Old Mon, Nov-29-2010, 05:10:50 PM   #11
ECSTuning
ECSTuning's Avatar
Reputation: 0 ECSTuning is on a distinguished road
As mentioned above you can't go wrong with UUC!
It is well-known that BMW's original clutch arm bushings are the culprit for the annoying squeaking problem from your clutch pedal. You can lubricate or replace - but none of that typically works.
By simply replacing the stock bushings with the UHMW (Ultra High Molecular Weight polycetal) UUC Motorwerks Clutch Arm Bushings, you can permanently get rid of that annoying squeak and the side-slop.
The great advantage of UHMW over other materials is the superior long-term wear characteristics and self-lubricating properties.
An inexpensive way to keep your sanity.
Click HERE for more information.
Please let us know if you have any questions! Feel free to shoot me a PM or email.
Best,
Joe
Have questions? Need answers? Live Chat us! 8:30am to 12:00am Midnight EST
sales@ecstuning.com | customerservice@ecstuning.com
Customer Service Hours: M- F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172
Facebook | YouTube|OEM BMW Part Number Search
Jump to top ECSTuning is online now   Reply With Quote
Old Mon, Nov-29-2010, 05:27:44 PM   #12
d3x74
apple pie shtn skip
d3x74's Avatar
Reputation: 0 d3x74 is on a distinguished road
Originally Posted by BHenderson View Post
Even the slightest squeak can vibrate throughout the entire pedal assembly making it very difficult to track down its source. I have just gone through this entire deal, and I found out that my flywheel was squeaking a bit (amplified greatly by a SS line which I have since removed).
The best way to track down the source is to grab a stethoscope, get underneath the car, and have a buddy press and release the clutch pedal slowly. Even then, it's difficult to track down the source.
Was it a SS line between the slave cylinder and the master cylinder?
I am having a new clutch installed and am in the process of replacing the clutch slave cylinder and getting a SS line between the slave and the master myself. Will this increase the problem?
Jump to top d3x74 is offline   Reply With Quote
Old Mon, Nov-29-2010, 06:27:57 PM   #13
stolidog
stolidog's Avatar
Reputation: 0 stolidog is on a distinguished road
Originally Posted by d3x74 View Post
I know its the clutch slave cylinder on mine that squeaks.
Same here. I have a squeaking outside the car that happens when I press the clutch in. I went to my indy, clutch slave needs to be replaced. Luckily its rather inexpensive.
2004 E46 M3 Tiag - 6 Speed, Blk Interior, OEM 19's
Current Mods:330d Shifter, Orion V2 4300k, TIAG reflectors
2014 Ducati 899 Panigale - Red
Current Mods:LSL Footpegs, Techspec Snake Skin, Opticoat Pro, DP Lower Radiator Guard
2016 X4 3.5i M-Sport - Dark Graphite Metallic
Jump to top stolidog is offline   Reply With Quote
Old Mon, Nov-29-2010, 06:49:34 PM   #14
BHenderson
Reputation: 0 BHenderson is on a distinguished road
Yeah, it was the clutch SS line which stiffened the clutch pedal and transferred more sound from the pressure plate to the entire pedal assembly. After I took that SS line out and put the stock rubber line back in, the pedal lightened up and felt so much better.
I see no reason for a SS clutch line. You're just modulating some liquid through means of hydraulic lines. :shrug:
Jump to top BHenderson is offline   Reply With Quote
Old Mon, Nov-29-2010, 07:32:15 PM   #15
d3x74
apple pie shtn skip
d3x74's Avatar
Did the clutch pedal feel stiffer?
Guessing you also had the SS brake lines, would you recommend them? Does it makes the brakes stiffer and more responsive?
Old Mon, Nov-29-2010, 07:46:39 PM   #16
BHenderson
The SS clutch line made the clutch pedal feel way stiffer.
The SS brake lines made the brakes feel stiffer and more responsive. I would definitely recommend them.
Old Thu, Sep-08-2016, 07:36:10 AM   #17
aceprowler
Reputation: 0 aceprowler is on a distinguished road
Default Re: squeaky clutch pedal: where do i grease?
Originally Posted by natty99 View Post
or just replace the OEM clutch pedal bushings with the ones from UUC:
http://www.turnermotorsport.com/html...PRODUCT_ID=CAB
Thread revival!
Just wanted to say thanks.
Was just looking to see if I could fix the problem!
Just got an e36 m3 unmolested but needed updated of worn parts as the norm.
Thanks again!
Great Site!!
Jump to top aceprowler is offline   Reply With Quote
clutch, grease, pedal, squeaky
squeaky clutch pedal nepenthean E36 M3 (1992-1999) 6 Sat, Mar-15-2008 04:15:16 AM
Squeaky Clutch Pedal USNA92 E36 M3 (1992-1999) 12 Thu, Jul-13-2006 03:51:18 AM
squeaky clutch pedal -- if the clutch is not bled properly....two more questions SeattleBlackM3 E46 M3 (2001-2006) 2 Tue, Jun-13-2006 10:16:12 PM
Squeaky Clutch pedal? ViNcE650 E36 M3 (1992-1999) 21 Fri, Feb-24-2006 05:47:52 PM
Squeaky clutch pedal Cyrus E36 M3 (1992-1999) 12 Tue, Apr-27-2004 04:59:45 AM
Discussing squeaky clutch pedal: where do i grease? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
