Old Mon, Dec-29-2014, 05:26:47 PM   #21
Kansas Corey
Reputation: 0 Kansas Corey is on a distinguished road
Default Re: LSZ Software Update
terra - sorry for the novice question, but how do you determine version CI34 through CI37? I sincerely doubt my current unit is anything special (original to the car), but with my PO, who knows... I've also got a spare Euro LCM in the garage that I bought for the rear fog light button.
I just didn't know if it's something indicated on the outside / inside of the physical unit or something identified through software. Assume based on this thread, it is visual on the physical unit though.
Jump to top Kansas Corey is offline   Reply With Quote
Old Mon, Dec-29-2014, 05:50:33 PM   #22
Look at the SW number printed on the label
3.56 = CI34
3.6 = CI35
4.0 = CI36
4.5 = CI37
Old Wed, Dec-31-2014, 11:01:43 PM   #23
3.56 appears to be a no-go. Board is identical, but microcontroller is different -- it has a much larger EEPROM and Flash built in. Makes it impossible to use the 4.0/4.5 software
3.6 LCMs are much more common though, and they can all be upgraded
Old Thu, Jan-01-2015, 07:49:04 PM   #24
153624
Reputation: 0 153624 is on a distinguished road
Ireland
Excellent work as always Terra!
Can the sw number be found via inpa?
Any rough idea which build date started with CI35?
Oops .... just read OP again. CI35 in Sept 2003 (MY2004)... seems I'm likely out of luck on this one
Jump to top 153624 is offline   Reply With Quote
Old Thu, Jan-01-2015, 07:52:55 PM   #25
CI35 appears to have started in September 2003. It was used until September 2005
Old Sat, Jan-03-2015, 10:28:13 AM   #26
M3_E4
Reputation: 0 M3_E4 is on a distinguished road
Germany
Its pretty easy to identify, just look at the partsnumber and if its "6 936 xxx" its flashable
Jump to top M3_E4 is offline   Reply With Quote
Old Wed, Jan-21-2015, 04:55:50 PM   #27
ac427
Reputation: 0 ac427 is on a distinguished road
United Kingdom
Can the SW version be read through INPA ?
Jump to top ac427 is offline   Reply With Quote
Old Wed, Jan-21-2015, 10:13:47 PM   #28
Yes. But if you can run INPA, you can probably also just run NCS Expert and read the module. You'll know for sure what coding index you've got then
Old Fri, Jan-23-2015, 09:28:22 PM   #29
Biosphere
Reputation: 0 Biosphere is on a distinguished road
Norway
can it be updated by obd or need bdm ?
anyway good work!
Jump to top Biosphere is offline   Reply With Quote
Old Fri, Jan-23-2015, 09:52:12 PM   #30
anyway good work!
Needs BDM as far as I know. If it can be updated by OBD, BMW didn't tell us how
Discussing LSZ Software Update in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
