Old Fri, Feb-08-2008, 02:12:25 AM   #11
Poowill
Poowill's Avatar
Reputation: 0 Poowill is on a distinguished road
Originally Posted by RicoJamM3 View Post
Remote start, problem solved...easier said than done tho'.
wwah?
1998 e36 M3 - Sold | 1991 e30 325iX - Sold | 2002 e46 330xi - RIP | 2008 e92 328xi - Sold | 1990 e30 325i Sold
2001 e53 X5 Daily
2005 e46 M3 IB/Cinnamon ZCP 6spd
Jump to top Poowill is offline   Reply With Quote
Old Fri, Feb-08-2008, 09:42:44 PM   #12
dakotabmr
Reputation: 0 dakotabmr is on a distinguished road
Default Tumbler
My 97 M3/4 did the same thing!! tumbler would not move any way, shape or form. had to have mine towed to the dealer and $630 later everything workes fine.................$125 just for the key code!
Jump to top dakotabmr is offline   Reply With Quote
Old Fri, Feb-08-2008, 09:53:58 PM   #13
Poowill
Poowill's Avatar
I'm going to pretend you are just pulling my leg....
2001 e53 X5 Daily
Old Fri, Feb-08-2008, 10:41:23 PM   #14
Ricco
Legalize It !!!
Ricco's Avatar
Reputation: 0 Ricco is on a distinguished road
Jamaica
Originally Posted by Poowill View Post
wwah?
Remote start feature was just an idea, since you may need to insert key anyway.
An alternate solution would be to install a push button start kit (from the Z8) and that would bypass your tumbler issue. Just use keys to open car, and trunk, and push button to start car. My cousin did this install about 4years ago, sorry dont have any pics, but that's what he did.
Jump to top Ricco is offline   Reply With Quote
Old Fri, Feb-08-2008, 10:44:54 PM   #15
Poowill
Poowill's Avatar
Ah, i see what you're saying. But with a push button you'd still have to turn to ACC or Run for the electrical system, I can't do either. So that wouldn't much help me out.
2001 e53 X5 Daily
Old Fri, Feb-08-2008, 10:52:35 PM   #16
Ricco
Legalize It !!!
Ricco's Avatar
Jamaica
try this: http://forums.bimmerforums.com/forum...+lock+cylinder
Old Fri, Feb-08-2008, 10:55:00 PM   #17
Ricco
Legalize It !!!
Ricco's Avatar
Jamaica
And this : http://forums.bimmerforums.com/forum...hlight=tumbler
Old Fri, Feb-08-2008, 11:07:00 PM   #18
mtmpow3r
Reputation: 0 mtmpow3r is on a distinguished road
Exclamation
I had this happen to the wife's M3. Just pop the switch off the back of the ignition tumbler, grab the end of the tumbler with some needle nose and play around with turning it while turning the key to get the tumbler to line up again. It will snap back in and BAM! your back in buiness. I swear upon my life this works. Took me about a half hour, just make sure you loosen the two screws with red locktight on them to get the switch off.
It really works.
Or you can take it to the stealer and get it back 800 dollars later
Jump to top mtmpow3r is offline   Reply With Quote
Old Fri, Feb-08-2008, 11:20:17 PM   #19
Poowill
Poowill's Avatar
thanks man! Don't know how I missed this thread..
I've tried using a bobby pin, but with no luck. I will try with something more heavy duty and hopefully i'll be able to make it work.
2001 e53 X5 Daily
Old Fri, Feb-08-2008, 11:27:42 PM   #20
Poowill
Poowill's Avatar
It really works.
Awesome, thanks for the advice. Glad you were able to get this fixed yourself! Makes me a feel a little better.
So you did or didn't remove the tumbler?
Question though, when putting using the little hole to get the tumber out, what do you pull on to remove it? Does it pop off once I hit the spot with the paperclip?
Thanks again guys I'm hoping with some luck I can get this figured out.
2001 e53 X5 Daily
acc, ignition, move, replacement, stuck, tumbler
No low RPM Power-Ignition Coil Replacement-Cost? jlb532 E46 M3 (2001-2006) 9 Fri, Sep-14-2007 11:50:15 PM
ACC, switched power? ZeroG Audio/In Car Entertainment (I.C.E.) 7 Tue, Mar-20-2007 10:42:07 PM
sterring wheel interface only works in acc Wickedflava Audio/In Car Entertainment (I.C.E.) 1 Mon, Jan-29-2007 06:43:09 AM
Ignition Cylinder/tumbler problem IIrjII E36 M3 (1992-1999) 4 Tue, Jan-03-2006 05:18:54 PM
My Right Headlight Went Out Under Hard ACC M3_guy_84 E46 M3 (2001-2006) 8 Thu, Dec-01-2005 02:40:57 AM
Discussing Ignition Stuck in Acc, won't move. Tumbler Replacement? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
