Old Mon, Jan-11-2010, 08:50:56 PM   #21
cstern
Reputation: 0 cstern is on a distinguished road
Its a slightly easier fix. I had the same problem. One door was tied to the other to keep it shut.... Anyway I picked up a door latch assembly off ebay for about $40. It included the actuator even though mine worked fine.
You will need to do most of that DIY. You will have to remove the window and the track for it to get the latch mechanism out of there. Its still a pain, but I managed to do it without and previous knowledge of this DIY in about an 1.5 hours. Its not too bad, but definitely an annoying problem to have.
Jump to top cstern is offline   Reply With Quote
Old Mon, Jan-11-2010, 09:36:07 PM   #22
Diesel///M3
Oh no you d'nt!
Diesel///M3's Avatar
Reputation: 0 Diesel///M3 has disabled reputation
By door latch assembly do you mean the door locking mechanism? Is it part # 51-21-1-977-113? I found this online for about $150 new. Do you happen to have a part # for the part you replaced?
"Its not who we are underneath, but what we do that defines us."
-Jay
Upgrades: AA Gen III, AA track pipe, AA tune, H&R Sports, blown Bilsteins, TMS aluminum RSMs, UUC tranny mounts(red), UUC sways, TMS RTABs, M50, CAI, 10mm front spacers, X-brace, Brembo/Hawk, SS brake lines, ltw flywheel/JB clutch, CDV delete, Alpine HU
Coming soon: Powerflex subframe bushings, RE RSMs, UUC RTABS, Koni's, AA diff support bracket, new diff mounts, AA 3.5" CAI, Euro 3.5" HFM, Bimmerworld 3.5'-3" elbow, UUC SSK/DSSR, 140a alternator, 6000K HID heads and fogs...
Jump to top Diesel///M3 is offline   Reply With Quote
Old Mon, Jan-11-2010, 10:19:36 PM   #23
cstern
I replaced number 9. Part number 51228122419 for left and ending in 20 for right.
Link on ebay: http://cgi.ebay.com/ebaymotors/DOOR-...item56334767e4
Less than $30 shipped.
Old Fri, Jan-18-2013, 03:58:15 AM   #24
EasyEd
Reputation: 0 EasyEd is on a distinguished road
Default Re: Door stuck closed? Lock actuator broken? Here's the fix...
Hello! Wife came home with "honey, the right rear door won't open"
Great post helping me out 6-7 years later.
Just noticed that you can replace the actuator thru the now empty door handle slot (if you have small enough hands!). So I hope I don't have to go thru the trouble of taking out the window!
Still have to put everything back together.
Actuator started working after I played with it(took it apart). But I don't trust it, and will replace it.
Thank you again for posting.
Ed
Now to go back to the ABS ASC gremlin.
Jump to top EasyEd is offline   Reply With Quote
Old Fri, Jan-18-2013, 04:28:18 PM   #25
egebhardt
egebhardt's Avatar
Originally Posted by M3kindathing View Post
nice write up. I can still pull lock knob up and down on my sedan right rear door but the remote is note actuating it? Is it the same problem? In the steps you describe where would I have to stop to change the actuator? At the point where the actuator is out right?
Yes. You have the same problem. Remove the old actuator. Put the new one in.
Great write up Brandon
It's a shame Coupes are 10x harder than that
It is not harder on a coupe. It is not necessary to remove the window on a coupe. Just remove the door panel.
Do you have a sedan or a coupe? It may be necessary to remove the window on a sedan. I don't know yet. I have this exact problem but have not fixed it yet. My coupe had this problem and I did not have to remove the window.
97 Byzanz on Black 4dr - Bot 6.13.19
97 Byzanz on Magma 4dr - Sold 7.7.17 Jerad in CO
Old Fri, Jan-18-2013, 05:10:11 PM   #26
Brandon318
Reputation: 0 Brandon318 is on a distinguished road
Glad it helped! I love seeing old DIYs stand the test of time haha.
/// Brandon
Jump to top Brandon318 is offline   Reply With Quote
Old Sat, Jul-26-2014, 10:24:04 PM   #27
berny2435
Reputation: 0 berny2435 is on a distinguished road
I'll try and add a couple things to this DIY. Thank you for posting it. definitely helped.
I also looked at this DIY
http://www.bimmerfest.com/forums/sho...d.php?t=131544
I was in the same position, rear door was stuck locked and the symptoms said that the lock actuator was faulty. It would randomly not unlock and then would stay locked for the longest time. I got really lucky and the rear passenger door randomly came unlocked by itself after staying locked for the longest time.
I ran into a couple issues
1.) the Head snapped off of the plastic screw holding the little white plastic lever for the door lock knob broke on me. I had to pry the white lever off of it. I first lubed it up with some penetrating oil and used a trim pry bar. L shaped.
2.) I thought I needed to take the door handle trim off, as well as the door handle free of the door, but that wasn't the case. I tried to get it off but it wasn't happending for me. Luckily, my patience (rare), paid off and I was able to wiggle the door lock assembly and the electrical actuator down and in a position where I didn't need to removed the window track or the door handle.
a.) just use a medium and a small flat head screw driver to pry the actuator off of the door lock assembly.
b.) wedge the door lock assembly down as far as you can basically
c.) pull the actuator with the wire connector still attached, out of the door
d.) replace. I had a hard time getting it back on the door lock assembly but after I lubed the connection with lithium grease, it made it easier.
98' M3 4dr, 06' S2000. SCCA member
Jump to top berny2435 is offline   Reply With Quote
Old Sun, Jul-27-2014, 12:18:09 AM   #28
egebhardt
egebhardt's Avatar
Update:
I finally did this job on a sedan.
I had to remove the window on the sedan, and the rail too.
On top of it all, I the old actuator nearly fell out. The clip in the door was really loose.
I had to rig a way to keep the new actuator seated, otherwise it would pop out of place and not work.
Ultimately, this took me 8 hours because of the failure of Part#9 to hold the actuator in place.
Old Mon, Nov-21-2016, 02:27:18 AM   #29
elmessican
Reputation: 0 elmessican is on a distinguished road
Why can't I see the Pictures?
Jump to top elmessican is offline   Reply With Quote
Old Mon, Nov-21-2016, 02:53:10 AM   #30
Evtron
Evtron's Avatar
Reputation: 0 Evtron is on a distinguished road
Because this thread is over 10 years old.
E36 M3 Sedan Journal
Jump to top Evtron is offline   Reply With Quote
actuator, broken, closed, door, fix, lock, stuck
Door lock actuator? Dreams190 E36 M3 (1992-1999) 20 Thu, May-16-2013 09:44:42 PM
Door stuck in lock position with door open! GotM? E46 M3 (2001-2006) 0 Mon, Aug-04-2008 01:08:23 PM
Changed Door Lock Actuator - Now NO Power Locks!! Suncoast E36 M3 (1992-1999) 1 Sat, Jan-13-2007 06:50:15 PM
Door lock actuator pic/part #?? LagunaE46 E46 M3 (2001-2006) 10 Sun, Nov-05-2006 04:28:57 PM
HELP with door lock actuator c_tejuco E36 M3 (1992-1999) 2 Tue, Jul-26-2005 04:36:53 AM
Discussing Door stuck closed? Lock actuator broken? Here's the fix... in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
