Old Thu, Nov-12-2015, 12:54:05 AM   #1
Default Manual Leveling Retrofit for Xenon Cars
So this is a pretty easy mod actually. Allows you to adjust the headlight aim from inside the car like European halogen cars.
There are two parts to this modification. The soldering of an extra resistor, and coding.
Requirements:
  • 1 10KΩ SMD Resistor
  • An LCM Faceplate w/ Manual Leveling
  • NCS Expert
The Resistor:
  • Solder the 10K resistor to the highlighted pad (already added in picture). I used an 0603 resistor since that's what I had on hand, but the pads are meant for a larger one.
  • After you're done with that, install the new faceplate and reinstall the LCM in your car
The Coding:
  • Using NCS Expert, set "LEUCHTWEITENREG_AUTOM" to "nicht_aktiv"
You're done; you should now be able to manually adjust the headlight level from inside the car.
Bonus: Modifying rear-fog ONLY faceplate to front fog.
If you want to retrofit this feature, but don't want to bother with retrofitting rear fogs, and don't want to have a useless button, buy a faceplate meant for cars with rear fogs only.
  • Open up the faceplate (one screw and 4 "clips" -- no DIY, sorry), and remove the fog lamp button (pops out).
  • Under where the button was, you should notice a couple solder pads (highlighted below)
  • A rear fog ONLY switch will have the right pad populated with a 0-ohm link and the left pad empty. Move the link to the left pad.
  • You can now open up your original faceplate, and grab the front-fog button to install in your modified plate.
Final result will look like this:
Old Thu, Nov-12-2015, 12:59:18 AM   #2
LSB FTW
Fear is exciting for me
LSB FTW's Avatar
Reputation: 0 LSB FTW is on a distinguished road
Default Re: Manual Leveling Retrofit for Xenon Cars
I have to do this, Thanks Terra!
Sent from my SM-N910T using Tapatalk
Jump to top LSB FTW is online now   Reply With Quote
Old Thu, Nov-12-2015, 02:07:28 AM   #3
Tchleung
Reputation: 0 Tchleung is on a distinguished road
WHAT
I didn't even know this was a thing!?!!? You are the best.
PS: Checkout the Z4M fan thread on E46F
Follow me on Instagram @tommtomm84
09 X54.4 - Parts Hauler/Daily
02 Carbon Black M3 6MT - Fun Car
462whp/311wtq @ 9.5psi(SuperFlow)
Now at 11 PSI...
4.10 / Headers / ESS VT2-550+
Jump to top Tchleung is offline   Reply With Quote
Old Thu, Nov-12-2015, 01:43:32 PM   #4
SliM3
SliM3's Avatar
I've got to do this
Old Fri, Nov-13-2015, 09:04:58 AM   #5
sergbaja5t
Uncle Grandpa
sergbaja5t's Avatar
Reputation: 0 sergbaja5t is on a distinguished road
Can someone do this for me, as I don't have ncs expert
2016 Ford F150 Screw sport Egoboost
2005 SilberGrau Met/Schwarz M3 Smg, VMR 703 reps, Megan Racing sec 3, Bilstein PSS10/Koni
2002 StahlGrau MET/Schwarz M3 6spd AA headers, Supersprint x-pipe, AA Gen 4 sec3, Besian hub and seals, Turbotoy hardware, Rouge Engineering Vanos & Coolant pipe, Arp studded, H&R/ST/Bilstein coilovers, M220 19's. S54 timing tool w/ two guide pins**FOR RENT** Atlanta valve adjustment service(ask about rates)! Simple coding & DME scanning (Atlanta area)
Jump to top sergbaja5t is offline   Reply With Quote
Old Fri, Nov-13-2015, 01:26:40 PM   #6
ac427
Reputation: 0 ac427 is on a distinguished road
United Kingdom
Great mod. If you want to switch back to auto levelling lights do you just remove the resistor ?
Jump to top ac427 is offline   Reply With Quote
Old Fri, Nov-13-2015, 01:56:19 PM   #7
Just change the coding back
Old Fri, Nov-13-2015, 03:06:59 PM   #8
ac427
United Kingdom
Does anyone know the fascia part number with the manual level adjust in it?
Old Sat, Nov-14-2015, 04:07:24 PM   #9
exodus454
Reputation: 0 exodus454 is on a distinguished road
So wait, this allows you to use a manual leveling faceplate with the US xenon LCM?
I actually just tried to do this the other day, got an entire new LCM (auto, halogen, F/R fogs) from german ebay. Went to swap the faceplate and couldn't manage to code the manual leveling to work. I ended up recoding the new LCM to my car in the end.
Manual leveling is awesome though
I aimed my lows up a little higher and adjusted them down from inside, that way I can turn them back up when needed.. It's really nice!
Jump to top exodus454 is offline   Reply With Quote
Old Sun, Nov-15-2015, 03:08:08 AM   #10
TC2
BF.c Class of 2012
TC2's Avatar
Reputation: 0 TC2 has disabled reputation
Without automatic headlights
- 61318378573
With automatic headlights
- 61316911644
Without automatic headlights + rear fog button
- 61318378572
With automatic headlights + rear fog button
- 61316911645
'84 325e 32k miles|'98 328i 80k miles|'01 Z3 84k miles|'05 M3 63k miles|'05 M3 103k miles|'03 M5 98k miles|'99 M Coupe 104k miles|'00 M5 105k miles|
|'03 C4S 127k miles|'07 Z4 M Coupe 68k miles|'02 PTS X50 996 Turbo 111k miles|'06 X5 4.4i 56k miles
'05 IB|ZCP|Impuls Cloth|Slicktop|SMG II
'05 IR|ZPP|Black Leather|No HK|6MT
Front wheel bearing installation tool for rent. PM me.
Jump to top TC2 is offline   Reply With Quote
Discussing Manual Leveling Retrofit for Xenon Cars in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
