Old Wed, Dec-03-2008, 09:32:37 PM   #31
zottyzot
zottyzot's Avatar
Reputation: 0 zottyzot is on a distinguished road
Well, I took out and disassembled my head unit...The circuit board on the back of my tape mechanism looks nothing like the pic.* If anyone can help, I could use it.*edit* It appears I have a c43...
Jump to top zottyzot is offline   Reply With Quote
Old Thu, Dec-04-2008, 03:21:00 AM   #32
zoti
Reputation: 0 zoti is on a distinguished road
Post a really big close up picture of the circuit board on the tape mechanism.
Jump to top zoti is offline   Reply With Quote
Old Thu, Dec-04-2008, 12:31:00 PM   #33
zottyzot
zottyzot's Avatar
Here's a pic of the circuit board on the back of the tape deck.
Old Thu, Dec-04-2008, 10:52:33 PM   #34
zoti
Post one from a similar angle to the one below.
In the picture below you can see 2 PCB (electronic boards). The one on the back like in the picture you posted and the one which is on the top of the tape mechanism. The second board was covered by a metal plate which was held by 2 screws. Try to find that board on your tape mechanism.
If you look closely right above where the wires are soldered into the back PCB you will be able to see the following markings: S-GND (ground), L-CH (left channel) and R (Right Channel). The correspond with the connections I made at the back PCB.
Those are the connection we are trying to find on your top PCB. Try to find them and post a picture so we can confirm.
Old Thu, Dec-04-2008, 11:23:04 PM   #35
zottyzot
zottyzot's Avatar
Okie Dokie, here's what I've got. First, there is no circuit board on TOP of the deck, only the one on the back. I can make out some solder points that are labeled LF, LR, RF, RR, and GND, I assume these are speaker points, I cant find an RC or LC. But here are some pics.This is the bottom/back of the head unit itself...
Old Thu, Dec-04-2008, 11:25:47 PM   #36
zottyzot
zottyzot's Avatar
OK!! How do I get the pics and the text the way I want?? The text always seems to wrap around in ways I dont intend...
Old Thu, Dec-04-2008, 11:41:50 PM   #37
zoti
You see that brown tape on the left side of the tape mechanism? It goes from the cassette reading head to the board. It's a bit hard to see in the picture but it does have 3 wires in it, right?
I believe this is where you want to tap in but I suggest you test everything first before you solder and close the radio.
Old Thu, Dec-04-2008, 11:51:23 PM   #38
zottyzot
zottyzot's Avatar
It actually has 5 wires in it...It's hard to tell but it looks like the two outermost on either side are joined at the circuit board and only the center one remains solo. So, if thats correct, yes there are only 3 wires. If ya know what I'm sayin.
Old Fri, Dec-05-2008, 12:02:04 AM   #39
zoti
It has 5 wires because the head can read side A and side B of the tape. That is why the 5 wires turn into 3. Each left channel is joined together and then each right channel as well while ground is just 1 wire. You will need to find teh L and R channels by hooking it up and then playing with the Balance feature on the tape. If it work correctly you got it right. If it is switched then you got it wrong.
Old Fri, Dec-05-2008, 12:14:37 AM   #40
zottyzot
zottyzot's Avatar
You are apparently "Da man" , Thanks Zoti I'll let you know how it works.
adding, auxiliary, c33, diy, input, radio
DIY - Auxiliary Audio Input Kit JerDevil E46 M3 (2001-2006) 54 Fri, Mar-30-2012 06:22:39 PM
Need auxiliary input install help R Salesman Audio/In Car Entertainment (I.C.E.) 5 Mon, Jul-30-2007 06:37:41 PM
Alpine C33 radio tool vs Blaupunkt C34 radio tool bigneil E36 M3 (1992-1999) 1 Sun, Aug-13-2006 11:48:53 AM
Auxiliary Input Install halt00 E46 M3 (2001-2006) 30 Wed, May-05-2004 01:56:22 AM
Where is the auxiliary input located? Jared Kaplan E46 M3 (2001-2006) 7 Wed, Mar-26-2003 09:42:14 PM
Discussing DIY - Adding auxiliary input to your radio (C33) in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
