Old Wed, Aug-01-2018, 11:45:56 PM   #651
VincentM3E36
Reputation: 0 VincentM3E36 is on a distinguished road
France
Default Re: Comprehensive MSS50 DME information (Euro E36 M3 S50B32 321 PS)
Hi,
It seems that your Alpha N tune was done with approximatly zero adaptation if the car performes very well after you reset them.
How many kilometers or miles do you drive to move from 0% to -25% after you reset your adaptations ? Is it very quick ?
Can you tell us if it is additive or multiplicative adaptation ? Bank 1 or 2 or both ?
Jump to top VincentM3E36 is offline   Reply With Quote
Old Thu, Aug-02-2018, 06:01:28 AM   #652
dafoxm3
Reputation: 0 dafoxm3 is on a distinguished road
Hello Vincent,
I Usually have to only drive 40-50 Kilometres and the adaptations move from 0% to -25%, so very quickly.
the scanner i have is a creator C310, and the readout is;
Multiplicative mixture adaptation (Part load) bank 1 = -24.7
Multiplicative mixture adaptation (Part load) bank 2 = -24.3
Additive Mixture Adaptation Cylinder bank 1 = .36 ms
Additive Mixture Adaptation Cylinder bank 2 = .50 ms
for some time the car was running with on -9% to -13% but now in the -25% range
Jump to top dafoxm3 is offline   Reply With Quote
Old Thu, Aug-02-2018, 06:02:59 AM   #653
dafoxm3
Multiplicative mixture adaptation (Part load) bank 1 = -24.7%
Multiplicative mixture adaptation (Part load) bank 2 = -24.3%
Old Thu, Aug-02-2018, 01:20:11 PM   #654
Olza
Code monkey
Olza's Avatar
Reputation: 0 Olza is on a distinguished road
Belarus
so try to disable adaptations. there is info on this couple messages ago.
Jump to top Olza is offline   Reply With Quote
Old Fri, Aug-03-2018, 12:02:50 AM   #655
Ba114
Reputation: 0 Ba114 is on a distinguished road
if multiplicative (LTFT) is pulling all that fuel, you're too rich in the main fueling map. you need to pull a bunch of fuel.
As always, verify with a wideband
Jump to top Ba114 is offline   Reply With Quote
Old Fri, Aug-03-2018, 07:21:39 AM   #656
dafoxm3
Hi Olza, thanks for that, i have found it. however my XDF does not show these parameters for editing
Hi Ba114, do you know what map is the main map ? is that Lambda target (Table 18x12, offset 0312)
Old Tue, Aug-14-2018, 03:00:26 AM   #657
dafoxm3
Hello gents,
just wondering if anyone has an update ?
would appreciate the help!
Old Tue, Aug-14-2018, 09:49:36 PM   #658
xtremezone
Reputation: 0 xtremezone is on a distinguished road
Netherlands
Hello guys
I donít know how much to highlight on K_HFM_DIAG_ML_MIN on my MSS50, (-5000 ) works fine on the MSS52 / 54 / 54hp, but I'm not sure about the Mss50, how much do you put in minimum value of K_HFM_DIAG_ML_MIN forbdelete a MAF on the M3E36 B32
Please for you help
Thank you
Jump to top xtremezone is offline   Reply With Quote
Old Thu, Aug-16-2018, 04:10:50 AM   #659
abi
Reputation: 0 abi is on a distinguished road
Indonesia
Still can't get that XDF. any other way of getting it.
Jump to top abi is offline   Reply With Quote
Old Sat, Aug-18-2018, 05:54:25 PM   #660
Olza
Code monkey
Olza's Avatar
Belarus
I have my own, what do you want?
Discussing Comprehensive MSS50 DME information (Euro E36 M3 S50B32 321 PS) in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
