Old Thu, Aug-15-2019, 05:25:23 PM   #1
hooptie157
Reputation: 0 hooptie157 is on a distinguished road
Default SMG Transmission Question - will it fit in an already manual M3?
Hello,
Hypothetically if I needed to replace a transmission in a manual M3 could I use an SMG transmission and just remove the pump? I know its the same tranny but wasn't sure what modification were needed.
I ask because I suspect the SMG tranny would be in munch better condition (syncos, clutch etc) because the computer was doing the shifting plus they are much cheaper online.
Let me know thanks!
Jump to top hooptie157 is offline   Reply With Quote
Old Thu, Aug-15-2019, 05:29:11 PM   #2
Texaz3
Default Re: SMG Transmission Question - will it fit in an already manual M3?
Yes, need bell housing from a 6MT though.
“Aerodynamics are for people who can't build engines.” - Enzo Ferrari
Old Thu, Aug-15-2019, 05:32:16 PM   #3
hooptie157
Oh yeah I'd be removing a manual tranny so I'd have the complete tranny and parts to work with. I'd probably throw a RTD or CAE in at the same time.
so just swap the bell housing and remove the pump?
Old Thu, Aug-15-2019, 05:32:35 PM   #4
tjkenny15
tjkenny15's Avatar
Reputation: 0 tjkenny15 is on a distinguished road
Or, you can have the SMG bell housing machined and converted to a manual bell housing.
2005 BMW M3 INDIVIDUAL - Estoril Blue
Jump to top tjkenny15 is online now   Reply With Quote
Old Thu, Aug-15-2019, 05:34:16 PM   #5
hooptie157
Id have the bell housing for the existing Manual Tranny. So basically I'm good to go right?
Old Thu, Aug-15-2019, 05:41:51 PM   #6
hooptie157
Also is there a DIY for the transmission removal?
Old Fri, Aug-16-2019, 01:46:21 AM   #7
ddaniel1
ddaniel1's Avatar
Reputation: 0 ddaniel1 is on a distinguished road
I did exactly this, replaced a six speed in bad shape with a low milage SMG, it has been flawless, read the swap threads, it will show you what you need to do, swap bell housing and tap a hole for the gear position sensor.
http://www.m3forum.net/m3forum/showthread.php?t=444126
Jump to top ddaniel1 is offline   Reply With Quote
Old Fri, Aug-16-2019, 03:51:05 AM   #8
If you are going with an RTD or CAE self centering shifters, you don't need to swap the bellhousing or machine the smg bellhousing...
You will need to tap (make threads in the aluminum housing) in the blind plug on the smg tranny to be able to thread in the gear position switch.
You also need to get parts 8,9,10 from a manual (link below) and swap them into the smg tranny. https://www.realoem.com/bmw/enUS/sho...diagId=23_0887
In short, yes, very easy to swap the trannies, but positions of some of the sensors are a bit different (reverse sensor and gps), but easy to make work with 6mt wiring and change a pin.
Discussing SMG Transmission Question - will it fit in an already manual M3? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
