Old Wed, Jun-16-2010, 08:06:58 PM   #41
ECSTuning
ECSTuning's Avatar
Reputation: 0 ECSTuning is on a distinguished road
You can find the parts needed below...
Click HERE to order or for more information.
The Air Pump, Valve, and Hose
Feel free to shoot us a PM if you have any questions!
Cheers,
Joe
ECS Tuning your #1 source for all things German automotive
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
sales@ecstuning.com | customerservice@ecstuning.com
Jump to top ECSTuning is offline   Reply With Quote
Old Tue, Jul-06-2010, 02:28:46 AM   #42
mredwin25
mredwin25's Avatar
Reputation: 0 mredwin25 is on a distinguished road
does this valve affect performance?
E90 Jerez M3
335i Vert
Jump to top mredwin25 is offline   Reply With Quote
Old Tue, Jul-06-2010, 03:13:50 AM   #43
MisterEm
MisterEm's Avatar
Reputation: 0 MisterEm is on a distinguished road
never did affect it. I believe the pump is only used on cold start to reduce emissions.
If I'm wrong a vulture will pounce and correct me.
Jump to top MisterEm is offline   Reply With Quote
Old Tue, Jul-06-2010, 03:51:52 AM   #44
Chris(NJ)
Back home in Jersey
Chris(NJ)'s Avatar
Reputation: 0 Chris(NJ) is on a distinguished road
Yea, its just an emissions thing. I replaced mine. Pretty easy and dont need a lot of tools. Easy DIY imo.
2002 Topaz/Black M3-Slicktop-SMG: OEM CSL Bootlid, Mini-CSL Battery, TMS Pulleys, Stoptech SS Lines, Borla muffler & Midpipe, Hotchkis Sways, Eibach Springs, RE RSMs, PowerFlex Rtabs, PowerFlex Subframe Bushings, TMS Subframe Reinforcement, Blk Grills, Blk Side Gills, VCSL Center Console, Euro Front Bumper, Hamann Fog Ducts, ACS Lower Lip Spoiler, FUCY Rear Diffuser, LED Tail upgrade w/ outer ring mod, D/A street software, RPI Scoops, e92 m3 18" rims w/ PS2s
Jump to top Chris(NJ) is offline   Reply With Quote
Old Tue, Jul-06-2010, 04:55:00 PM   #45
MisterEm
MisterEm's Avatar
Yep.
One 10 mm box end wrench will do the trick.
Old Fri, Jul-30-2010, 04:59:32 AM   #46
sic
The Slovak
Reputation: 0 sic is on a distinguished road
Slovakia
a little refresh on this thred...
I sure have the same problem, my pump does not pull air... today I am going to exchange the pump.
If the new pump won't work, what else could be the issue ? valve,hose,gasket...all checked.
Or the question is, what makes the pump blow ? Temp sensor ?
Thanks
Jump to top sic is offline   Reply With Quote
Old Fri, Jul-30-2010, 12:54:36 PM   #47
MisterEm
MisterEm's Avatar
leaking valve over time over works the pump.
Old Fri, Jul-30-2010, 07:03:53 PM   #48
sic
The Slovak
Slovakia
is that valve located over the ECU ?
I switched the pumps and still no secondary air flow...
Old Sat, Jul-31-2010, 02:11:34 AM   #49
MisterEm
MisterEm's Avatar
No sir. It's on the passenger side of the motor, above the heatshield, and over the headers. There is a pre-bent plastic hose that connects the pump to the valve as well.
I replaced the hose and and the valve and the random AA code disappeared.
Hope this helps,
Mike
Old Sat, Jul-31-2010, 02:48:31 AM   #50
fasteddie03M3
Reputation: 0 fasteddie03M3 is on a distinguished road
We wouldn't have this problem if we had the german counterpart. Emissions here suck!
My M and S
Jump to top fasteddie03M3 is offline   Reply With Quote
air, pump, replacement, secondary
Help with my secondary air pump... amongst others! soulintake E46 M3 (2001-2006) 2 Thu, Sep-11-2008 02:53:35 PM
Secondary Air Pump Problems PurduinaM3 E36 M3 (1992-1999) 65 Sat, Aug-02-2008 01:59:51 PM
FS: S52 M3 Secondary Air Pump BMW FTW Parts for Sale/Wanted 1 Sun, Jun-08-2008 08:02:32 PM
WTB: Secondary Air Pump 332ti Parts for Sale/Wanted 0 Mon, Jun-02-2008 08:09:36 PM
Anyone ever tried to rebuild their secondary air pump? puopolvj E36 M3 (1992-1999) 13 Thu, Jan-10-2008 03:53:18 AM
Discussing secondary air pump replacement in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
