Old Sat, Mar-22-2014, 10:33:09 PM   #121
gooooders
gooooders's Avatar
Reputation: 0 gooooders is on a distinguished road
United Kingdom
Default Re: Pic Request OEM 18x9 Square Set-Up on E46 //M3
Originally Posted by PiL View Post
Do you have to have camber adjustment in the front if you run OEM 18 square? I'm not that low, on TEIN S-Techs and Koni SA. Would probably run stock tires 255/40 all around. The square stance looks sick!
Depends how low your front end is?
I can't comment coz I had adjustable camber dialed in as soon as I went lower than 35mm drop from OEM.
Supersprint V2 Headers/euro cats/ s/s non res Xpipe, s/s Race backbox/Kiwi clad Bride Low Max seats (copies)/BC Coilovers/KW Anti roll bars/Rota Grid alloys 18's/OEM 18x9" square set up/Ksport BBK/CSL Bootlid (copy)/Smoked rear LED's.
Jump to top gooooders is offline   Reply With Quote
Old Sun, Mar-30-2014, 07:02:47 PM   #122
dunkman23
dunkman23's Avatar
Reputation: 0 dunkman23 is on a distinguished road
I need some help guys. I'm running 255/40 all the way around and 1.6 camber but from the looks of my car, it looks like the tire is going to hit the top of my fenders. I drove around for a good 20 minutes through speedbumps and drive ways no rubbing so far. Will I rub or crumble my fender if I hit a large enough bump
Sent from my SPH-L900 using Tapatalk
2002 BMW ///M3 6mt TiAg /Imola - APEX ARC-8/PSS - BILSTEIN PSS10
1993 BMW ///E34 Touring - OBD1 S52 - 5sp MT, 3.23 LSD - SOLD
1997 BMW ///E36 Sedan -
2012 BMW ///E70 MSport -
Jump to top dunkman23 is offline   Reply With Quote
Old Tue, Apr-08-2014, 08:43:15 AM   #123
gooooders
gooooders's Avatar
United Kingdom
It'll be close.
Old Mon, May-19-2014, 09:14:58 AM   #124
joHey
joHey's Avatar
Reputation: 0 joHey is on a distinguished road
France
Hello,
My square setup painted in blue.
Michelin ps cup 265/35 18" all around.
Jump to top joHey is offline   Reply With Quote
Old Mon, May-19-2014, 05:49:33 PM   #125
cyberlando
cyberlando's Avatar
Originally Posted by joHey View Post
Hello,
Hay man where in Germany are you located I'm in wiesbaden?? Wouldn't mind linking up some time
Sent from my SM-G900F using Tapatalk
Engine:
Interior:
Suspension/Handling:
Old Wed, May-21-2014, 12:51:09 PM   #126
joHey
joHey's Avatar
France
Hello ,
I don't live in Germany.
I live in France but near the German border.
I'm approximatively 250km of Wiesbaden.
Old Wed, May-21-2014, 02:58:03 PM   #127
deeznutz972
Reputation: 0 deeznutz972 is on a distinguished road
will 18x9's with 255/35's, mild camber (1-2 degrees), 13/13.5 height, and 12 or 15mm spacer in rear work just fine? Any comments to this setup?
'11 e92 M3 ZCP DCT Lemans/Nappa [Volk, Recaro CS, Corsa, BMW Wheel v2, aero]
'04 M3 AW/Nappa 6-Spd [Evolve airbox, SS V1 headers, TTFS, PSS9, Apex, RTD, Dinan, Sparco]
'14 Accord Sport Sedan
'13 Lexus GX 460 Premium
'11 e90 M3 SG/Nappa 6-Spd [ZCP, leather, slicktop] - Sold
Jump to top deeznutz972 is offline   Reply With Quote
Old Wed, May-21-2014, 04:02:56 PM   #128
bimmerfan08
bimmerfan08's Avatar
It'll work just fine. I run the same size tires, close to those ride heights with 12.5 mm spacers in the rear.
Me...
Front: 2.5 degrees camber, 0 degrees toe
Rear: 1.5 degrees camber, 0 degrees toe
Old Mon, May-15-2017, 06:57:54 AM   #129
ultimateracer28
ultimateracer28's Avatar
Reputation: 0 ultimateracer28 is on a distinguished road
Anyone have experience with 255/40 Michelin PSS's and Dinan springs with 12.5mm spacers in the rear? Looking at this setup for a street driven car and crumbling fenders/shredding tires isn't an option. Also, I've read that the 12.5mm rear still leaves the track width wider at the front. Any measurements out there to confirm?
Jump to top ultimateracer28 is offline   Reply With Quote
18x9, e46, oem, or or m3, pic, request, setup, square
Discussing Pic Request OEM 18x9 Square Set-Up on E46 //M3 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
