Old Fri, May-21-2010, 04:36:22 AM   #1
tnomud
tnomud's Avatar
Reputation: 0 tnomud is on a distinguished road
Default 04 M3 Track Car > pop > fire > fix
Ok, creating a new thread for the future help of others.
Car: 04 M3 SMG
MODS: H&R coil overs, f&r bars, camber plates, 6 piston Rotors up front, 4 piston rotors in rear, Dinan Intake, Dinan MAF, Dinan TB's, B&B header, B&B exhaust, rasp elim, catless, 18X10 Enkies, 275 Falkens, CF hood, CF trunk, Sparco seats, belts, 6 point cage, aftermarket dogbox (still SMG config.), alum flywheel, delrin bushings on all suspension, billet subframe, motor, and trans mounts, CF driveshaft, Cams, gutted, 10 qt oil capacity, FM oil cooler, Tranny cooler, AC removed, airbags removed, seam welded unibody, 2918lbs, unknown HP. There is a bunch more stuff done, but I cant remember it all off the top of my head.
Fresh motor with under 2K (IIRC) grenades at Tally during an open track day. As a result, oil caught fire as it left the motor. Lost brakes, got out safely. It appears that the last 2 cyliners have gone through the block. Fire travelled back into the motor, so it will have to be pulled to know 100% (pics will follow as this happens). FOund parts of internals on drivers side of engine bay tonight whil cleaning it up for the autopsy. Hole is on passenger side behind headers.
Before:
during:
aftermath:
-04 E46 M3 SMG-
Jump to top tnomud is offline   Reply With Quote
Old Fri, May-21-2010, 04:44:05 AM   #2
xM P0W3Rx
Dan the VANOS man
xM P0W3Rx's Avatar
Reputation: 0 xM P0W3Rx is on a distinguished road
damn dude. throw an S85 in that *****.
My Reviews
Jump to top xM P0W3Rx is offline   Reply With Quote
Old Fri, May-21-2010, 05:31:01 AM   #3
DOCTOR 3VIL
DOCTOR 3VIL's Avatar
Reputation: 0 DOCTOR 3VIL is on a distinguished road
Armenia
wow what a beautifull car and look what happened to it
02 E46 M3 Jet Black
11 E92 M3 Le Mans Blue
Jump to top DOCTOR 3VIL is offline   Reply With Quote
Old Fri, May-21-2010, 06:45:12 AM   #4
jaykalia
Starships - Meant To Fly
jaykalia's Avatar
Reputation: 0 jaykalia is on a distinguished road
I second that emotion.
2001 LSB ///M3
Jump to top jaykalia is offline   Reply With Quote
Old Fri, May-21-2010, 06:52:55 AM   #5
Smalec
fattie
Reputation: 0 Smalec has disabled reputation
Russian Federation
Keep us posted
Jump to top Smalec is offline   Reply With Quote
Old Fri, May-21-2010, 06:56:51 AM   #6
azngolf
azngolf's Avatar
Reputation: 0 azngolf is on a distinguished road
Viet Nam
that sucks... keep us posted on what you plan to do next
03.5 SG:
CURRENT MODS
A little here and little there...
Jump to top azngolf is offline   Reply With Quote
Old Fri, May-21-2010, 07:47:07 AM   #7
Waitwhat
Reputation: 0 Waitwhat is on a distinguished road
South Africa
I like the way the ///M badge still shines through, like it won't be beaten.
Good luck with the repair.
Jump to top Waitwhat is offline   Reply With Quote
Old Fri, May-21-2010, 08:12:29 AM   #8
eas
eas's Avatar
Reputation: 0 eas is on a distinguished road
Sorry to hear, hope everything works out for you.
Customer Service | european auto source (eas)
email: info@europeanautosource.com web: www.europeanautosource.com
tel 866.669.0705 | ca: 714.369.8524 | fax: 714.908.1796
Blog | Facebook | YouTube | Flickr
Jump to top eas is offline   Reply With Quote
Old Fri, May-21-2010, 12:55:37 PM   #9
roobe16
Certified Naysayer
roobe16's Avatar
Reputation: 0 roobe16 is on a distinguished road
Antarctica
Damn that's awful.
Jump to top roobe16 is offline   Reply With Quote
Old Fri, May-21-2010, 01:00:03 PM   #10
redice
hello
redice's Avatar
Reputation: 0 redice is on a distinguished road
yikes! good luck with everything and do keep us posted on updates
Jump to top redice is offline   Reply With Quote
>, car, fire, fix, pop, track
Discussing 04 M3 Track Car > pop > fire > fix in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
