Old Tue, Oct-09-2018, 06:38:11 PM   #1
///ALpineVert
Reputation: 0 ///ALpineVert is on a distinguished road
Default 245/45/18 Help
I posted in the racing forum, maybe this will get more views...
Im running stock 18 rims on my e46. Im currently running 245/40/18 front and 275/35/18 rear RE-71r for autocross.
My front tires are toast and wont make it the rest of the season(3 events).
I saw a deal on some barely used 245/45/18 re71r tires so I bid/bought them.
My question is, will I be able to use the 245/45/18 in combination with the 275/35/18 rears? This is approx .55 inches diameter difference. I run without traction control but will this put me in limp mode or something?
Better just to flip my fronts and sell the 245/45/18 tires that I bought?
Jump to top ///ALpineVert is offline   Reply With Quote
Old Tue, Oct-09-2018, 09:56:04 PM   #2
E46Hoonigan
E46Hoonigan's Avatar
Reputation: 0 E46Hoonigan is on a distinguished road
Default Re: 245/45/18 Help
It should be completely fine.
http://www.m3forum.net/m3forum/showthread.php?t=318122
Edit: I misread the thread. I'm not sure if a 245/45/18 would work.
Instagram: sid_e46
CarbonBlack/Cinnamon E46 M3
Koni/Vogtland, Apex ARC-8 18" Square/PS4s, Powerflex, Megan Racing Sec. 3, WPC Rod Bearings, ECS OCC, Besian VANOS, Mishimoto Electric Fan, 3.91 Gears, 996 Brembo, OEM CSL Trunk/Diffuser
Alpine White/Sakhir Orange F10 M5 Comp
Stage 1 Vargas Turbo Upgrade
Jump to top E46Hoonigan is offline   Reply With Quote
Old Fri, Oct-19-2018, 04:50:29 AM   #3
///ALpineVert
To follow up, they won’t fit. The extra 0.2255” won’t clear the strut assembly. I had to buy another set of 245/40/18 fronts. I never noticed but the clearance with those is REALLY tight.” But they(245/40/18) fit.
Discussing 245/45/18 Help in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
