Old Fri, Dec-05-2008, 01:15:09 AM   #41
zottyzot
zottyzot's Avatar
Reputation: 0 zottyzot is on a distinguished road
Uughhh, I cant believe I just tore the solder points off the board...I had the wires soldered on, i was trying to remount the tape deck in the headunit and I fu*king bent the wires to hard! All three came off at once...Will the head unit operate without the tape deck in?
Jump to top zottyzot is offline   Reply With Quote
Old Fri, Dec-05-2008, 02:18:30 AM   #42
zoti
Reputation: 0 zoti is on a distinguished road
Mount the wires to a point on the board that is connected to those solder points you broke. You're not going to use the tape anyway.
Jump to top zoti is offline   Reply With Quote
Old Fri, Dec-05-2008, 11:25:30 AM   #43
zottyzot
zottyzot's Avatar
You mean just follow the metallic line on the board to the next solder point? I was thinking of soldering in where the tape deck connects to the rest of the head unit, the computer style multi pin connector you mentioned in the original DIY. I was looking at that connector, looks pretty solid. From what I can tell the first 5 pins on the left are the audio, the center of those five has the fatest lead going to it, so maybe thats ground? Would there be 4 chanels out? fr, fl, rr, rl ?
Old Fri, Dec-05-2008, 01:51:01 PM   #44
zoti
I wouldn't solder anything to the main board. If you screw that up then you destroy your radio.
Just find a solder point that connects to where you broke it off. Post a picture of the damage. Shouldn't be too hard to fix.
BTW, the tape only has L and R channels. The headunit then takes that and splits each channel to FL, FR, RL, RR.
Old Fri, Dec-05-2008, 02:16:42 PM   #45
zottyzot
zottyzot's Avatar
Originally Posted by zottyzot View Post
I was thinking of soldering to the posts across the bottom of this board. They are the back side of the connector that clips to the main board. Should be a much stronger solder point. The one that broke was a surface mount, not a through mount.
Old Fri, Dec-05-2008, 03:46:30 PM   #46
zoti
Use a voltmeter to determine which point at the bottom connects to what point at the tape head connection at the top left and you should be fine.
Old Fri, Dec-05-2008, 05:08:23 PM   #47
zottyzot
zottyzot's Avatar
I'll be checking for continuity correct? So I shouldnt need power.
Old Fri, Dec-05-2008, 07:11:04 PM   #48
zoti
yes. check for continuity.
Old Tue, Dec-09-2008, 12:56:05 AM   #49
zottyzot
zottyzot's Avatar
....Well, I had to take a break from the radio project, but I got back into it last night. First off I went out and bought a 13.8v @ 3 amp DC power supply. I cant get it to power the radio. I connected 12v+ to terminal #'s 5&9 and ground to terminal 15. No dice. I picked three solder points on the bottom row I mentioned earlier and soldered leads to them and connected a 1/8" jack to those leads. I removed the spring and taped the arm thing on the top of the tape deck. I connected the head unit to the car and I get a "tape error" message. Tuner and cd changer operate fine. I even tried using an empty cassette tape to fool the player it kept spitting it back out. So anyhow, I cant even determine if the solder points I chose were the right ones because I cant get the tape deck to activate. Does anyone have any suggestions. I was wondering if I could cut power to the tape motor, that may work, but it may also cause an error....I searched here and googled "c43 aux input" and several variations, I couldnt find sh*t.
Old Tue, Dec-09-2008, 06:17:16 AM   #50
zoti
Try to remove the tape and put the spring back on the arm. Basicly, don't do the "trick the tape to think there is a cassette in it" thing I did and see if that fixes the error.
adding, auxiliary, c33, diy, input, radio
DIY - Auxiliary Audio Input Kit JerDevil E46 M3 (2001-2006) 54 Fri, Mar-30-2012 06:22:39 PM
Need auxiliary input install help R Salesman Audio/In Car Entertainment (I.C.E.) 5 Mon, Jul-30-2007 06:37:41 PM
Alpine C33 radio tool vs Blaupunkt C34 radio tool bigneil E36 M3 (1992-1999) 1 Sun, Aug-13-2006 11:48:53 AM
Auxiliary Input Install halt00 E46 M3 (2001-2006) 30 Wed, May-05-2004 01:56:22 AM
Where is the auxiliary input located? Jared Kaplan E46 M3 (2001-2006) 7 Wed, Mar-26-2003 09:42:14 PM
Discussing DIY - Adding auxiliary input to your radio (C33) in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
