Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted > E90/x - Parts for Sale/Wanted
E90/x - Parts for Sale/Wanted Use this section to post parts for sale or wanted that are related to the E90, E92 and E93 M3 only.
Old Thu, May-18-2017, 01:45:07 AM   #1
AOE
Reputation: 0 AOE is on a distinguished road
Default StopTech Trophy BBK - STR60 6-Piston 380mm Front / STR40 4-Piston 355mm Rear
SOLD!!!
Hi everyone.
I'm usually on the M3Post forums since this forum is more centered around the E46 generation, but posting this here just in case!
I bought this setup used from an awesome fellow M3Post member back in late 2016, but have since decided to take the car in a different direction so the kit is now being offered for sale to a good home. I've fully rebuilt the calipers after acquiring the kit, however it was never mounted nor used under my ownership.
This is the StopTech Trophy Street STR60 6-Piston 380mm front, STR40 4-Piston 355mm rear BBK.
Note that the "Trophy Street" kit comes with dust boots, whereas the "Trophy Race" kit does not.
The StopTech trophy kits have the following differences that set them apart from the non-trophy StopTech kits:
- Anodized calipers (regular kit has painted calipers)
- Anodized 7075 billet aluminum AeroHats (regular kit has painted AeroHats)
- Trophy STR60 piston sizing = 36mm, 34mm, 32mm (regular non-trophy ST60 piston sizing = 36mm, 36mm, 30mm)
The rotors included with this kit all measure near new, with barely any discernible wear in thickness from new spec. Measurements are as follows:
Front 380mm rotor 1 = 34.96mm = 98% remaining rotor life
Front 380mm rotor 2 = 34.92mm = 96% remaining rotor life
Rear 380mm rotor 1 = 31.95mm = 97.5% remaining rotor life
Rear 380mm rotor 2 = 31.95mm = 97.5% remaining rotor life
Remaining rotor life was calculated based on the following information:
- StopTech suggests rotors be replaced after 2.00mm of material have been used
- StopTech specs the front 380mm rotors as being 35.00mm thick when new
- StopTech specs the rear 355mm rotors as being 32.00mm thick when new
All 4x calipers included in this kit have been fully rebuilt to ensure optimal performance and longevity. No part of this kit has been mounted or used whatsoever since the refresh was completed. The refresh was meticulously conducted and entailed the following:
Step 1) All 20x pistons were removed and stainless steel lines disconnected to prepare for the cleaning process; old piston seals and old dust boots were discarded
Step 2) All 20x pistons were individually inspected for any damage, scoring, or issue; none were found whatsoever
Step 3) All calipers, caliper parts, pistons, and stainless steel lines were decontaminated using Iron X ferrous metal remover
Step 4) All calipers, caliper parts, pistons, and stainless steel lines were degreased using Optimum Power Clean
Step 5) All calipers, caliper parts, pistons, and stainless steel lines were cleaned using Optimum Car Wash
Step 6) All calipers, caliper parts, pistons, and stainless steel lines were thoroughly dried using an air compressor
Step 7) Installed 20x brand new genuine StopTech piston seals into the calipers using StopTech caliper ASSEMBLY Lube (NOT brake caliper lube, which is the wrong lubricant for this application)
Step 8) Re-installed all pistons into the calipers using 20x brand new genuine StopTech dust boots
Step 9) Exterior surfaces of all 4 calipers treated with a heat resistant coating of Polish Angel SuperSport
What you will receive with the kit:
- 2x STR60 complete front calipers
- 2x STR40 complete rear calipers
- 2x 380mm front rotors /w STR60 Trophy AeroHats
- 2x 355mm rear rotors /w STR40 Trophy AeroHats
- Front and rear StopTech braided stainless steel brake lines /w banjo bolts
- Brand new in box StopTech Sport brake pads for both the front STR60 and rear STR40 calipers (the StopTech "Sport" compound is the most updated version of their previous "Street Performance" compound)
Note that you will need to acquire new copper washers to secure the SS lines/banjo bolts to the calipers properly when you install the BBK, as I have discarded the old washers since it is not recommended to re-use them. These can be sourced from https://www.zeckhausen.com/catalog/p...oducts_id=1607 or www.bimmerworld.com for a few dollars.
Asking $5,000 shipped for the entire setup, or $4900 shippped without the brake pads (price includes shipping within the continental US only; anywhere else will be extra).
Local buyers are welcome to pick the kit up from me for a $100 discount; I'm located in 98403 WA.
I can accept cashier's check, cash, Google Wallet, or PayPal (either +3.5% to cover PayPal fees, or sent using the friends and family option).
Please PM me or post here with any questions, and I'll be happy to answer them!
Cheers,
Jason
[IMG]https://lh3.googleusercontent.com/GVLSyQF0I5xfXP44XoG2TTPrmSYwAyMmDnwoPcOvnMcBelk52Y YLQ65sIWM_vwxmawA0VdamLljIQ88A0UX3qyj1dPMexkgVzWCb eOLg8LsVgOXVKb1ulOwcP9rGEe9kt_4wdCaGEbfMQmSeeBd-SIdv-J7aX-crSmyAgSY_9UdW3H23LeW_gkFVouIzEI3mFnXaFH29B6hCj1ib jm5KLqmm8us-StA5KBTSvzBwFBZ3skGbsRRb1G1uzaPPOUSALtOowRxCaHpJsc UrHV2qndfahCtFIAPUNLwOB93Dr5sxCp5YPGNlbxPkVIJ90ejI vhXhOk-zBEtDqnwgxmx5eaK9YyyE8hcubhQcZ76tkj_vhnrnURuSIjynr thJGZQMKCKCmm7K8PzzYis1hBuw7wpeawDOs0OzB87SEe0cXg5 JAXCSfsMkEiFLndKlm_ifBXVP7SeRYCOIiG5Y17EawpGXatI1x R_60EKzFsXFCOiAanI376kOoAUtBWnCslfSnND04_AtMRjng1Z ***aGJIaFioj4W_wlz947yiOcrpNkN9NzYIzImMOJocpFXHRXB z609gPw2QOJGfXkRQAsit9mEY6sLQevaU2Grlvhfq8FCgAfiRn 3qcpfWdJf0Fxgs0ctAP8Rg9OKNGWrutvpOLNUGpN6umZC99vW-W7a5w=w1689-h950-no[/IMG]
[IMG]https://lh3.googleusercontent.com/d4deQ6_sUm0Kge3M3ZPLOt1QGVpbeGs08JysQj1X_4e9B7DBlR _hTf_v8H-9hJbs5oPLL89EI9EXQ5-xHkUUu45KxHqDLCYPR9QSIKonzh5J2s-QFOCZ6Rre3EpZshjBEGYugvqZvxl6iplUIRB5FJhYh33GKyWTg Vn3WAc_eZDE4XStEHm08jns-4i-EWG1DiaP3w7sNxzGLk-XJhr3zsKsT9I_QSWdSn-OXyCzSOnpFWQmO9ddcc6edozOwNzIZEINwDQXjUhCkjb5CPfWt 5UNWUIG-MZv7gi1Un8yfTe31V8hS8HOD59erwGyBv_dgnDNCnQhyDdL3Pf BmzEygEpqHgoJSU9u5YV1eOpBq4g7rN-mX824TiwM0uSxhz4-HDcDeW8NBGTZmNkEzl_wXqUzDByF4_7SY2HxyPP_pXudY9t6Qo AUmBSm-tnbl7uOxHIaC-WpE_ykCwEqBwFyz9hD6rdvDu1yZfp0Gt36ML49Dlyt-O9YMf0-vCmxp2IvQGS7uqj1SvYr1VnbyzEvv5C-V4xS4mQuO0WPZvYLkv3cOr4ANWWgl0TLmO_P9jmSHeSH08N-PRdzZ0r3A-zRLYGm15STe00m54yr***FbXQB5t_2CF-5oFRmPjlkCA6otKfMJKqXRjVrdLHn8WFEA06ovL9hR55o9MLrD nEeYg=w1689-h950-no[/IMG]
Jump to top AOE is offline
Rate Seller View Rating
Old Sat, May-27-2017, 10:30:24 PM   #2
G3t0ut
Reputation: 0 G3t0ut is on a distinguished road
Default Re: StopTech Trophy BBK - STR60 6-Piston 380mm Front / STR40 4-Piston 355mm Rear
I want these! and im local but I am a few checks away from having enough "play" money :P
You will be hearing from me if they are still available when I am ready; otherwise GLWS.
Jump to top G3t0ut is offline   Reply With Quote
Old Sat, May-27-2017, 10:44:51 PM   #3
AOE
Sounds good mate, just let me know!
I've also recently dropped the price:
Local buyers are welcome to pick the kit up from me for a $100 discount off either configuration (/w brake pads, or w/o brake pads); I'm located in 98403 WA.
Jump to top AOE is offline   Reply With Quote
Old Mon, May-29-2017, 11:35:25 PM   #4
AOE
Bump! $5K shipped for a freshly rebuilt kit!
Old Wed, May-31-2017, 04:48:23 AM   #5
AOE
Pending sale!
Old Wed, May-31-2017, 06:48:19 AM   #6
AOE
Sold; thanks for the interest everyone!
Discussing StopTech Trophy BBK - STR60 6-Piston 380mm Front / STR40 4-Piston 355mm Rear in the E90/x - Parts for Sale/Wanted Forum - Use this section to post parts for sale or wanted that are related to the E90, E92 and E93 M3 only. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
