmw/showparts...=11&fg=15&hl=6 .....did not go anywhere visible when the valve was removed. so i have this extra o-ring and didn't use it. there was a square looking black ring but i'm not sure if it was rubber or hard plastic, i didn't touch it. i did replace the larger o-ring (item 6).
the filter did have small speckles of metal in it, really very small grains, they were there all around the filter.
pliers worked fine to remove the old filter, i snapped the new one on by hand
///M fan
Jump to top GR///M3 is offline   Reply With Quote
Old Mon, Sep-14-2009, 09:13:55 PM   #42
tonggi
Tonggi Tuning, LLC
tonggi's Avatar
Reputation: 0 tonggi is on a distinguished road
Great video! Good job making this man!
TiTS Racing in association with MMFN Racing and AYO STFU
Want to buy your High Mileage Car!
Jump to top tonggi is offline   Reply With Quote
Old Wed, Sep-23-2009, 10:44:37 PM   #43
kn0my
Reputation: 0 kn0my is on a distinguished road
I too could not find where item #5 was on my pressure limiting valve (as depicted in http://www.realoem.com/bmw/showparts...=11&fg=15&hl=6).
Has anyone figured out this mystery? The hard flat o-ring followed by the spliced nylon o-ring appears to be set of parts that comes on a new pressure limiting valve. With that being said #5 did fit snug over the end of the PLV (after the filter), but I'm not one to shove random parts into my VANOS.
Jump to top kn0my is offline   Reply With Quote
Old Sun, Sep-27-2009, 05:44:59 AM   #44
Jako1
Jako1's Avatar
Reputation: 0 Jako1 is on a distinguished road
I think we are all having the same issues. The big o-ring matched up. The smaller one didn't.
Jump to top Jako1 is offline   Reply With Quote
Old Sun, Sep-27-2009, 01:03:06 PM   #45
vioilio
Reputation: 0 vioilio is on a distinguished road
Great video! Thank you! Will change soon.
Jump to top vioilio is offline   Reply With Quote
Old Wed, Jan-20-2010, 01:23:40 AM   #46
m3e46freak
M3 Freq
m3e46freak's Avatar
Reputation: 0 m3e46freak is on a distinguished road
Germany
Definitely bumping this up and going to attempt to do it... I have a mechanic around here that used to be master mechanic at BMW Gmbh over here in Germany. He says a large portion of VANOS failures are at fault from this small filter..
subscribed and bump
Rock Hard Abs Racing
KWV2!
18X10 CCW CLASSIC!
CPI Headers!
RESONATORS AND SUPERSPRINT!
DINAN!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
Jump to top m3e46freak is offline   Reply With Quote
Old Wed, Jan-20-2010, 05:09:46 PM   #47
Wengy
Reputation: 0 Wengy is an unknown quantity at this point
Sweet, thanks a bunch for the video. I knew the job was easy, but not that easy. So I'm ordering a new filter/screen, today.
Jump to top Wengy is offline   Reply With Quote
Old Mon, Jun-20-2011, 10:35:50 PM   #48
bstone
bstone208
Reputation: 0 bstone is on a distinguished road
Default Re: Video: VANOS filter replacement DIY
subscribed and bump
Seems hard to believe that by neglecting such a simple Vanos Filter change could potentially lead to complete engine failure.
Whether it is true or not, I have no problems spending the $15.00 for a new filter and rubbers to possibly prevent Vanos failure leading to a much more expensive fix (engine).
Anyway... Thanks for the Video. Doing this tonight. Curious to see what lies in my filter.
Jump to top bstone is offline   Reply With Quote
Old Mon, Jun-20-2011, 10:37:33 PM   #49
zerotosixty
Search Nazi
zerotosixty's Avatar
Reputation: 0 zerotosixty is on a distinguished road
OMG! what is up with the bumps lately
Lords of M3Forum official member
ZeroToSixty's car journal
Originally Posted by Why m3 View Post
Not everybody Is into tracking because you guys other to each of their own
Originally Posted by cowboyM3 View Post
Again, just like several of you have proved and myself: it's going to be nothing but a $hitshow until our science is to the height to which we can prove something's there and the time it gets there.
Until then, we must prevent these mistaken pregnancies in the first place
Jump to top zerotosixty is offline   Reply With Quote
Old Tue, Jun-21-2011, 02:51:15 AM   #50
bmwboy031979
Reputation: 0 bmwboy031979 is on a distinguished road
Originally Posted by yaja23 View Post
After how many miles should this filter be replaced?
I've heard every 30k, you should also replace the 2 o-rings as well. I just did this with my last oil change. torque specs are 20 ft/lbs if I remember correctly.
http://www.ecstuning.com/BMW-E46-M3-...nos/ES1892454/
Jump to top bmwboy031979 is offline   Reply With Quote
diy, filter, replacement, vanos, video
Discussing Video: VANOS filter replacement DIY in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
