Old Thu, Jan-22-2009, 06:45:02 PM   #11
QIK1320
Reputation: 0 QIK1320 is on a distinguished road
So I took the cover off her and started it up. Didin't disconnect the hose, but put my hand on the pump and sure enough I felt it turn on so I'm just going to chage the valve for now, reset the light and see what happens
2004 M3 Silver/Grey on Cinammon 44,000km
2008 M3 Alpine white on Black 90,000km
Jump to top QIK1320 is offline   Reply With Quote
Old Thu, Jan-22-2009, 08:47:23 PM   #12
JeST
Old Skool
JeST's Avatar
Reputation: 0 JeST will become famous soon enough
China
^ don't forget the gasket as the leak will throw a ses light.
1994 Toyota Supra 6speed Red/Black
Big Single + Meth
Jump to top JeST is offline   Reply With Quote
Old Fri, Jan-23-2009, 11:45:24 AM   #13
QIK1320
will do...Thanks!
Old Mon, Feb-09-2009, 03:39:49 PM   #14
lax01
lax01's Avatar
Reputation: 0 lax01 will become famous soon enough
Any resolution to this? I have a P0411 code after the dealer replaced one of my header/cats. The code wasn't there before they did the work so I'm thinking they might have re-used the gasket on the valve or something. I checked the hose for cracks and did not see one. I tried seeing if the pump would work but I think the car was too warm (it won't turn on if the coolant is too warm right?)...
Thanks
-Josh
2004 Porsche GT3 - sold
2002 M3 Carbon Black - sold
2012 Ducati Streetfigher 848 - sold
Jump to top lax01 is offline   Reply With Quote
Old Mon, Feb-09-2009, 04:05:06 PM   #15
Chris(NJ)
Back home in Jersey
Chris(NJ)'s Avatar
Reputation: 0 Chris(NJ) is on a distinguished road
I just did this job. Very easy to do. Fwiw, I didn't replace the gasket. I had bought a new one, but my old one was on there pretty good, so I said screw it and left it. No leaks large enough to toss another code. Also, I'd suggest getting that hose. Mine snapped very easily. I actually think it was cracked prior to removing it and that may have been what was causing the light. Anyway, yea, easy job. I'd buy parts 3, 4, 5 and 6.
2002 Topaz/Black M3-Slicktop-SMG: OEM CSL Bootlid, Mini-CSL Battery, TMS Pulleys, Stoptech SS Lines, Borla muffler & Midpipe, Hotchkis Sways, Eibach Springs, RE RSMs, PowerFlex Rtabs, PowerFlex Subframe Bushings, TMS Subframe Reinforcement, Blk Grills, Blk Side Gills, VCSL Center Console, Euro Front Bumper, Hamann Fog Ducts, ACS Lower Lip Spoiler, FUCY Rear Diffuser, LED Tail upgrade w/ outer ring mod, D/A street software, RPI Scoops, e92 m3 18" rims w/ PS2s
Jump to top Chris(NJ) is offline   Reply With Quote
Old Mon, Feb-09-2009, 04:15:22 PM   #16
QIK1320
I haven't done my car yet, going to wait until April or so when I pull it out
Old Mon, Feb-09-2009, 06:05:11 PM   #17
JeST
Old Skool
JeST's Avatar
China
Thanks
Correct, it needs to be on a cold start where the car needs the secondary pump to "inject" air into the exhaust system to help the cats break down emissions.
I'd let the car sit overnight outside and try the method of disconnecting the hose to the valve and start the car. Feel if the air is being pumped through the hose. If there's airflow then most likely the valve attached to the head has too much carbon buildup and will need to be replaced.
Big Single + Meth
Old Mon, Feb-09-2009, 06:06:12 PM   #18
lax01
lax01's Avatar
Thanks...I'll report back if and when I fix my problem...
I just passed emissions so I don't think I'm really going to care about this...we'll see
-Josh
Old Mon, Feb-09-2009, 06:06:46 PM   #19
JeST
Old Skool
JeST's Avatar
China
Over time that plastic becomes hard and brittle, like most old divorced wives, and will break easily.
Big Single + Meth
Old Mon, Feb-09-2009, 11:28:31 PM   #20
lax01
lax01's Avatar
Out of curiosity, I wanted to check to make sure my air pump was actually plugged in since the dealership just had the car for a cat replacement. Sure enough, the pump wasn't plugged in...this should be my problem
-Josh
air, pump, replacement, secondary
Help with my secondary air pump... amongst others! soulintake E46 M3 (2001-2006) 2 Thu, Sep-11-2008 02:53:35 PM
Secondary Air Pump Problems PurduinaM3 E36 M3 (1992-1999) 65 Sat, Aug-02-2008 01:59:51 PM
FS: S52 M3 Secondary Air Pump BMW FTW Parts for Sale/Wanted 1 Sun, Jun-08-2008 08:02:32 PM
WTB: Secondary Air Pump 332ti Parts for Sale/Wanted 0 Mon, Jun-02-2008 08:09:36 PM
Anyone ever tried to rebuild their secondary air pump? puopolvj E36 M3 (1992-1999) 13 Thu, Jan-10-2008 03:53:18 AM
Discussing secondary air pump replacement in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
