Old Sun, Feb-01-2009, 09:10:30 PM   #1
wally828
Reputation: 0 wally828 is on a distinguished road
Default Power Steering Fluid/ATF?
I've searched the forum for power steering fluid posts, but I haven't quite found what I'm looking for. I know that I'm supposed to use ATF with Dexron III or IV, but when I looked at the bottles at the parts store, they all say they're for Ford, GM, Toyota, Nissan, Chrysler...etc. No where did I see anything about BMW. I've seen some posts that say any ATF III or IV fluid is fine, does car specification on the bottle not matter? And my PS hose is leaking a little bit, any suggestions on specific stop leaks to use? This is what I saw at O'Reily's, and Advance wasn't much different. I just don't want to make a mistake.
Jump to top wally828 is offline   Reply With Quote
Old Sun, Feb-01-2009, 10:44:47 PM   #2
wally828
And here's what Advance had. I picked up the castrol dexron IV because I'm going out of town tomorrow and I needed to top off the resevoir, and it was really the only one that said dexron IV.
Old Sun, Feb-01-2009, 11:43:24 PM   #3
deilenberger
deilenberger's Avatar
the Valvoline Dexron-IV would be fine. And you won't see BMW on the bottle - they aren't considering using it for power steering - only auto-transmissions.
  • 2011 Lexus RX-350. SWMBO's toy.
Old Mon, Feb-02-2009, 12:40:36 AM   #4
NetFixer
NetFixer's Avatar
Reputation: 0 NetFixer is on a distinguished road
I orded from Tischer a while back and they sent me Castrol Import Multi-Vehicle ATF.
2005 AW M3S. S for stock!
Jump to top NetFixer is offline   Reply With Quote
Old Mon, Apr-29-2013, 12:39:26 AM   #5
LSB FTW
Fear is exciting for me
LSB FTW's Avatar
Reputation: 0 LSB FTW is on a distinguished road
Default Re: Power Steering Fluid/ATF?
whats the total amount of require ATF? 1L?
Jump to top LSB FTW is online now   Reply With Quote
Old Mon, Apr-29-2013, 12:51:33 AM   #6
wiry
wiry's Avatar
Reputation: 0 wiry is on a distinguished road
I use that same Castrol fluid in mine, and before I sold my 330 I used it in that as well. Haven't had any issues.
Jump to top wiry is offline   Reply With Quote
Old Mon, Apr-29-2013, 02:36:18 AM   #7
kuksul08
http://www.nexternal.com/bimmerworl/...20d4%20atf.jpg
I used the whole quart, flushing the system 3 times.
fluid or atf, power, steering
Power Steering Fluid : Mobil 1 ATF ? Or OEM ? M3Seeto E46 M3 (2001-2006) 2 Mon, Oct-20-2008 04:22:08 AM
How much power steering fluid? mpegripper E46 M3 (2001-2006) 2 Wed, Apr-11-2007 01:28:45 AM
Power Steering fluid? which is better? Techno ///M3 E36 M3 (1992-1999) 27 Fri, Dec-01-2006 12:39:31 PM
Power Steering Fluid? ThewsM3 E36 M3 (1992-1999) 3 Thu, Jun-15-2006 05:58:55 PM
What Power Steering Fluid to use? 2pak E46 M3 (2001-2006) 3 Tue, Mar-28-2006 01:48:58 AM
Discussing Power Steering Fluid/ATF? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
