Old Thu, Dec-20-2007, 08:53:48 PM   #1
Brandon318
Reputation: 0 Brandon318 is on a distinguished road
Default DIY - Windshield Cowl Replacement (Sedan)
This DIY will help you replace the windshield cowling on your E36 sedan, which often becomes brittle, and as a result, cracks and chips. This is intended to compliment the DIY Brett did awhile ago that addressed the same thing, only for the coupe. Since it’s a completely different procedure for the sedan, I figured a DIY was in order.
Let’s start with the tools needed for the job…
• Flat blade screwdriver
• 13mm socket
• Ratchet
• 2-inch extension (optional)
• Torque wrench (optional)
The parts you’ll need are the two cowlings (P/N 51 71 1 960 843 (left) and P/N 51 71 1 960 844 (right)). Optional purchases include grommets and clips, P/N 51 13 8 124 389 and 51 71 8 108 613, respectively. Just get 10 of each. They’re used multiple places on the vehicle, they’re cheap, and they’re good to have in your toolbox.
Let’s begin by removing the engine bay seals and the fan motor grille. Remove the front-most seal (bottom arrow) by pulling upward. Then, remove the grill by unclipping it and pulling upward. Top arrow points to a clip.
This is what it should look like once the above steps are complete…
/// Brandon
Jump to top Brandon318 is offline   Reply With Quote
Old Thu, Dec-20-2007, 08:54:26 PM   #2
Brandon318
Next, let’s remove the wiper arms. Pry up the black cap that covers the wiper shaft nut. Do this on both arms.
Next, unscrew the wiper shaft nut using your 13mm socket.
Close your hood (not completely) and wriggle the wiper arm loose. This may take some effort, as some cars haven’t had these removed – ever.
Once it’s loosened (not yet removed), open your hood and lift the arm off of the shaft.
/// Brandon
Old Thu, Dec-20-2007, 08:54:57 PM   #3
Brandon318
Next, beginning with the driver’s side first (yes, it matters), gently pry the cowl upward. It simply clips in.
Remove the other side by first unscrewing the little black fasteners.
Then lift upward in the same way as the driver’s side. It will be pretty dirty under there…
I took some time to clean up…
Now we’re ready to install the new guys. Transfer the clips from the old cowling to the new ones, and snap the new cowling into place.
Installation is reverse of removal. Tighten the wiper arms to 18 ft-lbs.
Voila…
/// Brandon
Old Thu, Dec-20-2007, 10:36:00 PM   #4
Very nice Brandon!
If you want, I'd be happy to place all your DIY's on my website (with proper credit of course). Link in sig; DIY
Old Thu, Dec-20-2007, 10:54:29 PM   #5
Shock(/\)ave
Freedom Under Democracy
Reputation: 0 Shock(/\)ave is on a distinguished road
Talking
Great work!
Founder Of The New Car Smell Club & The Canadian Edition Club
Originally Posted by M3BabyDady View Post
i once stood in front of my x fiance and said .... wow that right there is the love of my life, and i pointed at an m3
Jump to top Shock(/\)ave is offline   Reply With Quote
Old Fri, Dec-21-2007, 12:32:41 AM   #6
Sirius
How many licks..
Sirius's Avatar
Awesome!
♪♫♪♪♫♪ Trevor ♪♫♪♪♫♪
97' M3. '10 R6.
Old Fri, Dec-21-2007, 01:26:14 AM   #7
Brandon318
Very nice Brandon!
Wow, sure, that'd be great Brett!
/// Brandon
Old Fri, Oct-17-2008, 03:43:41 AM   #8
kcchong
Reputation: 0 kcchong is on a distinguished road
Hi there! Any chance of re-uploading the pictures. They don't load anymore. Thanks!
Jump to top kcchong is offline   Reply With Quote
Old Fri, Oct-17-2008, 01:07:04 PM   #9
jmd471
jmd471's Avatar
Reputation: 0 jmd471 is on a distinguished road
Word of warning, watch the nut that holds on your windshield wipers
Mine was missing the cap, so it was pretty well fused to the bolt, and being a jackass I twisted it off.....Had to replace the entire linkage, no fun.
Jump to top jmd471 is offline   Reply With Quote
Old Fri, Oct-24-2008, 06:00:11 AM   #10
kcchong
Thanks for re-upping the pics!
cowl, diy, replacement, sedan, windshield
DIY - E36 Lower Windshield Cowl Replacement - "Lower Seal" Braymond141 Faults, Fixes and DIY 24 Wed, Dec-31-2014 03:36:30 PM
Windshield Replacement gtb5 E46 M3 (2001-2006) 18 Thu, Nov-08-2007 02:22:19 AM
windshield replacement Lost Mid Atlantic 4 Thu, Aug-16-2007 02:40:15 PM
FS E36 M3 lower windshield cowl Techno ///M3 Parts for Sale/Wanted 2 Sat, Jan-06-2007 12:02:53 AM
Windshield replacement LA, CA ara7 E46 M3 (2001-2006) 3 Tue, Oct-10-2006 08:57:27 AM
Discussing DIY - Windshield Cowl Replacement (Sedan) in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
