Old Mon, Jan-11-2010, 01:00:59 AM   #11
trange1
Reputation: 0 trange1 is on a distinguished road
Originally Posted by NVS PWR View Post
Extended life oil changes are not good for any motor especially a high strung one- it is a marketing edge to make maintainance costs look lower all manufactures are doing it- their goal is to have you buy a new car when you finish your last payment and you warranty is up because the forever fluids did not hold up. so its either spend 4k on repairs on 4k on a down payment most people opt for the down payment new ride deaaler wins.
Why skimp on one of the cheapest engine insurance plans a $70 oil and filter change.
I have two E46 M3's that I change the oil every three thousand miles
one car has 86000 and the other one 92000
driven hard every day
NO VANOS FAILURE OR OTHER PROBLEMS
THE LOW MILEAGE CARS with VANOS problems is due to the fact that the wonderful 15k mile CASTROL oil is breaking down and clogging the screens
I USE LIQUI MOLY 10W-60 RACETECH OIL and one quart of SYNTHETIC LUCAS OIL ADDITIVE every three thousand miles
lAST Time the valve covers were off one car needed one valve shim- the time before neither car needed any-(no castrol in these cars)
The point is more oil changes equals less worry.
I change my trans,and diff fluids every 15k, in addition I change my fuel filter every 15k also.( I still get 17-19 mpg local and 25-28 mpg on the highway) with supporting mods
Nothing is made to last forever- and the more you maintain it the longer it will last.
Just my
some will appreciate it and some will have their own opinion.
What an enlightening and informative post. I have a couple of questions: How long have you been using Liqui Moly?
Did you notice any wear on your cam lobes?
I have been using only TWS and while complying with my valve adj. schedule I noticed wear on the aft cam lobes. I am definitely switching oil this next oil change however I feel that it is probably more important to change oil frequently than the brand of oil used.
My carfax shows that the previous owner followed the BMW oil change schedule and I feel that is why my valvetrain suffered, not because of TWS.
Having said that though if TWS is the only oil BMW recommends it should be able to withstand BMW's maintenance schedule, looking at my engine it can't!
I am still trying to gather all the info I can find as I am still deciding to go with Liqui Moly or Redline, but I am definitely trying something other than TWS and increased oil changes in hopes that the wear on my cams doesn't become catastrophic.
Jump to top trange1 is offline   Reply With Quote
Old Mon, Jan-11-2010, 01:56:42 AM   #12
NVS PWR
Final Touch Motorsports
NVS PWR's Avatar
Reputation: 0 NVS PWR is on a distinguished road
I have been using LIQUI MOLY for 18 months- prior to that I was running mobil one 15-50
I am not saying castrol is bad- what i am saying is that no oil should be run for 15000 miles.
The M was built with pride to be driven with pride why would one not want to maintain it with pride.
Redline is a real good oil also, but again I would still change it at three thousand, 4000 the most and thats for any oil I use.
UUC,BORLA,ROGUE BLUE RTABS-RSM & OIL HOUSING,H&R,BIMMERWORLD,BOSCH,ECIS,VMR,RPM,
NGK,NX,MSD,DEI,EVOSPORT,SHRICK,SHARK,K&N,
TOPSPEED,STEWARTWARNER,LUBROMOLY,LUCAS,
MAHLE,REDLINE,TOYO T1,MICKEY THOMSON DR'S,PAGIDBLUE, VELOCITY MOTORING,SNOW PERFORMANCE WATER METHANOL INJECTION,S&W,POWDER COAT,CUSTOM NX INSTALL BY FINAL TOUCH MOTORSPORTS,
CUSTOM GUAGE POD BY FINAL TOUCH MOTORSPORTS, CUSTOM ROLLBAR BY FINAL TOUCH MOTORSPORTS
Jump to top NVS PWR is offline   Reply With Quote
Old Mon, Jan-11-2010, 02:49:21 AM   #13
deilenberger
deilenberger's Avatar
Sounds great. Even better than 3,000 mile changes would be 1,000 mile changes, or even 500 mile changes.. or how about you never start the engine and just keep pouring oil through it. That's where you're headed with your theory.
Actually - not. There has been very little evidence of the "screens" getting clogged (there is one cone shaped filter - which was an idea of the moment here - pull it out and clean it.) The vast majority of people found it didn't need cleaning. Go figure.. The REAL Vanos problems are on late model cars where the cam-mating gear snaps off the two drive nubs, which then get caught under the chain, taking them up and over the two sprockets and grenading the valve cover. That is the VANOS problem (and I've seen no correlation to oil change frequency with it - it appears to be a materials failure by BMW - the finely engineered/constructed engine.) The other Vanos problems are due to either a bad solenoid or seals going bad.
Well, good for you. The oil companies must love'ya.
Just my
Without oil tests it's ALL just opinion. Do some oil tests with Blackstone, in particular the extended change interval text ($10/extra) and see what they say about your 3,000 mile oil changes. It will cost less than one unneeded change.
Old Mon, Jan-11-2010, 02:59:32 AM   #14
deilenberger
Do you have any photos of your worn cam lobes? Some of the acceleration ramp (where the cam start pushing down on the cam-finger) and the lobe tip would be of interest.
I also didn't see - what year is your M3?
Old Mon, Jan-11-2010, 11:29:17 AM   #15
trange1
I did take some photos. I believe I downloaded them to my laptop at home and unfortunately I'm not scheduled to go home until the end of the month.
I will definitely try to post them in this thread even if it will be 2 weeks from now as I am very interested in what others think about this problem.
I can tell you that I noticed the wear on two lobes in the aft end of the engine I believe on the intake side. The wear was near the tip and starting down the acceleration ramp as you describe.
Not looking to get into alternative oil argument yet again, but wouldn't you be concerned if you opened up your engine and saw the wear I'm describing. I am since I know that the car has only ever seen TWS and has been on BMW's maint. program for it's entire life.
This is not suppose to be happening as I and the previous owner have done everything right and by the book.
Oh, and the car is an 02/03
Thanks for any help from anyone.
Old Mon, Jan-11-2010, 01:25:25 PM   #16
deilenberger
Without seeing what the wear is - dunno. If I had to guess - the wear wasn't due to the oil used.. it was more likely a manufacturing defect of some kind. What kind? Dunno - defective finger-follower mebbe? If this was the oil's fault, we'd be seeing a lot of complaints about it, and we're not. Yours is the first I've seen (aside from one chap who had an aftermarket cam in his car that experienced wear - with aftermarket, all bets are off..)
OK, just checking to see if it was one of the '01 or early '02 cars that came with 5W-30 from the factory (before the change to TWS..) But even those cars - haven't heard of any rash of camshaft failures.
Old Mon, Jan-11-2010, 01:32:48 PM   #17
tenfifteen
Pale Geek Rigour
tenfifteen's Avatar
Reputation: 153 tenfifteen is a splendid one to beholdtenfifteen is a splendid one to behold
Sigh..
Valves are done at EVERY INSPECTION SERVICE. It's in your manual, it's in the stickies, it's in the valve adjustment DIY. Do we have to tatoo it on people?
A thousand pardons sir, thanks for pointing out my error so politely.
Yes... it's done at every inspection. I forgot or missed it in the maintenance thread, but cannot find any mention of it whatsoever in the manual. On what page did you find it?
Jump to top tenfifteen is online now   Reply With Quote
Old Mon, Jan-11-2010, 02:06:52 PM   #18
trange1
Thanks for the civil reply.
I have been thinking about this problem for quite a while and have come to the conclusion that it would be in my best interest to keep using TWS.
Say for instance I switch oil and next time I c/w my valve adj. I notice significantly more wear than before. Not only will I not know if the different brand of oil accelerated the wear but BMW will be a lot less likely to be helpful with any repair costs even though I'm out of warranty, knowing TWS wasn't used.
Since I purchased the car I have increased my oil changes to once every 6 months which is about 5K mi. You maybe right about a manufacturing flaw but I'm sure the 15K mi BMW oil changes that were recommended didn't help the situation.
I agree that if this was a fault of TWS it would be a lot more common than what I have been able to find.
Old Mon, Jan-11-2010, 04:22:44 PM   #19
deilenberger
I don't have my manuals in front of me - but I know in my M-Coupe manuals (which has an S54 in it) - the Inspection I and II schedules are in the Service and Warranty manual (the one where the dealer stamps that service has been performed - although that seems about unknown in the USA..) Probably the same place on the M3 manuals. I'll have to take a peek..
Old Mon, Jan-11-2010, 04:24:08 PM   #20
nwthunder
nwthunder's Avatar
Reputation: 0 nwthunder is on a distinguished road
3000m for me
TT 04.5 Cummins
03.5 E46 M
Jump to top nwthunder is offline   Reply With Quote
change, interval, miles, oil, time
Discussing Oil Change Interval (Miles and Time) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
