Old Fri, Mar-23-2018, 12:20:03 AM   #21
Solaris99
Reputation: 0 Solaris99 is on a distinguished road
Default Re: What's wrong?
At extremely high speeds, the springs don't react quickly enough to pull the valves back before the piston meets them.
1999 BMW M3
2009 Chevy Cobalt SS turbocharged coupe
2000 Ford F350 7.3L 4x4
Jump to top Solaris99 is offline   Reply With Quote
Old Fri, Mar-23-2018, 08:13:56 PM   #22
frbz
I believe it is called valve float
Jump to top frbz is offline   Reply With Quote
Old Fri, Mar-23-2018, 11:15:39 PM   #23
Valve float and I would also think the tensioner loaded timing chain has a reaction limitation (forcing into the wrong gear shoots the rpm up quickly) and speed limitation.
Money shifts can also spin the oil pump nut off. The rebuilt motor in my 96 came from my cousin's car who did this. Chewed up the crank and the cams were goners due to the oil starvation. There were only 12 bent valves and they were mild.
Old Sat, Mar-24-2018, 04:44:12 AM   #24
bip_m3
bip_m3's Avatar
Reputation: 0 bip_m3 is on a distinguished road
gives you a great reason for a project. The s50 around 150k of abuse should be refreshed at least. Good luck!
90 alpine e30 m3 sold
87 alpine e30 325ix sold
95 dakar e36 m3
Jump to top bip_m3 is offline   Reply With Quote
Old Sat, Mar-24-2018, 05:20:27 PM   #25
Ajcanadian
Reputation: 0 Ajcanadian is on a distinguished road
Alright guys the heads off. Pistons had no damage. But in the gasket there was some valve seat. Machine guy things its the valve guide. But it has more tear down to go.
Jump to top Ajcanadian is offline   Reply With Quote
Old Sat, Mar-24-2018, 06:24:05 PM   #26
Ajcanadian
Old Sat, Mar-24-2018, 06:26:48 PM   #27
Ajcanadian
https://drive.google.com/drive/folde...eY?usp=sharing
For some odd reason I cannot upload the remaining pics. So, I've attached a link to a google docs that I'll be updating
Old Tue, Mar-27-2018, 05:53:04 PM   #28
Ajcanadian
Originally Posted by westopher View Post
Its a mechanical overrev that will mash pistons into the valves. It will pit the pistons, bend valves and can cause damage to the head.
The pistons looked fine. Machine shop hasn't taken the head apart yet. But he thinks it's bad valve guides.
Old Tue, Mar-27-2018, 05:53:30 PM   #29
Ajcanadian
Yessir, The head's out to the machine shop but it sucks that the m3 is my only car.
Old Tue, Mar-27-2018, 05:54:39 PM   #30
Ajcanadian
Quick side question for ya. So on the m3 whenever I opened the expansion tank it had pressure in it. Even if the car was cold. The day before the compression test while the car was running and driving great a radiator hose popped off. Does this have any connection to my cylinder 4 & 5 having low compression?
Discussing What's wrong? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
