Old Sun, Aug-14-2011, 09:24:04 PM   #11
M Nectar
M Nectar's Avatar
Reputation: 0 M Nectar is on a distinguished road
Default Re: Fan Clutch DIY
Great DIY -- thanks!
Did my fan clutch today. Only things I'd add:
1. The fan blades can attach to the fan clutch in two ways, so remember how they're bolted to the fan clutch. Otherwise, the fan clutch + blades won't go back on. Ask me how I know.
2. Be sure to reattach the fan shroud middle "catch." To do this, I found it easiest to remove the top torx screw and hook the shroud back on before reassembling everything.
Thanks again!
Jump to top M Nectar is offline   Reply With Quote
Old Wed, Nov-30-2011, 11:53:04 PM   #12
skelzy
Great White
skelzy's Avatar
Reputation: 0 skelzy is on a distinguished road
Does anyone have a pic of this "catch" in the middle of the shroud?
2005 Coupe AW/BLK/SMG/LOADED
Jump to top skelzy is offline   Reply With Quote
Old Tue, Jan-10-2012, 01:31:39 PM   #13
M Nectar
M Nectar's Avatar
I don't have a picture, but it's pretty clear once you're in there and looking for it. Here's the realoem diagram:
http://www.realoem.com/bmw/showparts...07&hg=17&fg=05
There is a plastic tab from (4) that fits into (2).
Old Fri, Sep-14-2012, 01:26:06 AM   #14
Da Jemster
Institutionalized User
Da Jemster's Avatar
Reputation: 0 Da Jemster is a jewel in the rough
Thanks a lot for writing this up. I started with the other fella's tip from E46Fanatics, but his didn't have the radiator hose like our M's. Everything went smoothly. What really helped was your tip on bending the shroud to let the fan assembly out. Thanks again!
2008 E93 - AW - DCT - Stock...for now
2004 E46///CB-BLK///SMG II///D/A tuned///AFE Stg 2///SS Stepped///SS Metallic Cats///Eisenmann SS X-pipe///SS Race///4.10 diff///ACS CF Front Lip///6000K Xenons & Fogs///CF Grills & Gills///Angel Eyes///Clear Corners w/Solaris///Painted Reflectors///Black'd Sides & Tails///TEIN S
Jump to top Da Jemster is offline   Reply With Quote
Old Sat, Sep-15-2012, 02:13:11 PM   #15
Da Jemster
Da Jemster's Avatar
After the change, I've noticed that my oil temp is now running a tad over 210. Did that happen to you guys as well?
Old Thu, Sep-20-2012, 04:49:23 PM   #16
Chaser720
Chaser720's Avatar
Reputation: 0 Chaser720 is on a distinguished road
That seems pretty high. How old is your coolant?
I thought it was my fan clutch going out and and coolant change brought my temps down.
Jump to top Chaser720 is offline   Reply With Quote
Old Thu, Sep-20-2012, 06:07:36 PM   #17
Da Jemster
Da Jemster's Avatar
After the 4th day, I'm running a hair under 210 and cooler water temps. I guess the unit just needed to settle in.
Old Sat, Mar-16-2013, 03:55:47 AM   #18
orthotist
orthotist's Avatar
Reputation: 0 orthotist is on a distinguished road
Thumbs up Re: Fan Clutch DIY
One thing to add is that you should also clean out the radiator and oil cooler with a hose , both directions, before you put back together. You will be surprised of all the contamients you wash out.
Jump to top orthotist is offline   Reply With Quote
clutch, diy, fan
Stuck clutch fan? Clutch fan brushing up against radiator shroud? Overheat? YiKes! NYM3Jack E36 M3 (1992-1999) 6 Sat, Jun-28-2008 05:28:37 AM
Bad fan clutch and/or aux fan switch ? bartolome1 E36 M3 (1992-1999) 3 Fri, Jul-20-2007 11:34:30 PM
Need DIY on How to Replace Fan Clutch RealPolItiK E46 M3 (2001-2006) 6 Mon, Jun-18-2007 04:31:00 AM
Fan delete DIY JasonSTL739 E46 M3 (2001-2006) 4 Sun, Apr-23-2006 07:26:19 AM
Is it possible to take off the fan clutch and not install an electric fan? UA///M3 E46 M3 (2001-2006) 9 Thu, Nov-03-2005 01:21:38 PM
Discussing Fan Clutch DIY in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
