Old Fri, Apr-06-2018, 12:22:41 AM   #11
Default Re: Keep Rouge SSK or go back to OEM
Oval.
Old Fri, Apr-06-2018, 03:36:16 AM   #12
PITT M3 RR
PA
PITT M3 RR's Avatar
Had mine all apart today. I didn’t realize it until now, bmw separates the lower and upper portion of the shifter rod and fills it with an adhesive rubber to dampen the feel. Personally I’m not a fan of that. Rogue did the same thing. Hold the bottom of the shifter rod that goes to the selector rod and then grab the part where the knob goes...you can twist them independently of each other.
I just drilled perpendicular holes slightly offset from each other and ran aluminum rod through. I left like 3mm hanging out each end and flared it so they can’t slide out...now the shifter is solid with out that rotational give.
S54 E36 BUILD
Discussing Keep Rouge SSK or go back to OEM in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
