Old Sat, Sep-29-2012, 03:10:56 AM   #1
BMWtomas
Reputation: 0 BMWtomas is on a distinguished road
Default Need help M3 owners please chime in.
I am looking to trade my current car for a 95 M3. What should i watch out for?
Genuine M3s have vader seats, different mirrors, m3 badges obviously, exhaust, rear trailing arm marking or something, m3 on brake calipers pressed out, bumpers etc.
IS IT TRUE that e36 M3's vin codes start with WBS???
I know the only true and safe way is to run the vin (which i plan on doing).
Sorry about dumb/stupid questions, but thanks anyways. I have no experience with M3s, i just have an old turbo bmw. I plan on going to look at it tomorrow or sunday.. will let you guys know what happens.
Jump to top BMWtomas is offline   Reply With Quote
Old Sat, Sep-29-2012, 03:21:25 AM   #2
white-hot
is lurking around the corner
white-hot's Avatar
Default Re: Need help M3 owners please chime in.
Subscribed!!
Old Sat, Sep-29-2012, 03:25:41 AM   #3
BMWtomas
inb4igetflamed
Old Sat, Sep-29-2012, 04:05:27 AM   #4
anarekist
i has m3 now?
anarekist's Avatar
Reputation: 0 anarekist is on a distinguished road
sigh. good luck dude. you should take the care you're interested in to the dealer for a PPPPPP inspection.
1998 Techno-Violet ///M3
Jump to top anarekist is offline   Reply With Quote
Old Sat, Sep-29-2012, 07:36:04 AM   #5
Em&M
So OEM It Hurts
Em&M's Avatar
Reputation: 0 Em&M is on a distinguished road
Hey,
Good luck my friend! Read up, search this forum, do your homework.
Here's a classic thread: http://www.m3forum.net/m3forum/showthread.php?t=300562
///Shadi
'99 M3 Alpine/Dove
Jump to top Em&M is offline   Reply With Quote
Old Sat, Sep-29-2012, 12:55:15 PM   #6
Richardsperry
95 SC M3
Richardsperry's Avatar
You shouldn't have to watch out for anything, maybe a strat bus...
Anyway, pay me $16,500, and you can have mine. Done... I don't drive it anymore...lol
Old Sat, Sep-29-2012, 02:16:50 PM   #7
propchef
Toodle-oo Motherf**kers
propchef's Avatar
Reputation: 0 propchef is on a distinguished road
Yea, but is it a real M3? Does it have badges and stuff?
Originally Posted by AllwaysLow View Post
x2 and some Chicago style pizza
Originally Posted by M3Dom View Post
He's suffered enough.
Originally Posted by EKaru View Post
STFU Klong!!!!! Go Fuk Yourself!
Jump to top propchef is online now   Reply With Quote
Old Sat, Sep-29-2012, 03:37:47 PM   #8
E36.Mthreezey
E36.Mthreezey's Avatar
Reputation: 0 E36.Mthreezey is on a distinguished road
^ lol
Jump to top E36.Mthreezey is offline   Reply With Quote
Old Sat, Sep-29-2012, 04:51:29 PM   #9
white-hot
white-hot's Avatar
Old Mon, Oct-01-2012, 08:12:11 PM   #10
xmetrix
Reputation: 0 xmetrix is on a distinguished road
I got a ppi and it was ****ing bullshit, they totally missed that the car had no auxilary fan, the rtab carriers were installed upside down, and the ****ing fcabs were worn. I knew it didnt have the aux fan and the fcabs were worn, but wtf, upside down suspension parts. shows how well dealers follow a checklist.
Grab your phone, go to the car, pull the vin # from the dash and check it at realoem.com , also pull the vin from behind the block (use a mirror or inspection camera) to see if its the original engine, check each fender for vin #'s. check each door for vin #'s, and remove the rear license plate to check that vin. if theres no vin, its an aftermarket trunk lid (unless they put it on the inside on other years thatn those i own. if there's a DOT tag, its a replacement fender (lowers value to purists/collectors), jack up the front end and tug on the wheel side to side, into and out from the car, check for play. Check for cracks/signs of fatigue on the rtab carrier and rear subframe. Check flexdisc couplers on the driveshafts. check to see if the thermostat housing is metal or plastic. check the fuse panel, see if they're all Geniune OEM BMW style fuses (replaced fuses usually means electrical problems/grimlins/harness swap/retarded po). Check for rust if you see any, RUN AWAY!
Jump to top xmetrix is offline   Reply With Quote
Discussing Need help M3 owners please chime in. in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
