Old Mon, Jul-19-2010, 05:17:20 PM   #1
TRACK-CZAR
TRACK-CZAR
TRACK-CZAR's Avatar
Reputation: 0 TRACK-CZAR is on a distinguished road
Default Vanos bolt replacement history
The purpose of this thread is to document the condition of the intake and exhaust Vanos bolts for those of us who have followed the DIY procedure originally listed by Excessive.
Refer to the following link for Exessive's DIY:
http://www.m3forum.net/m3forum/showthread.php?t=321494
Another link by JRM3 can be found here:
http://www.m3forum.net/m3forum/showthread.php?t=326663
Please list the following information for the thread (in the order as shown):
Year:
Build Date:
Intake bolts damaged:
Intake bolts sheared:
Exhaust bolts damaged:
Exhaust bolts sheared:
Work peformed by self/BMW/Indy:
Time spent on replacement (if by self):
Cost of replacement:
Symptoms (if any) prior to work:
List of respondents: Updated 11/2/2010 11:00pm
  1. Boston Duce: 2006, 20K miles, Intake bolts damaged: 0, Intake bolts sheared: 0, Exhaust bolts damaged: 0, Exhaust bolts sheared: 0
  2. Obioban: 2005, 106K miles, Intake bolts damaged: 0, Intake bolts sheared: 0, Exhaust bolts damaged: 0, Exhaust bolts sheared: 0
  3. JRM3: 2002, 83K miles, Intake bolts damaged: 1, Intake bolts sheared: 5, Exhaust bolts damaged: 0, Exhaust bolts sheared: 0
  4. excessive: 2003.5, 100K miles, Intake bolts damaged: 6, Intake bolts sheared: 0, Exhaust bolts damaged: 0, Exhaust bolts sheared: 0
  5. winter737: 2002, ??? miles, Intake bolts damaged: 6, Intake bolts sheared: 0, Exhaust bolts damaged: 0, Exhaust bolts sheared: 0
  6. NikolaiD: 2002, ??? miles, Intake bolts damaged: 0, Intake bolts sheared: 0, Exhaust bolts damaged: 0, Exhaust bolts sheared: 0
  7. knopdm: 2001, 67K miles, Intake bolts damaged: 0, Intake bolts sheared: 0, Exhaust bolts damaged: 0, Exhaust bolts sheared: 0
GONE: 2005 IB ZCP,
NEW: 1997 M3 Sedan, Track Car
Jump to top TRACK-CZAR is offline   Reply With Quote
Old Mon, Jul-19-2010, 05:23:46 PM   #2
Que paso?
http://www.m3forum.net/m3forum/showthread.php?t=326839
_
Old Mon, Jul-19-2010, 05:24:06 PM   #3
TRACK-CZAR
TRACK-CZAR
TRACK-CZAR's Avatar
Posted for Ian:
Year: 2005
Build Date: ?
Work peformed by self/BMW/Indy: self
Time spent on replacement (if by self): ?
Cost of replacement: ?
GONE: 2005 IB ZCP,
Old Mon, Jul-19-2010, 05:34:50 PM   #4
TRACK-CZAR
TRACK-CZAR
TRACK-CZAR's Avatar
I know, I am missing the mileage. I will get to it after my next meeting.
GONE: 2005 IB ZCP,
Old Tue, Jul-20-2010, 12:43:25 PM   #5
3/05 production.
Hard to say exact time, as I did it over a couple days so I could quadruple check everything, but probably 8 hours total?
And gaskets were replaced, so $50 cost
Year: 2005
Build Date: 03/2005
Mileage: 106,000
Time spent on replacement (if by self): 8 hours
Cost of replacement: $50
Old Tue, Jul-20-2010, 01:13:38 PM   #6
JRM3
Reputation: 0 JRM3 will become famous soon enough
Year: 2002
Build Date: April
Mileage: 83K
Work peformed by self/BMW/Indy: self (not finished yet, may need to get car re timed)
Time spent on replacement (if by self): 7 hours
Cost of replacement: $10
Jump to top JRM3 is offline   Reply With Quote
Old Tue, Jul-20-2010, 03:08:36 PM   #7
maveric23
maveric23's Avatar
Reputation: 0 maveric23 is on a distinguished road
Lightbulb
I think that it would be helpful to know any symptoms that result from loose cam gear bolts.
May I suggest the following additions to the template?:
Were there symptoms that made you suspect that you had loose cam bolts?
SES Light On?:
Fault Codes:
If you paid someone to do the work, how much did the labor cost?
Any complications after completing the bolt replacement procedure?
Thanks!
Do you wish that Double VANOS never existed? Vote!
2004 Silver Gray/Black M3 Convertible
Jump to top maveric23 is offline   Reply With Quote
Old Thu, Oct-21-2010, 04:23:45 PM   #8
winter737
winter737's Avatar
Reputation: 0 winter737 is on a distinguished road
Year: 2002
Build Date: 5/2002
Intake bolts sheared: 1/2 through like 4
Work performed by self/BMW/Indy: SELF (son)
Time spent on replacement (if by self): 5 days
Cost of replacement: around 75$
Symptoms (if any) prior to work: Eng rattle like bad valves or exhaust leak increasing worse for about a yr or so thank god we caught it. NO code were thrown. We narrowed issue down by this great M3forum and doing the check on the vanos for looseness.
BMW has a huge issue they are ignoring.
Jump to top winter737 is offline   Reply With Quote
Old Thu, Oct-21-2010, 05:01:33 PM   #9
NikolaiD
NikolaiD's Avatar
Bulgaria
I guess I'll keep it going...
Year: 2002
Build Date: 12/2001
Work peformed by self/BMW/Indy: Self
Time spent on replacement (if by self): Hard to say, i was doing multiple items.
Cost of replacement: Cost of bolts and timing tool. ~ $275.
Symptoms (if any) prior to work: none
MSS54 Error Codes
(work in progress)
Old Thu, Oct-21-2010, 08:27:03 PM   #10
knopdm
Reputation: 0 knopdm has disabled reputation
Year: 2002
Build Date: 11/01
Mileage: 67k
Cost of replacement: ? cost of bolts and gaskets and timing tool rental
2002 E46 M3 Steel Grey, no sunroof
Jump to top knopdm is offline   Reply With Quote
bolt, history, replacement, vanos
Discussing Vanos bolt replacement history in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
