Old Sun, Nov-05-2006, 12:16:29 AM   #71
Originally Posted by Need4Spd
Yes, I can see them by clicking on these links but the embedded tags don't seem to work, for just these pics. The before and after ones are fine. Puzzling.:nixweiss:
how about
http://www.lindvigs.com/obioban/adaptive2.htm
Old Sun, Nov-05-2006, 03:27:43 PM   #72
Need4Spd
Need4Spd's Avatar
Reputation: 0 Need4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond repute
how about
It works! Thanks for updating your site. I hope it wasn't me who was the only one having this issue, so that your work benefitted a wider audience! (BTW, the link in your sig has the same issue.)
Past car: '05 M3 'vert, 6MT, custom 18" RAC RG63 Hyperblack monolites, Continental Extreme DW 245/40 and 275/35, Nav, HK, BT, Euro rotors, Custom Performance Rasp Terminator (2nd Gen.), Silverline DICE iPod adapter, EAS Aurora 60 LED Angel Eyes, "-CDV," "free & easy" camber mod (-1.7 degrees), Koni S/A shocks, Rogue Engineering RSMs and transmission mounts, Bimmerworld silicone intake boot, spacesaver spare from LeatherZ, updated OEM RTABS
'11 Jaguar XFR
Jump to top Need4Spd is offline   Reply With Quote
Old Sun, Nov-05-2006, 07:59:23 PM   #73
fixed. Making sure the new one worked, first.
Text in the new one sure is big
Old Fri, Feb-15-2019, 05:06:00 AM   #74
Whitehawk8
Whitehawk8's Avatar
Reputation: 0 Whitehawk8 is on a distinguished road
Default Re: New Guide: Enabling the outer LED ring on OEM tail lights
Taking this wayyyyy back. The original link in this thread is no longer working. Couldn't fine a guide on how to do this mod with RETROFITTED LED's. If someone knows of an updated link your help would be much appreciated!
2003 M3 StahlGrau Metallic | Beisan | JB Racing | Koni | CMP | TMS | OEM SSK
Jump to top Whitehawk8 is offline   Reply With Quote
Old Fri, Feb-15-2019, 03:50:43 PM   #75
Whitehawk8
Whitehawk8's Avatar
mid day bump
Old Sat, Feb-16-2019, 12:27:41 AM   #76
nervous24
Reputation: 0 nervous24 is on a distinguished road
Originally Posted by Whitehawk8 View Post
mid day bump
There is very literally a link at the top of this page...
2003.5 Carbon Black ///M3 @_weaponM
SMG>CAE (1st no drop swap) | MCS | SuperSprint | Rogue | Turner | Bimmerworld | Vorshlag | Hyperco | AKG | PFC | Status Gruppe | Apex | Beisan
Jump to top nervous24 is offline   Reply With Quote
Old Sat, Feb-16-2019, 02:56:25 AM   #77
Whitehawk8
Whitehawk8's Avatar
That link is very literally for cars that have NOT retro fitted LEDs...
Old Sat, Feb-16-2019, 01:42:22 PM   #78
It'll be pretty much the same. Instead of splicing into a wire that's already there, you're adding a wire and splicing into that.
Old Sat, Feb-16-2019, 04:09:16 PM   #79
SQ13
Maybe this will help a little.
A wire needs to be added to 4 or 6 (donít remember which one, just check the harness). To do that, you need to open up the front of the connector by releasing I think two tabs then insert the wire. Idk what itís called but the wire has a metal tip that is made to work with the connector. Then splice together the wires at 4 and 6.
Old Sat, Feb-16-2019, 09:02:45 PM   #80
Whitehawk8
Whitehawk8's Avatar
Thanks guys! Will take a look when I get my car back. Cheers
enabling, guide, led, lights, oem, outer, ring, tail
i have oem led tail lights on my 02 vert..how to get the outer rings working? jateshk E46 M3 (2001-2006) 2 Wed, Aug-13-2008 05:28:17 PM
FS: Complete OEM COUPE LED TAIL LIGHTS W/ TRUNK LIGHTS $350 AliM3 Parts for Sale/Wanted 7 Sun, May-25-2008 04:06:39 AM
Can the outer LED ring of Umnitza Tails be wired to light up with brake lights? Quicke46 E46 M3 (2001-2006) 16 Wed, Apr-16-2008 10:15:54 PM
Outer ring of tail light LEDS....now working??? Bents E46 M3 (2001-2006) 7 Sun, Jan-28-2007 01:37:44 PM
Retrofitting LED tail light without the error light but with the outer ring lit!! hotcello E46 M3 (2001-2006) 23 Mon, Sep-20-2004 03:09:00 AM
Discussing New Guide: Enabling the outer LED ring on OEM tail lights in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
