Old Wed, Jan-10-2018, 01:23:56 AM   #91
m3dragon
CSL M3 / Raptor / 12C
m3dragon's Avatar
Reputation: 0 m3dragon is on a distinguished road
Default Re: Comprehensive CSL Intake Thread
Would have to program it for your car and I think have to change units possibly. Not plug and play but same dme.
NorCal drive organizer guy
Drive database and photo locations
NorCal CSL build thread - US to CSL Conversion
Jump to top m3dragon is offline   Reply With Quote
Old Wed, Jan-10-2018, 01:26:01 AM   #92
It'd be no different than using any other used DME.
Old Wed, Jan-10-2018, 01:42:57 PM   #93
EYEHAVEYOU
Simon
EYEHAVEYOU's Avatar
No. US and Euro DMEs are the same besides the software.
Thanks for the explanation, I've read this and other threads but still feel like a total noob when it comes to the CSL airbox install
Old Thu, May-03-2018, 05:43:03 PM   #94
repoman89
repoman89's Avatar
Reputation: 0 repoman89 is on a distinguished road
Originally Posted by casper3t View Post
I just got word that the Control Unit (Snorkel) P/N 11617833498 is no longer available.
I know this post is four years old -- seems like these may have gone back into production? https://www.ecstuning.com/b-genuine-...617833498~oee/
Has anyone ordered one of these and received it? I placed an order so we'll see if it goes through. I'm in the Karbonius airbox group buy and will try to remove their CF snorkel from my order if I can source the legit flap. I read on here that people were paying $900 for the OE flap a few years back so $420 isn't bad ... assuming they send it!
Jump to top repoman89 is online now   Reply With Quote
Old Sun, Sep-30-2018, 01:39:20 PM   #95
Updated the bit on the alternator signal for 2004+ cars
Alternator signal (March 2004+ Cars)
Option 1: Software mod
  • Download Modified Program (remove the ".pdf" from the filename to extract the archive)
  • Flash the modified program that's appropriate for your setup
    • If you're using the non-CSL bootloader, the "2113230401" file is the appropriate one
  • Modify your tune by writing "01 05 0A" at 0x5968
    • A parameter section is not included in those binary files. Modify whatever CSL tune you were going to use or already have
  • Using NCS Expert, make sure "GENERATOR_UEBER_CAN" is set to aktiv (should already be aktiv if your car is a March 2004+ car)
Option 2: Wiring mod
  • Requirements:
    • 12527510674 x 2 (Cluster and DME pins)
    • 22 AWG wire
  • Pinout: Black Connector of Instrument Cluster Pin 2 -> X60004 Pin 1
  • Coding: Set “GENERATOR_UEBER_CAN” to nicht_aktiv
Thread discussing the modification here: http://www.m3forum.net/m3forum/showthread.php?t=602252
As far as which method is "better" - if you trust my software skills, either method should be safe.
Old Sun, Sep-30-2018, 02:46:57 PM   #96
duracellttu
Iím in the middle of a CSL conversion and had a quest about the air rail.
Is the only difference between the stock and CSL air rails the inclusion of the MAP sensor on the CSL? Anything else to note?
2005 BMW M3 ZCP - Black/Black 2M Autowerks Full Respray and Restoration: RKP Slicktop Conversion, OE CSL Trunk, JCSL Diffuser
Paul Claudes Custom Tune | Kassel Performance CSL ECU Conversion | Lang Stage Stage 2.5 Head | 288/280 Schrick Cams | CSL Karbonious Airbox | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91 w/ 3 stage clutch
TCK SA 450/500 | Vorshlag Camber Plates | Rogue Engineering ASP, RSM | AKG FCABs, RTABs, SFBs | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | SPAL Fan | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings
Old Tue, Oct-02-2018, 05:38:56 PM   #97
scansp7
Reputation: 0 scansp7 is on a distinguished road
correct, thats the only difference.
TTFS also makes a csl vaccum rail:
http://tuningtechfs.com/ttfs-e46-m3-...nd-map-sensor/
Jump to top scansp7 is offline   Reply With Quote
Old Tue, Oct-02-2018, 05:45:08 PM   #98
EYEHAVEYOU
Simon
EYEHAVEYOU's Avatar
I just ordered Kassel Performance's MAP kit, lets you use the stock fuel rail. Haven't read much about it so I know I'm taking a risk, but hopefully works out OK:
https://www.kasselperformance.com/pr...onversion-kit/
Yes, I ordered from ECS a few weeks back and have the OEM one sitting in my living room currently.
Old Tue, Oct-02-2018, 05:52:36 PM   #99
That looks like a pretty clever solution.
Old Tue, Oct-02-2018, 05:55:32 PM   #100
scansp7
Looking forward to hear about that kit, I know people were also just using the GM map sensor installed between the vacuum line.
I just finished soldering on the new caps and H bridge on my DME, the H bridge is tricky!
Discussing Comprehensive CSL Intake Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
