Old Sat, Oct-20-2018, 07:29:48 PM   #1
kokgo20
kokgo20's Avatar
Default 255/40-18 or 265/35-18 and what tires to use for DD?
Currently running PSS 255/35-18 on 18x9.5 et22 all around with -2 degree camber with no problems
Would like to get more sidewall which size & tires should i go for and why?
Build thread---------- INSTAGRAM ------------ROTREX REBUILD-------------Now offering custom digital gauges
2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - SDW monoball RTABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + TTFS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Jump to top kokgo20 is online now   Reply With Quote
Old Sat, Oct-20-2018, 07:31:37 PM   #2
ggrslc
Reputation: 0 ggrslc is on a distinguished road
Default Re: 255/40-18 or 265/35-18 and what tires to use for DD?
May as well go square.
Jump to top ggrslc is offline   Reply With Quote
Old Sat, Oct-20-2018, 07:32:39 PM   #3
ggrslc
Your DSC will like you better.
Old Sat, Oct-20-2018, 07:34:43 PM   #4
ggrslc
Use the 255ís if you want more sidewall.
Old Sat, Oct-20-2018, 07:37:05 PM   #5
ggrslc
Use the 265ís if you want bit more grab.
Old Sat, Oct-20-2018, 08:34:04 PM   #6
bigjae1976
Will 255/40ís fit up front?
Iíd just go with whatever is size is cheaper.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Sun, Oct-21-2018, 02:23:25 AM   #7
265/35/18 is most popular for a "9 or 9.5" square setup from what I've read from those that track.
Tires for street only, Michelin pss or ps4. Maybe cups or some other higher temp tire if you only do 5k a yr or less.
Evolve-R Alpha N Evolve CF CSL Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 2.5" sect 1 SS unres 2.5" sect 2 SCZA 2.5" sect 3 Besian RE pulleys/fan delete CSL battery
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack
Old Sun, Oct-21-2018, 02:31:03 PM   #8
kokgo20
kokgo20's Avatar
Donít see why not since Iím currently running 255/35 with zero problems.
My track setup is square 275/35-18
Discussing 255/40-18 or 265/35-18 and what tires to use for DD? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
