Old Sun, Jul-10-2016, 03:45:48 AM   #31
frbz
Default Re: OEM Plus Eurospec M3 Build
What is your oil temp running. My car gets to the middle of the water temp gauge very quickly, within a few km and it also produces heat very quickly when it is cold out. The oil temp is not buffered and takes 15+km to get up to about 80-90c. On the track it gets all the way up to 105c with ambient at about 25-27c.
Jump to top frbz is offline   Reply With Quote
Old Sun, Jul-10-2016, 09:55:30 AM   #32
digger
the higher operating temps are usually for emission and economy reasons, its not a performance (hp) thing. one problem with extra heat is the plastics and rubbers degrade quicker so you need to keep upto date with the maintenance of the cooling system and other bits in the engine bay
1996 e36 M3 Evo
Jump to top digger is offline   Reply With Quote
Old Mon, Jul-11-2016, 12:43:59 AM   #33
_JohnnyD_
Reputation: 0 _JohnnyD_ is on a distinguished road
This is a very good description of what happens with my car. The oil temp hits about 90C after 10 minutes of casual driving.
Jump to top _JohnnyD_ is online now   Reply With Quote
Old Mon, Jul-11-2016, 12:59:06 AM   #34
_JohnnyD_
After a few weeks of crazy work and vacation I'm back working on the M3.
Today I did an oil change and front end face lift. (and ordered cooling system parts)
The old...
The new...
Let's call it front end phase 1.
I know you all loved the license plate holders but the tow hook holder works a little better. I also went with the US M3 luxury lower grill in place of the white mesh. I think it matches the larger louvers of the kidney grills. What do you think?
Old Mon, Jul-11-2016, 02:10:46 AM   #35
cblock
cblock's Avatar
Love lux slats!
Cblock
Jump to top cblock is offline   Reply With Quote
Old Mon, Jul-11-2016, 04:05:30 AM   #36
digger
i've always loved white
1996 e36 M3 Evo
Old Mon, Jul-11-2016, 02:45:17 PM   #37
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Originally Posted by cblock View Post
Love lux slats!
But don't protect the condensor/radiator like the mesh does.
I've had rocks trapped in the mesh before. With the slats, they would've gone straight through the mentioned parts.
Don't know which plate holder is worse. Both are not OK. Why not use the orginal one?
Old Mon, Jul-11-2016, 08:39:08 PM   #38
cblock
cblock's Avatar
Good point.
Cblock
Old Mon, Jul-11-2016, 10:05:58 PM   #39
Kirbius
Kirbius's Avatar
Reputation: 0 Kirbius is on a distinguished road
Agreed, both look odd
Sent from my SM-G900I using Tapatalk
1996 Evo S50B32 - Boston Green on Modena - Slicktop - Al doors - PDC - JBR 5kg F/W - Clutchmasters FX400 - Mason SS Clutch pedal - UUC Evo3 SSK w/DSSR - PWR radiator - DrVanos o/haul - Full AKG 75D bushing & mount set - AP delete - Fan delete - X-brace - BC Racing C/Os 8k/10k - Whiteline 27mm ARB - ARC8 17x8.5 - Nitto NT01 - APEX 75mm stud - Walbro GSS342 - Schroth Harness - TMS rear control arms - Hawk HP+ pads - GT splitter - GT 4pc wing - Momo Monte Carlo - Racechrono TS - RaceDAC - RR Strut Brace - Proflow PS res + AN lines - VDO gaugeset - E46 330 rack - VAC oil pump upgrade - ARP conrod bolts - Magnaflow spun cats - MAC Motoren Airbox - AlphaN - ATI/VAC HB - 3.91 210 -
Jump to top Kirbius is offline   Reply With Quote
Old Tue, Jul-12-2016, 03:52:28 AM   #40
_JohnnyD_
The original attachments are spaced for a european sized number plate which is much wider. (You can see the holes in the original black trim)
The way Canadian dealers fitted the front license plate is drill holes in the bumper below the center trim strip and then add a plastic bracket for the number plate.
I didn't want to drill into my bumper!
The plate holder is actually this...
http://www.usmillworks.com/bmw_front..._tow_hook.html
Discussing OEM Plus Eurospec M3 Build in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
