Old Thu, Jul-22-2010, 06:17:44 PM   #11
Mvez
RS-aholic
Mvez's Avatar
Reputation: 0 Mvez is on a distinguished road
Originally Posted by Gtfour View Post
I'm not sure right now if i put back the oem clutch/flywheel or keep the FX300 with a steel flywheel.
Oem was going well in my opinion, the reason i have an upgrade clutch/flywheel kit is because it was a free parts from my sponsor. It wasn't a priority for me to "upgrade".
Apart from the vibration, did you like the feeling of a 10lbs flywheel? I don't.
uh, after you fix your balancer and rod bearings, I go back to stock setup with an uprated clutch. what's not to love about a lighter flywheel? Just sucks the S54 simply doesn't like them, at all. If you are dead set on a lighter flywheel, then go with the clutchmasters steel flywheel and a FX300 sprung hub clutch, otherwise get a rigid hub FX300 clutch kit and go back to the stock flywheel.
'13 E92 M3 Coupe - Daily
'00 Miata - DE toy
'11 E92 M3 Coupe - track build starting
'12 Cayenne
'09 Ford F350 DRW - tow rig
Jump to top Mvez is offline   Reply With Quote
Old Thu, Jul-22-2010, 09:06:33 PM   #12
337
Frenchie
337's Avatar
Reputation: 0 337 is on a distinguished road
Good info!
Jump to top 337 is offline   Reply With Quote
Old Fri, Jul-23-2010, 10:15:23 AM   #13
Gtfour
Gtfour's Avatar
Reputation: 0 Gtfour is on a distinguished road
First post edit with pictures
Jump to top Gtfour is offline   Reply With Quote
Old Tue, Feb-15-2011, 05:30:39 PM   #14
mpegripper
mpegripper's Avatar
United Kingdom
Default Re: Have you change your harmonic balancer on your E46 M3?
so with a stock flywheel, how often should we be replacing the harmonic balancer as preventative maintenance?
also, anyone have a link to the tool for holding the crank pulley?
Old Tue, Feb-15-2011, 06:17:05 PM   #15
mpegripper
mpegripper's Avatar
United Kingdom
i found the tool, old part number was 90886110280 and tischer's site says the new part number is 83300493843
Old Tue, Feb-15-2011, 08:17:57 PM   #16
delirium45
Bottom Feeder
Reputation: 0 delirium45 is on a distinguished road
Originally Posted by mpegripper View Post
i found the tool, old part number was 90886110280 and tischer's site says the new part number is 83300492843
i think you mean part# 83300493843, the one you listed is for an E31 wiring set, and is a good bit more expensive
and i believe i saw somewhere that the maint interval for the harmonic balance is 100K miles
_ Garrett
2011 Rocky Mountain Region GTS4 champion & "Rookie of the Year"
2012 Rocky Mountain Region GTS3 champion
2013 National GTS3 - 4th place
Thanks Sponsors: SCR Performance
Jump to top delirium45 is offline   Reply With Quote
Old Tue, Feb-15-2011, 08:40:36 PM   #17
mpegripper
mpegripper's Avatar
United Kingdom
oops, typo..i'll correct it
Old Tue, Feb-15-2011, 09:21:48 PM   #18
Gtfour
Gtfour's Avatar
I think if you track the car a lot you should do it before 100k cause they seems to melt-split around 100k
Mine melt at 105k.
It's an ''expensive'' part but it can save A LOT of problem in the end...
Also, i think vibration isn't the only issue. My car is a 2002, it's a 9 years old car and rubber isn't new anymore. And heat also destroy them. I think it's a good idea to duct some cool air to the damper.
Old Tue, Feb-15-2011, 10:27:21 PM   #19
admranger
Registered troublemaker
Nothing on the aftermarket for this yet?
'11 E90 M3, Melbourne/Black/Fox Red/Black, 6MT, roof, PP2, heated seats, Eibach Pro Kit, GC Street camber plates, Arc-8's, Technic harness, JL XD 600/6
Old Tue, Feb-15-2011, 11:42:47 PM   #20
wrcdave
Mr. Chicken rules!
Reputation: 0 wrcdave is on a distinguished road
I have 5 track seasons on my jb flywheel with zero issues. The s54 revs much quicker with less rotational weight as would any engine. I have a 3" duct venting mine since last season as I have heard of this issue popping up but only recently which leads me to believe that the failue has more to do with age and mileage. The rod bearing upgrade is on my list of things to do soon but I wouldn't be afraid to run an aluminum flywheel. If you have a track only car and compete you have no choice but to do all of the mods the rules allow to be competitive. Just my .02
Jump to top wrcdave is offline   Reply With Quote
balancer, change, e46, harmonic
Discussing Have you change your harmonic balancer on your E46 M3? in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
