Mobile M3forum |
| E46 M3 (2001-2006) Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm Total Produced: 45,000+ - Years Produced: 2001 to 2006. |
#681 | |
TurboToys exhaust hub, PM him. Beisan Systems: http://www.beisansystems.com/products.html S54 Rebuilt Vanos Solenoid Coil Pack S54 Vanos Sealing Plate Repair Kit S54 Vanos Seals Repair Kit Dr. Vanos: http://www.drvanos.com/index.php?opt...&id=5&Itemid=6 Cam Bolt Repair Kit ECS (or anywhere else you can get it, ECS had best prices IMO) Vanos Gasket ES#23225 VANOS Filter Change Kit - Level I ES#1892454 I paid a grand total of a little over 1.1k, no calculating in the $150 back from beisan for the solenoid pack and some money back from TT for your old hub. Good luck! In theory you could start getting new chain's and spindles etc etc, but I am not so much worried about those parts, check everything while your down there though. |
| Sponsored Links |
#682 | |
![]() Location: Central NJ
#683 |
Piraña Powered
![]() Location: Westchester/Boston/Windham
Many others have done it without a lot of prior experience. Look at the DIT and decide for yourself
Vanos hub / bolts DIY Oil Pan Removal DIY Foam subframe reinforcement DIY Plastics Renewal DIY Spacer DIY ESS NA Tune Review Tools: -Shim kit -Timing tool -Engine support -Grainger foam applicator gun DIY stuff -Available in the NY/MA/NH area |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
